-   Z3X-Team Products (http://forum.gsmhosting.com/vbb/f453/)
-   -   Samsung sgh-i537 s4 active unlock done (http://forum.gsmhosting.com/vbb/f453/samsung-sgh-i537-s4-active-unlock-done-1715976/)
virgin_phones 09-18-2013 17:56
root with geohot tool.
connect with usb
Selected model: I537
Selected port: COM117 SAMSUNG Mobile USB Serial Port
Selected port speed: 115200
Searching ADB device... OK
Reading phone info...
Model: SAMSUNG-SGH-I537
Android version: 4.2.2
Product code: SGH-I537ZAAATT
Phone version: I537UCUAMF3
PDA version: I537UCUAMF3
CSC version: I537ATTAMF3
IMEI: 356554051xxxxxx
Phone S/N: R31D61xxxxx
Checking phone at COM117 OK
Backuping NVM... OK
Checking Super user right... true
Backuping MMCBLK... OK
Writing data to phone... OK
Rebooting phone... OK
Restoring NVM... OK
Reseting... OK
Unlock done
Done with Samsung Tool v.15.6
virgin_phones 09-18-2013 18:09
imei show 0 after unlock when i try repair i get error
Product code: Not Active
IMEI: 0
spent 1ms
Phone S/N: R31D617BGWT
Backuping NVM...
Exception: Cannot create file "C:\Program Files\Z3X\Samsung\SamsungTool\NVM\I537_0
spent 1ms_18-9-2013_16-2-33_bkp.nvm". The filename, directory name, or volume label syntax is incorrect
but phone still works
T Mobile 09-19-2013 14:43
You shoud trying to restore nvm backup
appolo 09-20-2013 12:29
same problem
unlock done but imei 0
Selected port: COM31 SAMSUNG Mobile USB Serial Port
Product code: SGH2I537ZAMATT
IMEI: 356xxxxxxxxxxxxxxx
Phone S/N: R31D8077S6N
Checking phone at COM31 OK
Backuping NVM... OK
Restoring NVM... OK
Reseting... OK
Unlock done
cannot write NVM
cannot repair imei
IMEI: 0
spent 5ms
Backuping NVM...
spent 5ms_20-9-2013_3-1-6_bkp.nvm". The filename, directory name, or volume label syntax is incorrect
NOTE: the phone works fine
but how to repair the imei
blang 09-20-2013 14:01
after unlock - power off / on phone. all will ok.
appolo 09-20-2013 14:21
same
i do that but still
imei 0/04
jcp.india 09-22-2013 15:51
Selected port: COM536 SAMSUNG Mobile USB Serial Port
Please, allow USB debugging on phone... OK
IMEI: 356554052786874
Phone S/N: R31D8076FER
Checking phone at COM536 OK
Backuping NVM... OK
Restoring NVM... OK
Reseting... OK
Unlock done
after unlock imei gone.........
imei shows 0/04
and mobile not woking with any network(airtel,idea.vodafone and aircel ect)..............
need solucation,its very big proble........
jcp.india 09-22-2013 15:56
i try to restore nvm but not done.......
IMEI: 0
spent 1ms
Backuping NVM...
spent 1ms_22-9-2013_18-45-40_bkp.nvm". The filename, directory name, or volume label syntax is incorrect
IMEI: 0
spent 2ms
Backuping NVM...
spent 2ms_22-9-2013_18-46-20_bkp.nvm". The filename, directory name, or volume label syntax is incorrect
IMEI: 0
spent 1ms
Backuping NVM...
spent 1ms_22-9-2013_18-47-15_bkp.nvm". The filename, directory name, or volume label syntax is incorrect
jcp.india 09-22-2013 15:57
IMEI: 0
spent 1ms
Backuping NVM...
IMEI: 0
spent 2ms
Backuping NVM...
IMEI: 0
spent 1ms
Backuping NVM...
jcp.india 09-24-2013 06:53
MR BLANG where is solucation...........................
Levitation 09-26-2013 23:59
I'm about to unlock i537... Until I read this thread.
I have a feeling my imei will become 0.
..........Wondering if I will have a better unlock if I use this method:
Developers are working for this model...
Till you can try this method on your risk..
Use Samsung Tool 15.0
Root with Geohot's Active root
New diag mode:
*#0808#
Select DM+Modem+ADB
Select i337 and repair with the same value as on the label only!!
This will wipe the security area and will unlock your phone.
Don't know what to do or risk doing... Customers phone. Don't want to break it.
blang 09-27-2013 00:03
IMEI: 0
spent 1ms
Backuping NVM...
IMEI: 0
spent 2ms
Backuping NVM...
IMEI: 0
spent 1ms
Backuping NVM...
fixed. just use last version.
Levitation 09-27-2013 00:11
blang... You said 'Fixed. Just use last version.'
What's fixed? Unlocking the phone without causing imei 0, or backing up NVM problem jcp.india was having issues with? Thanks.
Levitation 09-27-2013 07:10
Can someone please tell me if its safe to unlock this phone without changing imei? If yes, how?
Or should I use old method of i337 unlock on it? Is that safer? Please input brothers!
Levitation 09-27-2013 19:32
(10 char) Bump......... ....
Page generated in 0.33902 seconds with 5 queries
