12-19-2015, 20:30 | #1 (permalink) |
Freak Poster Join Date: Apr 2015 Location: Sylhet
Member: 2385681 Status: Offline Thanks Meter: 11 | Samsung SM-G361F unlock done by z3x pro 2. so u have to download pre rooted firmware from shell ( its named as root system something like that) and flash it in PDA/AP via odin . after flashing u will get SU in ur phone. Click on it and update SU binary ( internet will be needed). 3. now Connect in z3x pro by enabling debugging mode.Select model and go to unlock section and select ADB. 4. And finally click on unlock. 5. Your device is now unlocked. 6. after unlock is done still if it ask for network unlock pin then press 00000000 in network unlock pin and your phone is now unlocked. Enjoy!! Don't forget to press thanks ♦ Tanvir Tanju ♦ |
The Following 2 Users Say Thank You to tanvirtanju For This Useful Post: |
12-20-2015, 09:55 | #2 (permalink) |
No Life Poster Join Date: Sep 2013 Location: Mongolia
Member: 2022955 Status: Offline Sonork: 100.1646687 Thanks Meter: 418 | I already wrote about the ROOT for SM-G361F - 5.1.1: 1) Make sure you have the model SM-G361F / SM-G361M 3) Flash TWRP 2.8.7.1 - SM-G361F : https://dl.twrp.me/coreprimelte/ 4) Run TWRP (Volum UP + Home + Power) 5) Install SuperSU_2.46.zip / ROOT 6) Download and Flash stock recovery : recovery stock firmware / used ODIN : SM-G361F |
The Following User Says Thank You to huaweinckunlock For This Useful Post: |
12-20-2015, 13:39 | #3 (permalink) | |
Member: 2385681 Status: Offline Thanks Meter: 11 | Quote:
thanks for ur method. | |
12-28-2015, 11:52 | #5 (permalink) |
Member: 2385681 Status: Offline Thanks Meter: 11 | yah i tried that method of him too. but failed to got to twrp recovery . then i downloaded this pree rooted firmware and followed my process given in the post . and finally i could unlock it Last edited by tanvirtanju; 04-28-2016 at 14:09. |
The Following User Says Thank You to tanvirtanju For This Useful Post: |
01-02-2017, 19:40 | #9 (permalink) | |
Junior Member Join Date: Jan 2009 Location: spain
Member: 952636 Status: Offline Sonork: chowhan Thanks Meter: 1 | Quote:
this worked, phone was rooted after firmware update and unlocked in seconds. Cheers | |
04-13-2017, 16:38 | #10 (permalink) | |
Freak Poster Join Date: May 2015 Location: Algiers, Algeria
Member: 2399672 Status: Offline Thanks Meter: 187 | Quote:
If phone ask codes after unlocking, use: PUK - 12345678 PIN - 00000000 | |
