Old 10-14-2015, 09:37   #1 (permalink)
Member: 1763380
Thanks Meter: 86
samsung SM-g530h flashing problem
samsung sm-g530h/ds come with bootloop
already did
try flash with one package firmware with pit but setup conection error
try with 4 firmware with pit still error on setup connection
try with odin v3.10.0 and v3.09 same fail
any one can provide me how should i do?
thanks
FLASH INSTRUCTIONS:
1. Choose correct flash file(s).
2. If you have PIT file chosen, then you must check 'Repartition' option.
3. Check flashing options if needed (Repartition, EFS clear, Boot update).
4. Power on phone in download mode (turn off phone, press vol.down + home + power).
5. Connect phone to PC with USB cable, install drivers if needed.
6. Press 'Flash' button.
Operation: Flash
Selected model: SM-G530H
Software version: 22.9
File analysis... OK
Total file size: 0x3FBFD570 (1019 Mb)
Searching USB Flash Interface... detected COM30
Setup connection... error
Done with Samsung Tool PRO v.22.9
Old 04-03-2016, 15:09   #2 (permalink)
Member: 178616
Thanks Meter: 90
Arrow g530h/ds flashing error
i have same problem any help from any team coz i try octoplus z3x and odin but error on all flashing plz any expert way or team support will be appreciated
Old 04-04-2016, 02:02   #3 (permalink)
xerraco's Avatar
Member: 890926
Thanks Meter: 2,053
Post you log mate, What FW did you used?
Br,
xerraco
Old 08-29-2016, 13:25   #4 (permalink)
babudatabase's Avatar
Member: 1490564
Sonork: 100.1671685
Thanks Meter: 182
i have same issue
need solution
The Following User Says Thank You to babudatabase For This Useful Post:
Old 08-30-2016, 21:17   #5 (permalink)
bad_signal's Avatar
Member: 107069
Thanks Meter: 31
What is the vwrsion of ur phone
just dial *#1234#
to know the version of ur phone
put it here and i will got solution for u
br
Old 09-23-2016, 07:42   #6 (permalink)
Member: 2229851
Thanks Meter: 55
i have same problem how to fix?
Old 12-21-2016, 11:12   #7 (permalink)
yudibanjar's Avatar
Member: 713923
Thanks Meter: 38
same problem please solution....
Old 12-21-2016, 12:40   #8 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 2,102
Its g530H/DS or g530H/DV
Old 01-02-2017, 09:35   #9 (permalink)
randr's Avatar
Member: 73323
Sonork: 1001664281
Thanks Meter: 68
FLASH INSTRUCTIONS:
Operation: Flash
Software version: 27.6
File analysis... Ok
Total file size: 0x569200B0 (1385 Mb)
Searching USB Flash interface... COM22 detected
It looks like you have an unsucessful operation, try this link for solution - inurl:f453 site:http://forum.gsmhosting.com/ "Selected model: SM-G530H" "Setup connection error" - Пошук Google
Done with Samsung Tool PRO v.27.6
Old 02-15-2017, 05:38   #10 (permalink)
Member: 206206
..........................dv...................... ..
Old 02-20-2017, 12:41   #11 (permalink)
Member: 1828796
Sonork: 987656544321
Thanks Meter: 3
Arrow help me
Old 03-18-2017, 16:09   #12 (permalink)
Member: 2325926
Thanks Meter: 10
hey boss same as here whats the ............where is the support..............is there no solution for this??
The Following 2 Users Say Thank You to Abujnispap For This Useful Post:
Old 05-29-2017, 06:39   #13 (permalink)
Fazil's Avatar
Member: 282757
Sonork: 100.1606418
Thanks Meter: 34
pit Partition Problem . . . . No Solution Yet . . .
Old 05-29-2017, 07:55   #14 (permalink)
xerraco's Avatar
Member: 890926
Thanks Meter: 2,053
Put in Recovery Mode, post what FW you have.
Br,
xerraco
Page generated in 0.21217 seconds with 8 queries
