09-27-2017, 23:15 | #1 (permalink) |
Freak Poster Join Date: Jan 2014 Location: pakistan
Member: 2114397 Status: Offline Thanks Meter: 157 | Samsung SM-G928v 7.0 frp [Done] Waiting ADB device... OK Reading phone info... Model: SM-G928V Android version: 7.0 Product code: Not Active Phone version: G928VVRU3CQB9 PDA version: G928VVRU3CQB9 CSC version: G928VVZW3CQB9 CSC country code: USA CSC sales code: VZW HW version: G928V.04 Phone SN: R38G80CW2LB Chip name: EXYNOS7420 Modem board: MDM9635M Security patch: 2017-03-01 RF cal date: 2015.08.09 IMEI: 990005880539755 Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.29.3.1 |
06-29-2018, 21:28 | #4 (permalink) |
Banned Join Date: Jul 2006 Location: dword ptr [ebp-1C], edx
Member: 322417 Status: Offline Thanks Meter: 940 | As final conclusion he is lie and those members should take infraction I download 29.3.1 SamsungTool Pro just to make sure and G928V is not on list What kind of benefits some members has of lie dunno No respect for those members |
The Following 2 Users Say Thank You to Formingus For This Useful Post: |
06-29-2018, 23:00 | #5 (permalink) |
No Life Poster Join Date: Jun 2010 Age: 14
Member: 1315677 Status: Offline Thanks Meter: 1,437 | I red before from you, with adb enabled you don't need any tools. You know the basic commands. Maybe He selected an another model with frp adb method. Tha main problem how he got adb enabled |
The Following User Says Thank You to :Aishur: For This Useful Post: |
06-30-2018, 00:46 | #6 (permalink) | |
Member: 322417 Status: Offline Thanks Meter: 940 | Quote:
2.Phone with open menu I try 90% of things still unable to break frp on g928v | |
07-07-2018, 20:07 | #7 (permalink) | |
After few days of arguing with g928v patch 03.2018 mine personal conclusion is : You can get ADB enabled with fleshing boot.img from combination, but when OEM Lock is enabled phone will hang with loop vibration and yll dont have access to use command to remove FRP , you will get only adb name with "adb devices" command. If you unpack boot.img and modify build.prob repacking will change some offset you will get fail'boot secure when you try to flash. (working on this) Same build.prop is into recovery.img and fota.zip Without modify sboot.bin others 3 are useless because OEM Lock will bypass them Even i get to manage to open menu , settings and rest of it On 7 times build Developer will not be enabled. Every posible code on calculator , dialer , from shortcutmaker and tons of other apk are blocked for enabling adb. So our dear member post is fake 100% (Log can be real because after flashing boot.img and select g928p it will pass via Z3X) but FRP Remain. Developers that has high knowledge of unpacking in Linux, Cygwin , hex-editing can make sboot and boot.img otherwise for me is impossible ATM At last this is mine opinion and others can avoid losing days with g928v patch lvl 03.2018 Last edited by Formingus; 07-07-2018 at 20:12. Reason: Regards | |
The Following User Says Thank You to Formingus For This Useful Post: |
07-25-2018, 16:02 | #9 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Root tunnel Age: 36
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | OP is using eng root, and it will bypass every restriction, useless debate, collect some info before blaming others. |
08-07-2018, 17:57 | #10 (permalink) |
No Life Poster Join Date: Mar 2005 Location: gsmwebstore
Member: 125366 Status: Offline Sonork: 100.1602649 Thanks Meter: 108 | https://www.youtube.com/watch?v=u711IGFbGEk adb file in description Last edited by aukonline; 08-07-2018 at 18:02. |
08-07-2018, 20:41 | #11 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | here the link |
The Following 6 Users Say Thank You to ghacks For This Useful Post: |
11-03-2018, 14:47 | #12 (permalink) |
No Life Poster Join Date: Oct 2010
Member: 1422878 Status: Offline Thanks Meter: 164 | I have a G928V with compilation G928VVRS3CRC1, try to removed frp by UFS UART but the phone is in bootloop only vibrante and restart, when power off only show a Blue led on. How can fix this? BR Last edited by helpinterchange; 11-03-2018 at 14:49. Reason: a |
05-08-2019, 01:14 | #14 (permalink) |
Member: 2114397 Status: Offline Thanks Meter: 157 | Some people try to blaming for nothing they want to get solution by blaming as like mr Formingus .he is dont know anything except the typing bla bla . If someone dont know how to do job he should request to someone that help him to solve his problem. But people not use brain they are use there toungh and try to downgrade to other people who are doing hard working to solve the issues . |
12-14-2019, 02:51 | #15 (permalink) |
Junior Member Join Date: Jul 2017
Member: 2742391 Status: Offline Thanks Meter: 0 | G928v bin 3 frp done TRANSLATE ALL TO ENGLISH HAY DOS VERSIONES QUE ESTAN SOPORTADAS PARA REALIZAR EL FRP G928VVRS3CQI3 G928VVRE3CQB9 SI SU DISPOSITIVO POSEE CUALQUIERA DE ESAS VERSIONES PODRAN REALIZAR EL FRP 1) DESCARGAN ESTE ARCHIVO G928V_VRE3CQB9_ENGROOT.7z BUSCAN ASI EN GOOGLE Y LO DESCARGAN DE ANDROIDFILE HOST 2) FLASHEAN EN LA CASILLA PDA EN Z3X 3) HAY UN PEQUEÑO BUG EN Z3X QUE NO HABILITA LA PESTAÑA ADB Y SE FREEZE EL PROGRAMA. 4) ABREN OCTOPLUS SAMSUNG O OCTOPLUS FRP, SELEECIONAN EL MODELO G928F 5) SELECCIONAN RESET FRP/REACTIVATION, AHORA SELECCIONAN VIA ADB (COMBINATION) Y LE DAN EN ACEPTAR, ACEPTAR Y ACEPTAR Y LISTO |
