07-17-2017, 14:36 | #1 (permalink) |
No Life Poster Join Date: Mar 2015 Location: kapurthala punjab
Member: 2362867 Status: Offline Sonork: ththtuu Thanks Meter: 659 | Samsung SM-G950W Unlock done Unlocking with original MSL code: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will apear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-G950W Software version: 28.7 Checking Login and Password... OK Ballance: 50 crd. Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-G950W Android version: 7.0 Product code: SM-G950WZVAFMC Phone version: G950WVLU1AQDE PDA version: G950WVLU1AQDE CSC version: G950WOYA1AQDE CSC country code: Canada CSC sales code: FMC HW version: REV1.0 Phone SN: R28J41WJERB Chip name: MSM8998 Modem board: MSM8998 Security patch: 2017-04-01 RF cal date: 2017.04.15 IMEI: Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM25 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 51390730 NET lock: 95072530 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.28.7 |
The Following User Says Thank You to sachu2002 For This Useful Post: |
07-17-2017, 16:22 | #2 (permalink) |
Member: 2362867 Status: Offline Sonork: ththtuu Thanks Meter: 659 | Another one UNLOCK INSTRUCTIONS: Unlocking with original MSL code: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will apear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-G950W Software version: 28.7 Checking Login and Password... OK Ballance: 45 crd. Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-G950W Android version: 7.0 Product code: SM-G950WZKAFMC Phone version: G950WVLU1AQEJ PDA version: G950WVLU1AQEJ CSC version: G950WOYA1AQEJ CSC country code: Canada CSC sales code: FMC HW version: REV1.0 Phone SN: R28J525PQAV Chip name: MSM8998 Modem board: MSM8998 Security patch: 2017-05-01 RF cal date: 2017.05.18 IMEI: Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM25 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 27586849 NET lock: 93505790 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.28.7 |
The Following 2 Users Say Thank You to sachu2002 For This Useful Post: |
