Old 10-04-2018, 11:03   #1 (permalink)
Member: 511237
Thanks Meter: 10
samsung SM-G960u qcn file
hello to all if some one need samsung sm g960u qcn file contecto me pv
BACKUP INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information'
to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Read EFS' button to read backup or 'Write EFS' to restore.
To backup/restore QCN, phone diagnostic port must be enabled.
2. Type *#0808# and select 'DM+MODEM+ADB'.
4. Select diagnostic port in port settings.
5. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore.
Operation: Read QCN
Selected model: SM-G960U
Selected port: COM144 SAMSUNG Mobile USB Serial Port
Software version: 33.8
Reading ID... OK
Detected ID: 00000141 (SDM845)
SW version: MPSS.AT.4.0.c2.5-00120-SDM845_GEN_PACK-1.153519.4
Reading ESN... OK
Backuping RFNV... OK
Backuping FeatureMask... OK
Backuping NV Item... OK
Backuping NV Item SIM1... OK
Backuping NV Item SIM2... OK
Backuping Provisioning Item Files... OK
Reading QCN done
Done with Samsung Tool PRO v.33.8
log is here
The Following User Says Thank You to nasir iqbal For This Useful Post:
Old 02-06-2019, 20:46   #2 (permalink)
Member: 1417487
Operation: Read QCN
Reading ID... OK
Reading ESN... OK
Reading QCN done
log is here
Hi is this file still available?
Sent from my SM-G960U using Tapatalk
Old 04-25-2019, 07:54   #3 (permalink)
Member: 2788157
Thanks Meter: 12
used to change imei?
Old 05-16-2019, 18:40   #4 (permalink)
Member: 2691773
Post Samsung g960u pour unlock
Old 05-16-2019, 18:57   #5 (permalink)
Member: 2691773
Old 09-10-2019, 22:59   #6 (permalink)
Member: 73613
Thanks Meter: 7
Hi I need qcn file for network repair. Snk.
Надіслано із мого iPhone за допомогою Tapatalk
Old 10-23-2019, 07:39   #7 (permalink)
Member: 2824153
Thanks Meter: 32
Please how to root device?
Page generated in 0.17804 seconds with 8 queries
