12-04-2016, 10:19 | #1 (permalink) |
No Life Poster Join Date: Feb 2010 Location: Majuro, Marshall Islands
Member: 1227040 Status: Offline Sonork: 100:1654728 Thanks Meter: 55 | Samsung SM-J120A Unlocked Without Root! Android 6.0.1 1. Download this file from downloads section: md5_ATT_ATTFAC_CL8084686_QB9605135_REV00_user_mid_ noship.tar You will get 2 separate files. One is a zip md5 image file and the tar file. 2. Extract the md5 zip and copy the md5.img file and place it in the same folder as your tar file. 3. Use Odin3 v3.10.6 You will have error on first flash. Just remove battery, re-insert and boot back to download mode. If you encounter errors, do the same thing until flashing completes. DO NOT CLOSE ODIN! 4. Phone will boot into what it looks like an engineering mode. Click the dialpad and enter *#0808# and set it to DM+ACM+ADB 5. Open Z3x and select model J120A and read codes! It will take some time but you will get the codes alright. 6. Go back to your Shell and download J120A_UCU1APC8_ATT1APC8.zip. Use odin again to flash back to the normal 6.0.1 firmware. 7. If you want to, you can go ahead and clicke the "FRP Reset" button. I know I did.... hehehehe Searching Samsung modem... detected COM6 Reading phone info... Ok Model: AP version: CSC version: CP version: Product code: Phone SN: Unique number: Reading IMEI... Ok IMEI: XXXXXXXXXXXXXXX (SIGN: OK) Please wait, generating hash codes file, this can take few minutes... Ok Reading data from phone... Ok Modem board: SHANNON308 Checking NV data... Ok Calculating... Ok HWID: A2 65 F7 F0 A3 21 9E E0 A2 F2 B3 83 05 62 92 64 Please wait, calculating codes... OK (time - 00:00:05) Freeze code: 49749028 NET lock: 14293647 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.27.3 Don't forget to set the phone to Developer Mode! GOOD LUCK! |
The Following 5 Users Say Thank You to Jabbacks For This Useful Post: |
12-04-2016, 10:30 | #2 (permalink) |
Member: 1227040 Status: Offline Sonork: 100:1654728 Thanks Meter: 55 | Ah, forgot to tell you.... phone was stuck at the google account set up! I cannot get pass that.... Now I can! Waiting ADB device... Ok Reading phone info... Model: SAMSUNG-SM-J120A Android version: 6.0.1 Product code: SM2J120AZWGATT Phone version: J120AUCU1APE1 PDA version: FA60_J120AUCU1APE1 CSC version: CSC country code: CSC sales code: HW version: REV0.3 Phone SN: R58H54YBY6H Chip name: EXYNOS3475 Modem board: SHANNON308 RF cal date: 20160528 IMEI: Bypass FRP... Ok For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.27.3 |
The Following User Says Thank You to Jabbacks For This Useful Post: |
12-20-2016, 05:58 | #3 (permalink) | |
Junior Member Join Date: Feb 2014
Member: 2133497 Status: Offline Thanks Meter: 1 | Quote:
thanks | |
01-21-2017, 23:05 | #7 (permalink) |
Member: 1227040 Status: Offline Sonork: 100:1654728 Thanks Meter: 55 | Sorry for delay in response. Our underwater fiber optics cable was shut down in islands an entire month. No internet access. Ok, let me see if I can recall the process! First, the files are in Z3x Shell. Flash the md5_ATT_ATTFAC_CL8084686_QB9605135_REV00_user_mid_ noship.tar with Odin. From there, you can access settings so you can set your phone in developer mode. You will see screen is different from the regular firmware. I'm guessing it's the engineering mode. Also, there is a dialpad, enter #*0808#, go to the bottom option... modem/rms/adb (something like that, forgot). Then flash back the original firmware. Flash only the system image. Use Z3x to reset FRP. After that do a full factory reset from phone. Flash back the full firmware! |
04-03-2017, 14:44 | #8 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: INDIA BHUBANESWAR
Member: 641849 Status: Offline Sonork: 100.1619689 Thanks Meter: 44 | Quote:
md5_ATT_ATTFAC_CL8084686_QB9605135_REV00_user_mid_ noship.tar this file is no where found kindly chk | |
The Following User Says Thank You to RICKY great For This Useful Post: |
