Old 10-06-2016, 12:51   #16 (permalink)
Member: 2188828
Sonork: WOW
Thanks Meter: 54
Originally Posted by spawoolm View Post
Thanks for reply,I did it,but nothing.Still FRP is ON!!
I see many people having the same issue,so I think it must be something with the phone,or the combination file...Let's hope that somebody from support sees this and gives a solution...
did id you reset if from setting?
Old 10-07-2016, 12:07   #17 (permalink)
narayan pathak's Avatar
Member: 1864020
Sonork: 100.1624750
Thanks Meter: 44
plz help sm-j510fn frp
I downloaded the combination file (COMBINATION_FA60_J510FNXXU1APC3_CL7514550_QB89918 53_REV00_user_mid_noship_MULTI_CERT.tar.md5),flash ed it via odin PDA,phone starts up in factory mode,Z3x sees the ADB,says FRP unlocked.I make erase all through settings,but FRP still ON...
I also flashed the other file (md5___CL7514550_QB8991853_REV00_user_mid_noship_M ULTI_CERT.tar) then phone FACTORY BINARY plz help
The Following User Says Thank You to narayan pathak For This Useful Post:
Old 10-07-2016, 12:19   #18 (permalink)
Member: 2188828
Sonork: WOW
Thanks Meter: 54
try to flash via other firmware, after unlock it
The Following User Says Thank You to zangoako For This Useful Post:
Old 10-07-2016, 16:01   #19 (permalink)
Member: 1400
Thanks Meter: 77
That's exactly what I have!I will try to flash with another firmware but I think there will be no luck.When booting into download mode the FRP is still ON!!
Old 10-08-2016, 17:05   #20 (permalink)
Member: 2188828
Sonork: WOW
Thanks Meter: 54
write me skype. I will help you
Old 10-08-2016, 20:18   #21 (permalink)
Member: 2188828
Sonork: WOW
Thanks Meter: 54
Is the firmware stock?
Old 02-13-2018, 22:45   #22 (permalink)
Member: 9584
Thanks Meter: 25
i did over reset frp/react/ee it said everthing ok but still frp on. please z3x team find a solution for it
thanks
Searching Samsung USB Flash interface... COM106 detected
Setup connection... OK
Reading PIT from phone... OK
Searching FRP lock... OK
Erasing FRP lock... OK
Reset done
For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset'
Done with Samsung Tool PRO v.30.7
The Following User Says Thank You to darkeye For This Useful Post:
Page generated in 0.25489 seconds with 7 queries
