11-09-2016, 06:21 | #31 (permalink) |
No Life Poster Join Date: Apr 2013 Location: $Kathmandu Nepal$
Member: 1911970 Status: Offline Sonork: 9741081772 Thanks Meter: 2,076 | IMEI 2: 358814073248272 (SIGN: OK) Please wait, generating hash codes file, this can take few minutes... ok Reading data from phone... ok Please wait, calculating codes... OK (time - 00:00:01) Freeze code: 37927039 NET lock: 28196130 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# |
04-30-2017, 13:47 | #33 (permalink) |
Freak Poster Join Date: Jul 2013 Location: Sri lanka-matara
Member: 1989336 Status: Offline Sonork: 100.1652933 Thanks Meter: 13 | j700 unlock done Searching Samsung modem... detected COM57 Reading phone info... Ok Model: SM-J700F AP version: J700FXXS2APE1 CSC version: J700FOJV2APC5 CP version: J700FXXU2APC2 Product code: SM-J700FZKDKSA Phone SN: R28H70AF53P Unique number: CAJ035611EC0463 Reading IMEI... Ok IMEI: 356172078907216 (SIGN: OK) IMEI 2: 356173078907214 (SIGN: OK) Checking hash file... Ok Reading data from phone... Ok Modem board: SHANNON310 HWID: 73 A4 28 CF 89 90 D9 CE 49 17 23 9F 4F 5E 88 23 Reading NV data... Ok Checking NV data... Ok Please wait, calculating codes... OK (time - 00:00:09) Freeze code: 08583863 NET lock: xxxxxxxx SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.28.1 thx z3x team |
11-10-2017, 06:17 | #35 (permalink) |
Insane Poster Join Date: Sep 2010 Location: mumbai Age: 39
Member: 1387849 Status: Offline Sonork: 100.1623264 Thanks Meter: 15 | hello guys i have a problem with sm-j700f 2015 model everything is ok but 4g network not working is very very slw how can i repair 4g network in z3x or octoplus any one can help ? i flashed new firmware from smafirmware.com but still not working imei ok network showing ok evn volte showing 4g showing but not accseable i cant using 4g data speed like 1g speed not 4g plz any one tell me the solution if any one done Thank you gsmfoum! |
07-28-2018, 10:49 | #38 (permalink) |
Junior Member Join Date: Jul 2018
Member: 2848565 Status: Offline Thanks Meter: 1 | hi guys i have J700f which has imei changed problem first i have wrote efs and than write imei with z3x box after that my mobile have network lock im trying to unlock it by z3x box and the result after 10% is: Operation: Read Codes Selected model: SM-J700F Software version: 33.2 Searching Samsung modem... not found Done with Samsung Tool PRO v.33.2 my box cant found my device plsss help me!! |
07-29-2018, 17:06 | #39 (permalink) |
Insane Poster Join Date: Feb 2017 Location: Gazipur
Member: 2680150 Status: Offline Thanks Meter: 10 | UNLOCK INSTRUCTIONS: To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To read security codes via diagnostic port: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes DIAG' button to read security codes. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Unlock Selected model: SM-J700F Software version: 33.2 Waiting ADB device... OK Reading phone info... Model: SM-J700F Android version: 5.1.1 PDA version: J700FXXU1AOJ2 CSC version: J700FOLB1AOJ1 Phone version: J700FXXU1AOJ2 Product code: SM-J700FZKDXME CSC country code: MALAYSIA CSC sales code: XME Phone SN: R28GC230KBL IMEI: 356173072629137 HW version: MP 0.701 RF cal date: 20151215 Chip name: EXYNOS7580 Modem board: SHANNON310 Boot Warranty bit: 1 Checking Super user right... true Reading NV data... OK Checking NV data... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.33.2 |
12-29-2018, 09:33 | #40 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Pako new road,Nepal
Member: 257603 Status: Offline Sonork: 100.1605284 Thanks Meter: 147 | Operation: Unlock Selected model: SM-J700F Software version: 34.6 Waiting ADB device... OK Reading phone info... Model: SM-J700F Android version: 6.0.1 PDA version: J700FXXU4BRA1 CSC version: J700FOJV4BRA1 Phone version: J700FXXU4BQC3 Product code: SM-J700FZKDKSA CSC country code: KSA CSC sales code: KSA Phone SN: RF8H81WZTDF IMEI: 358688074074030 HW version: MP 0.701 RF cal date: 20160819 Chip name: EXYNOS7580 Modem board: SHANNON310 Security patch: 2017-08-01 Boot Warranty bit: 1 SIM State: NOT_READY,NOT_READY Checking Super user right... true Reading NV data... OK Checking NV data... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.34.6 |
01-04-2019, 07:44 | #41 (permalink) |
Junior Member Join Date: Nov 2018
Member: 2878509 Status: Offline Thanks Meter: 0 | sasmung sm-j700f unlock in z3x Samsung SM-J700F Unlock DONE Z3X Operation: Read Codes Selected model: SM-J700F Software version: 22.7 Waiting ADB device... OK Reading phone info... Model: SM-J700F Android version: 5.1.1 Product code: SM-J700FZWDXSG Phone version: J700FXXU1AOFJ PDA version: J700FXXU1AOFJ CSC version: J700FOJV1AOFJ CSC country code: UAE CSC sales code: XSG HW version: MP 0.700 Phone S/N: R28G71QYQBV Modem board: SHANNON310 RF cal date: 20150716 IMEI: Checking Super user right... true Reading nv data... OK OK Please wait, generating hash codes file, this can take few minutes... OK Please wait, calculating codes... OK (time - 00:00:03) Freeze code: 00000000 NET lock: 49053863 Sub lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# |
