03-08-2018, 06:01 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bangladesh
Member: 387110 Status: Offline Sonork: Not Use Thanks Meter: 630 | Samsung SM-J701F unlocking error Code: UNLOCK INSTRUCTIONS: To unlock: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' for direct unlock. Reading codes using sever: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone using sever. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings) Operation: Unlock Selected model: SM-J701F Software version: 30.8 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-J701F Android version: 7.0 Product code: SM-J701FZKDINS Phone version: J701FXXU3ARA6 PDA version: J701FDDU3ARB1 CSC version: J701FODD3ARB1 CSC country code: India CSC sales code: INS HW version: MP 0.400 Phone SN: RF8J8366Z2R Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2018-02-01 RF cal date: 20170826 IMEI: 351569098178477 Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... error (0) Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Initialization data... OK Rebooting phone... OK Waiting ADB device... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... error (1 19) Done with Samsung Tool PRO v.30.8 |
03-08-2018, 06:02 | #2 (permalink) |
No Life Poster Join Date: Apr 2014 Location: B A N G L A D E S H
Member: 2171294 Status: Offline Sonork: 100.1659207(No More Use) Thanks Meter: 706 | Same here, I am also face same problem. Z3x team plz help us |
The Following User Says Thank You to tapas770 For This Useful Post: |
