05-28-2016, 20:55 | #1 (permalink) |
Freak Poster Join Date: Feb 2010
Member: 1231942 Status: Offline Thanks Meter: 19 | samsung sm-n9100 note 4 original write cert problem Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-N9100 Selected port: COM246 SAMSUNG Mobile USB Serial Port Software version: 25.5 Checking certificate file... OK KEY ID: 0065 Waiting ADB device... OK Reading phone info... Model: SM-N9100 Android version: 5.1.1 Product code: SM-N9100ZWUCHC Phone version: N9100ZCU1CPB1 PDA version: N9100ZCS1CPD2 CSC version: N9100CHC1ANIG CSC country code: China CSC sales code: CHC HW version: MP 1.100 Phone S/N: Modem board: MDM9225 RF cal date: 2014.10.29 IMEI: Initialization AT RIL... OK Bypass MSL... error (2) First reset MSL Done with Samsung Tool PRO v.25.5 |
