02-20-2017, 08:26 | #1 (permalink) |
No Life Poster Join Date: Jul 2011 Location: malawi
Member: 1614640 Status: Offline Thanks Meter: 468 | samsung sm n920c cert write done 6.0.1 january 2017 security patch Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Write CERT' to restore certificates. 7. Press 'Write NV DATA' if you need to restore NV backup. Read certificate operation: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read CERT' button to read certificates. Operation: Write CERT Selected model: SM-N920C Software version: 27.7 Waiting ADB device... Ok Reading phone info... Model: SM-N920C Android version: 6.0.1 Product code: SM-N920CZKASER Phone version: N920CXXU3IPIC PDA version: N920CXXS3BQA9 CSC version: N920COXE3BPJ2 CSC country code: Russia CSC sales code: SER HW version: MP 0.900 Phone SN: RF8H70ARKPY Chip name: EXYNOS7420 Modem board: SHANNON333 RF cal date: 20160706 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data from phone... Ok Modem board: SHANNON333 HWID: 18 BE 7F EE 57 04 00 00 00 00 00 00 00 00 00 00 Calculating... Ok Initialization AT RIL... AT RIL stopped, restarting... Ok Checking for compatible phone and cert Phone KEY ID: 0448 Checking certificate file... Ok KEY ID: 0448 Crypting CERT 1... Ok Crypting CERT 2... Ok Writing NV data... Ok Rebooting phone... Ok Write CERT done Done with Samsung Tool PRO v.27.7 |
