Old 05-05-2014, 15:35   #1 (permalink)
Member: 98928
Thanks Meter: 464
Samsung spd e1205y repaired imei ok
after many trays finally done.
you can repair imei by the great z3x very easy steps
1- select E1200I model
2- select AT MODE
3- JUST enter any IMEI you want press repair
4- without battery inside press ok on phone and connect usb cable
after finish this the program will ask to power phone ON
5- now power phone on with battery inside and connect usb cable
you will see success report on z3x
note: never mind if see any error during repair
I THINK THIS WILL HELP MORE PEOPLE LOOKING FOR REPAIR E1205Y IMEI ON Z3X
The Following User Says Thank You to bavesore For This Useful Post:
Old 05-07-2014, 14:07   #2 (permalink)
Member: 1826148
Thanks Meter: 57
but this method did not work with me...it worked untill searching samesung modem then it says did not find the modem...i think it is because of drivers...can u send me the drivers...i already sent you skypian request...thanks in advance...
Old 05-08-2014, 10:44   #3 (permalink)
Member: 349866
Thanks Meter: 2
[image]([url]http://i.hizliresim.com/lY3M0l.jpg)](http://hizliresim.com/lY3M0l[/image]
Old 05-08-2014, 10:48   #4 (permalink)
Member: 349866
Thanks Meter: 2
H?zl? Resim yükle, internette payla? | resim upload | bedava resim
Old 05-08-2014, 10:56   #5 (permalink)
Member: 349866
Thanks Meter: 2
Old 05-08-2014, 10:58   #6 (permalink)
Member: 349866
Thanks Meter: 2
help mi msl bypass flash file problem
Old 05-09-2014, 18:37   #7 (permalink)
Member: 98928
Thanks Meter: 464
br
try unlock your phone first in flash mode
then repair imei in AT mode
good luck
Old 11-05-2014, 12:12   #8 (permalink)
Member: 1712139
Thanks Meter: 2
Samsung e1205y simlock done with Volcano box
the phone was with phone lock, I read flash and it gave phone lock, after insert simcard the phone ask for simlock so i reset phone
Old 11-30-2014, 09:43   #9 (permalink)
Member: 1241196
Sonork: 100.1660453
Thanks Meter: 4
I need drivers man wheres the location for that drivers ....
Help meee guys ...
Old 11-30-2014, 23:45   #10 (permalink)
Member: 2215333
e1205 can't flash
Hello
I tried to make FLASH to E1205Y it does not work, unlock and IMEI change does work.
Happy if you can help!
Thanks ...
Old 12-01-2014, 07:52   #11 (permalink)
Member: 1241196
Sonork: 100.1660453
Thanks Meter: 4
Elirot can u please give me the file of E1205Y,
i got one cellphone and its dead need to flash with new file
thanks and reagardx ..
decent
Old 12-03-2014, 10:39   #12 (permalink)
Member: 98928
Thanks Meter: 464
Originally Posted by elirotnmr01 View Post
Hello
Thanks ...
i don't understand what you need ? if you want flashing your phone just do exactly this steps:
1- select flash file and press flash
2- press ok without battery
3- insert usb cable to phone and re insert your batt
thats it,
Old 12-03-2014, 10:45   #13 (permalink)
Member: 98928
Thanks Meter: 464
decent
the file you looking for is already exist in z3x support
Old 06-19-2015, 09:38   #14 (permalink)
Member: 1925069
Sonork: 1638142;tehmoor
Thanks Meter: 3
Selected model: E1205Y
Selected port: COM6 Z3X BOX Serial Port
Selected port speed: 921600
Waiting phone... detected COM74
Sending FDL... OK
Reconnecting phone... OK
Reading NV... OK
Checking NV... OK
IMEI Master: 357055059031388
Phone HW: MP 0.300
Product code: GT-E1205IBYXFV
Sending NV... OK
Unlock done
Done with Samsung Tool v.19.1
Sending FDL... OK
Reading NV... OK
Checking NV... OK
Phone HW: MP 0.300
Please wait, calculating codes... OK (time - 00:00:37)
For check lock status: *#7465625#
Sending FDL... OK
Reading NV... OK
Checking NV... OK
Phone HW: MP 0.300
Hello sir box say is DoNE but my phone is still show tha simlock!
plx HElp.
thanks is Adv.
Old 10-04-2015, 19:22   #15 (permalink)
Member: 1887781
Unhappy i need help plz
hi all
i need help plz
how to unlock samsung e1205y
Page generated in 0.22485 seconds with 9 queries
