02-21-2018, 05:25 | #1 (permalink) |
No Life Poster Join Date: Oct 2015 Location: Pakistan
Member: 2478233 Status: Offline Thanks Meter: 596 | samsung sph-l720t imei problem it says done but same REPAIR INSTRUCTIONS: 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options', tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Use 'Reset EFS' or 'Reset MSL' functions if you need to reset this values. Be carefully, do not perform this without necessity and make backup before. 'Wipe EFS/NVM': 1. Power on the phone in download mode (turn off phone, hold Volume Down + Home + Power). 2. Connect USB cable, install drivers if needed. 3. Press 'Wipe EFS/NVM' button to deactivate security. 4. Wait till phone reboot. Operation: Repair Selected model: SPH-L720T Selected port: COM74 SAMSUNG Mobile USB Serial Port Software version: 30.8 Waiting ADB device... OK Reading phone info... Model: SPH-L720T Android version: 5.0.1 Product code: Not Active Phone version: L720TVPSCPL1 PDA version: L720TVPSCPL1 CSC version: L720TSPTCPL1 CSC country code: USA CSC sales code: XAS HW version: Phone SN: 00000000000 Modem board: MDM9615M Security patch: 2015-11-01 RF cal date: NONE IMEI: Initialization AT RIL... OK Bypass SPC... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.30.8 |
02-21-2018, 05:59 | #2 (permalink) |
Freak Poster Join Date: Apr 2017 Location: PakisTan
Member: 2705080 Status: Offline Sonork: 100.1679605 Thanks Meter: 41 | after writing imei try to hard reset if same then flash firmware and then repeat these steps again ! IF U LIKE WHAT I POST THEN CLICK THE (THANKS) BUTTON |
