08-30-2011, 10:32 | #1 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Samsung T239 How To Solved Wrong Card With Z3X Box When I Try For Unlock Code: Selected model: T239 Selected com port: COM10 Selected speed port: 230400 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 04 Sending loader2... OK Unlock block Unlock block Unlock block Unlock block Unlock block Unlock block Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 197 second, sw ver: 3.5.0026 ------------------------------------------------------------------------------- Then Full Flash With Firmware Code: Selected model: T239 Selected com port: COM10 Selected speed port: 230400 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 04 Sending loader2... OK Start NOR flash NOR flash - ok Download - ok Elapsed time: 744 second, sw ver: 3.5.0026 ------------------------------------------------------------------------------- Then again Try For Unlock Code: Selected model: T239 Selected com port: COM10 Selected speed port: 230400 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 04 Sending loader2... OK Unlock block Unlock block Unlock block Unlock block Unlock block Unlock block Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 196 second, sw ver: 3.5.0026 ------------------------------------------------------------------------------- But Not Done Unlock Same Condition Wrong Card How To Solved This Problem. |
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post: |
08-30-2011, 10:41 | #2 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Try to read codes & input code #7465625*638*00000000# http://forum.gsmhosting.com/vbb/6118516-post8.html |
The Following User Says Thank You to srinibas For This Useful Post: |
08-30-2011, 10:59 | #3 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | @ srinibas I am Try All Method But Not Done. |
08-30-2011, 11:07 | #4 (permalink) |
No Life Poster Join Date: Mar 2010 Location: south africa Age: 41
Member: 1269056 Status: Offline Thanks Meter: 1,114 | samsung c5130 how to unlock phone lock code i try withe z3x / hwk / nspro all box showing unlock done but still phone lock what can i do.....? |
08-30-2011, 11:37 | #5 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | When Read Info [Codes] Set Unlock is Done . Code: Selected model: T239 Selected com port: COM10 Selected speed port: 460800 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 04 Sending loader2... OK Phone IMEI -> 01189900319981 Phone SW -> Langpack-> Not found langpack ! Phone HW -> Phone BT ADDR -> Phone WI-FI ADDR -> [NET LOCK]:97057590,97057590,97057590,97057590,97057590,97057590,97057590,97057590,97057590,97057590, [SIM LOCK]:00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000, [PHONE LOCK]:00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000, [SP LOCK]:00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000, Read Info - ok Elapsed time: 62 second, sw ver: 3.5.0026 ------------------------------------------------------------------------------- Thanks To all My Set Net Code Mark in Read Colour |
08-30-2011, 11:48 | #6 (permalink) | |
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
That i was told you - http://forum.gsmhosting.com/vbb/7673530-post3.html | |
08-30-2011, 11:51 | #7 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Pakistan Age: 36
Member: 748029 Status: Offline Sonork: 100.1603742 Thanks Meter: 1,822 | I Also Have Same Problem.I Will Try & Post Result. Code: Selected model: T239 Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 04 Sending loader2... OK Phone IMEI -> 01184100441886 Phone SW -> Langpack-> Not found langpack ! Phone HW -> Phone BT ADDR -> Phone WI-FI ADDR -> [NET LOCK]:04237030,04237030,04237030,04237030,04237030,04237030,04237030,04237030,04237030,04237030,04237030,04237030, [SIM LOCK]:00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000, [PHONE LOCK]:00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000, [SP LOCK]:00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000, Read Info - ok Elapsed time: 42 second, sw ver: 3.5.0026 ------------------------------------------------------------------------------- |
08-30-2011, 11:57 | #8 (permalink) |
Member: 748029 Status: Offline Sonork: 100.1603742 Thanks Meter: 1,822 | Phone Unlocked.But Now No Signal. I Think This Phone have 850/1900 Gsm network.Can I Change It With 1800 ?? Can anyone help me ?? B,R. |
08-30-2011, 12:01 | #9 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Hello.................. Now No Network Problem Only Searching Show on Dishplay. Please How to Solve it....................? |
08-30-2011, 12:27 | #10 (permalink) |
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | It works on Band 850, 1900 so need to change it. as i know it is possible & available the solution on Forum , do a little search |
02-14-2012, 03:11 | #15 (permalink) |
No Life Poster Join Date: May 2010 Location: South America Age: 41
Member: 1308889 Status: Offline Sonork: 100.1608156 Thanks Meter: 266 | i can do the unlock of this phone with SGTOOL (this is the samsung tool of LGTool of SEtool), this tool read the unlock code for samsung T239 using read E2P codes action |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
