04-04-2014, 12:11 | #1 (permalink) |
No Life Poster Join Date: Apr 2009 Location: where love is Age: 33
Member: 1002000 Status: Offline Sonork: 100.1604575 Thanks Meter: 90 | samsung t359 unlock |
04-04-2014, 12:21 | #2 (permalink) |
No Life Poster Join Date: Dec 2010 Location: [pujab haryana]
Member: 1481018 Status: Offline Sonork: 100.165460 Thanks Meter: 222 | use com cable samsung T359 unlock done z3x Model: SGH-T359 CountryCode: TMB Factory SW: UVJE1 UniqueNumber: 90620001726988 MemoryPhone: K5W2G1HACF(T359)S IMEI: 35242204xxxxxxx Phone S/N: RP1Z985179 Build: Q6270B-KPVZL-1.5.40T Reading SysInfo... OK Calculating... error Reading SysInfo... OK Calculating codes... OK (time - 00:00:34) Freeze code: 36370850 NET lock: #7465625*638*63807180# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# Multi lock: #7465625*685*12369874# SIM lock: #7465625*746*12369874# For check lock status: *#7465625# Done with Samsung 3G tool ver 9.4 |
04-04-2014, 12:31 | #5 (permalink) |
Member: 1002000 Status: Offline Sonork: 100.1604575 Thanks Meter: 90 | |
04-04-2014, 12:32 | #6 (permalink) |
Member: 1002000 Status: Offline Sonork: 100.1604575 Thanks Meter: 90 | i still face problem i get only this Selected model: T359 Selected port: COM9 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... OK Model: SGH-T359 Country code: ¹Ì±¹/TMB Cal date: 2010-10-06 Factory SW: UVJI2 Unique number: 90510001766781 Memory phone: K5W2G1HACF(T359)S Phone S/N: RQTB742246 Reading IMEI... OK IMEI: 358427040090709 Build: Q6270B-KPVZL-1.5.40T Reading phone version... OK Phone version: T359UVJI2 Reading sysinfo... OK Type *#7465625# and press OK Then repeat procedure Done with Samsung Tool v.17.0 Done with Samsung Tool v.17.0 |
04-05-2014, 12:58 | #8 (permalink) |
Cheater -Don't Deal with him- Join Date: Jan 2012 Location: COOCHBEHAR,WB
Member: 1714311 Status: Offline Sonork: 100.1604096 Thanks Meter: 271 | tell me what problem u faced????????? Type *#7465625# and press OK |
The Following User Says Thank You to <<SAMRAT>> For This Useful Post: |
04-05-2014, 14:55 | #9 (permalink) |
Member: 1002000 Status: Offline Sonork: 100.1604575 Thanks Meter: 90 | finally phone unlocked by the help of samrat singha (********)....phone was put to qualcomm mode by the code *#197328640#.... common/usb configuration/qualcomm mode......then inserted usb cable......select this driver C:\Program Files\Z3X\Samsung\SamsungTool\Drivers\B7320_B7330_ Drivers then select com in 3g tool,then press read codes...phone code readed...now unlocked |
