Old 10-07-2016, 10:09   #1 (permalink)
Member: 2188828
Sonork: WOW
Thanks Meter: 56
Thumbs up Samsung T377A unlock [done]
Operation: Unlock
Selected model: SM-T3777
Software version: 26.9
Searching Samsung modem... detected COM40
Reading phone info... OK
Model: SM-T377A
AP version: T377AUCU1APF1
CSC version: T377AATT1APF1
CP version: T377AUCU1APF1
Product code: SM-T377AZKAATT
Phone SN: R52H705C26Z
Unique number: CAJ030A0EF0CB53
Reading IMEI... OK
IMEI: 353608072208880 (SIGN: OK)
Reading data from phone... OK
Unlocking... OK
Rebooting phone... OK
Unlock done
Done with Samsung Tool PRO v.26.9
The Following 3 Users Say Thank You to zangoako For This Useful Post:
Old 01-03-2017, 11:30   #2 (permalink)
Member: 731353
Thanks Meter: 143
UNLOCK INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Unlock' button for direct unlock.
To read security codes:
2. Connect the phone to PC with USB cable.
3. Check Samsung modem in device manager, install drivers if needed.
4. Press 'Read codes' button to read security codes.
To reset Google account activation or Samsung reactivation lock:
1. ADB must be activated in any way (you can flash sBoot from combination firmware,
make sure, that you are not upgrade sBoot).
2. Connect phone to PC with USB cable, install drivers if needed.
3. Select device in ADB settings.
4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
(Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.)
Operation: Read Codes
Software version: 27.6
Searching Samsung modem... detected COM188
Reading phone info... Ok
Model: SM-T377A
AP version: T377AUCU2APJ2
CSC version: T377AATT2APJ2
CP version: T377AUCU2APJ2
Phone SN: R52H910NFFY
Unique number: CAJ033406B49B93
Reading IMEI... Ok
IMEI: 353608073450267 (SIGN: OK)
Checking hash file... Ok
Reading data from phone... Ok
Modem board: SHANNON308
HWID: 8D 63 82 05 EC A2 70 79 82 59 4D 2B B5 54 67 70
Reading NV data... Ok
Checking NV data... Ok
Calculating... Ok
Please wait, calculating codes... OK (time - 00:00:13)
Freeze code: 16257595
NET lock: 97075825
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
For check lock status: *#7465625#
Done with Samsung Tool PRO v.27.6
Old 03-16-2017, 03:22   #3 (permalink)
Member: 1204194
Thanks Meter: 3
how i can remove the att numbersync from this tablet icant use it like phone because of this function, there is a way to disable it or remove it? thanx its a t377a att 6.0.1
The Following User Says Thank You to xxkrakunxx For This Useful Post:
Old 03-16-2017, 06:14   #4 (permalink)
Member: 1204194
Thanks Meter: 3
double pooooosstt!!!!!
Old 03-24-2017, 16:31   #5 (permalink)
Member: 781439
hello how to root this tab?
Old 03-27-2017, 09:06   #6 (permalink)
Member: 2188828
Sonork: WOW
Thanks Meter: 56
Doesn't need root for unlock
The Following User Says Thank You to zangoako For This Useful Post:
Old 03-27-2017, 16:43   #7 (permalink)
Member: 781439
how to unlock? have z3x
Old 08-02-2017, 15:04   #8 (permalink)
Member: 2556820
Hello, you could remove AT & T NumberSync
Old 08-19-2017, 21:57   #9 (permalink)
Member: 320662
Thanks Meter: 4,294,967,295
Cannot find SM-T377A
Hi there everyone,
I am trying to find a solution to my problem, i got the 29.1 installed but i dont see the SM-T377A model, i can see the SM-T377 /7 /P /T /V /W variants but not the /A, any clue?
I would really appreciate the help.
ps: i understand clearly he said 26.9 but i cannot find it anywhere and i think 29.1 should have everything..... no?
Old 08-23-2017, 08:53   #10 (permalink)
Member: 2188828
Sonork: WOW
Thanks Meter: 56
Originally Posted by xiocer View Post
Hi there everyone,
Choose model SM-T3777. look at my firs post
Old 10-03-2017, 13:18   #11 (permalink)
gsmanam's Avatar
Member: 2581716
Sonork: 30294069
Thanks Meter: 136
Searching Samsung modem... detected COM118
Model: SM-T377A
Phone SN: R52H80G2LQP
Unique number: CAJ036693EE0573
Reading IMEI... OK
IMEI: 353608072896023 (SIGN: OK)
Unlocking... OK
Unlock done
Done with Samsung Tool 29.4
The Following User Says Thank You to gsmanam For This Useful Post:
Old 01-04-2018, 08:18   #12 (permalink)
Crazy Poster
Member: 2161862
Thanks Meter: 7
error
Searching Samsung modem... detected COM94
Model: SM-T377A
Phone SN: R52J7036QLM
Unique number: CAJ0351C9EEBE64
Reading IMEI... OK
IMEI: 359768081745837 (SIGN: OK)
Reading data from phone... error (0)
Try downgrade modem if possible
Done with Samsung Tool PRO v.30.1
The Following User Says Thank You to mohitkhurana93 For This Useful Post:
Old 02-01-2018, 00:59   #13 (permalink)
Member: 2710649
Thanks Meter: 46
Unlock Done with Nougat update
Software version: 30.5
Searching Samsung modem... detected COM56
Model: SM-T377A
AP version: T377AUCU2BQK2
CSC version: T377AATT2BQK2
Product code: ATT
Phone SN: R52H908KFJR
Unique number: CAJ03AA63EA5D83
Reading IMEI... OK
IMEI: 35 (SIGN: OK)
Please wait, generating hash codes file, this can take few minutes... OK
HWID: 48 91 9A 70 9A FF 58 4D 9E 08 E9 A6 27 63 78 12
Reading NV data... OK
Checking NV data... OK
Calculating... OK
Please wait, calculating codes... OK (time - 00:00:00)
Freeze code: 19353174
NET lock: 39035030
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
Done with Samsung Tool PRO v.30.5
Old 02-21-2018, 22:26   #14 (permalink)
CastleSamsung12's Avatar
Member: 2417116
Sonork: 100.1671776
Thanks Meter: 268
Model: SM-T377A
Reading IMEI... OK
Use modem from the Rev 2 Combo and retry. Only extract the modem from the t377a rev 2 combo and flash in CP slot of Odin. It will work then 100%.
Sincerely,
The Cell Magicians
The Following User Says Thank You to CastleSamsung12 For This Useful Post:
Old 02-21-2018, 22:34   #15 (permalink)
Member: 2417116
Sonork: 100.1671776
Thanks Meter: 268
Originally Posted by zangoako View Post
Operation: Unlock
Model: SM-T377A
Reading IMEI... OK
Unlocking... OK
Unlock done
If on revision 2, just extract the rev 2 combination file. In Odin, select the CP slot and select modem.bin extracted from the .tar. This will work, and yes as OG posted, select model T3777 on any Samsung tool pro version past 26.3. For frp removal, unzip the combo and use 7zip to make a tar of the boot.img from the combo, after making just that file a .tar, use same revision important! When tablet boots, select adb and frp reset. Done.
Page generated in 0.38910 seconds with 7 queries
