05-15-2015, 17:08 | #18 (permalink) |
Junior Member Join Date: May 2015
Member: 2394400 Status: Offline Thanks Meter: 0 | Hi, I am having the same problem with this version of samsung. I am using z3x Box to try to write back the original IMEI but it keeps writing the same fake IMEI(350695200123951). I have tried it with both the T-Mobile Firmware and the MetroPCS Firmware. Could you please help me. Thanks. |
05-15-2015, 19:23 | #19 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Cuba Age: 56
Member: 517318 Status: Offline Thanks Meter: 88 | This problem is common on this model, I will explain how to solve this problem. 1- I use this flash T399NUVUANK3_T399NTMBANK3_TMB this on: samfirmware 2- write a backup of a EFS of a T399n working OK. 3- Repair IMEI is written as the backup of EFS 4- Unlock. Phone working OK Last edited by mfeliu07; 05-15-2015 at 19:29. |
05-21-2015, 10:33 | #20 (permalink) | |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | Quote:
Please upload EFS File | |
05-26-2015, 19:14 | #21 (permalink) | |
Member: 2394400 Status: Offline Thanks Meter: 0 | Quote:
Have anyone managed to get this problem solved and working? | |
05-26-2015, 19:44 | #23 (permalink) |
Freak Poster Join Date: May 2007
Member: 511801 Status: Offline Sonork: 100.1590673 Thanks Meter: 46 | if you have t399n t-mobile with no service,although imei and baseband is not corruppted,then in repair tab just fill imei field and use patch certificate tab, all will be ok. I have done T399n with no service today. |
05-26-2015, 22:38 | #24 (permalink) | |
07-24-2015, 16:43 | #26 (permalink) |
Junior Member Join Date: Aug 2006 Location: union st andrew's grenada
Member: 333555 Status: Offline Thanks Meter: 2 | none of these tutorials is not working, i have octoplus and whenever i click repair on imei or unlock the process starts but never finish , the software just stop after a while and nothing happens. if i select repair network everything goes through and the phone restarts but no other option works |
08-27-2015, 16:17 | #27 (permalink) |
Junior Member Join Date: Aug 2015
Member: 2450251 Status: Offline Thanks Meter: 0 | Am having issues, repaired the IMEI successfully to match the one on the sticker after the unlock process made my Generic IMEI the same as everyone elses. Flashed all t-mobile files, modem, code, etc etc, and repaired IMEI, patched certs, and reflashed metroPCS firmware and modem files. Now phone says Unknown for everything, but the IMEI is correct. patching certs doesn't fix the issue. I can't use my phone, help please! |
11-02-2015, 19:01 | #30 (permalink) | |
Member: 517318 Status: Offline Thanks Meter: 88 | Quote:
You do not work you do not mean it is not correct the tutorial, it is more than proved by me in over 80 phones and go to 100%. In some cases it is not necessary to flash, it's just try and fix the problem. Look at Google EFS backup t399N. | |
