11-04-2011, 05:58 | #1 (permalink) |
Freak Poster Join Date: May 2008 Location: Dubai
Member: 778507 Status: Offline Sonork: 100.1640413 Thanks Meter: 265 | Samsung T469w unlock done... Tools: Z3X Samsung E210 combo cable Procedure: Qualcom mode method (only usb): 1. Power on phone. 2. Type *#197328640# -> common -> usb config -> Qualcomm mode 3. Connect USB part of 2in1 cable, setup drivers. 4. Choise qualcomm diagnostic port in port settings. 5. Choise unlock method: Read codes or Unlock. 6. Press Unlock button. after unlock..it only show this code so i enter this code: *#7465625# to the phone and it shows the lock status of the unit.. then tick unlock again...ang then the freeze code shows up... heres how to enter to your phone:
heres the unit: |
The Following 3 Users Say Thank You to aermacchi For This Useful Post: |
11-04-2011, 11:23 | #2 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Punjab(india)
Member: 1206156 Status: Offline Sonork: 100.1606768 Thanks Meter: 111 | thx my bro..my set unlocked in this way also...great yaar.. Count supported models - 260 Searching Samsung USB Modem... Detected (COM30) Model: SGH-T469W SW: T469UQJI2 IMEI: 358624030839042 Model: SGH-T469W Country Code: GLW Factory SW: UQJI2 Unique Number: 55470001193002 Memory Phone: K5R2G1GACC(T469)S Checking Phone On COM7... No Answer Done with Samsung Tool ver 11.4 Searching Samsung USB Modem... Detected (COM30) Model: SGH-T469W SW: T469UQJI2 IMEI: 358624030839042 Model: SGH-T469W Country Code: GLW Factory SW: UQJI2 Unique Number: 55470001193002 Memory Phone: K5R2G1GACC(T469)S Checking Phone On COM28... OK Reading Phone Info... OK Model: SGH-T469W Country Code: GLW Cal Date: 2010-09-14 Factory SW: UQJI2 Unique Number: 55470001193002 Memory Phone: K5R2G1GACC(T469)S Phone S/N: RP6B489666 Build: M6246A-KPVZL-1.2.0035 IMEI: 358624030839042 Done with Samsung Tool ver 11.4 Reading Phone Info... OK Model: SGH-T469W Country Code: GLW Cal Date: 2010-09-14 Factory SW: UQJI2 Unique Number: 55470001193002 Memory Phone: K5R2G1GACC(T469)S Phone S/N: RP6B489666 Build: M6246A-KPVZL-1.2.0035 IMEI: 358624030839042 SW Version: T469UQJI2 Searching SysInfo... OK Reading SysInfo... OK Please Wait, Calculating Codes... OK (time - 00:00:00) For check lock status: *#7465625# Done with Samsung Tool ver 11.4 Reading Phone Info... OK Model: SGH-T469W Country Code: GLW Cal Date: 2010-09-14 Factory SW: UQJI2 Unique Number: 55470001193002 Memory Phone: K5R2G1GACC(T469)S Phone S/N: RP6B489666 Build: M6246A-KPVZL-1.2.0035 IMEI: 358624030839042 SW Version: T469UQJI2 Searching SysInfo... OK Reading SysInfo... OK Please Wait, Calculating Codes... OK (time - 00:00:34) Freeze code: 62073613 NET lock: #7465625*638*60516180# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# Done with Samsung Tool ver 11.4 |
11-13-2011, 01:40 | #3 (permalink) |
Junior Member Join Date: May 2011
Member: 1568856 Status: Offline Thanks Meter: 0 | I have been trying to set up the phone for this method to unlock it but I keep getting a message about "Card not found waiting for connection" when I launch Samsung Tool 11.4. Can this be done with a regular USB cable? Is there some way to get the program to open and see the device? The computer sees the device ok |
11-14-2011, 04:03 | #4 (permalink) | |
Member: 778507 Status: Offline Sonork: 100.1640413 Thanks Meter: 265 | Quote:
bro you need to have a Z3X box to run that software.. thanks, br, Aermacchi | |
02-18-2012, 06:07 | #6 (permalink) |
Junior Member Join Date: Aug 2011
Member: 1628526 Status: Offline Thanks Meter: 3 | I was facing the same problem and tried at least 5 times. and when in job option I checked READ CODE instead of unlock then problem was solved. Reading Phone Info... OK Model: SGH-T469W Country Code: GLW Cal Date: 2010-09-14 Factory SW: UQJI2 Unique Number: 55030001188228 Memory Phone: K5R2G1GACC(T469)S Phone S/N: RQAB290831 Build: M6246A-KPVZL-1.2.0035 IMEI: xxxxxxxxxxxxxxxxxxxx SW Version: T469UQJI2 Searching SysInfo... OK Reading SysInfo... OK Please Wait, Calculating Codes... OK (time - 00:00:42) Freeze code: 84284727 NET lock: #7465625*638*06964060# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# Done with Samsung Tool ver 12.1 |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
