09-23-2017, 10:08 | #62 (permalink) |
Registered User Join Date: Dec 2006 Location: punjab india
Member: 419331 Status: Offline Thanks Meter: 101 | i do write imei g531f but not done see this error REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. Operation: Repair Selected model: SM-G531F Software version: 29.3.1 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... OK Reading phone info... Model: SM-G531F Android version: 5.1.1 Product code: SM-G531FXXXINU Phone version: G531FDDU1AOH1 PDA version: G531FXXU1AOH1 CSC version: CSC country code: CSC sales code: HW version: MP 0.200 Phone SN: RZ8GC0C2V1Y Modem board: RF cal date: 20160801 IMEI: 000000000000000 Checking Super user right... true Reading NV data... OK Analyzing SEC file... error Possible solution: Please send your *_nv_data.bin or *backup.tar file and card SN to [email protected] and don't share your file at public forums Done with Samsung Tool PRO v.29.3.1 i do allso ptach repair done but same problam see this log REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. Operation: Patch Certificate Selected model: SM-G531F Software version: 29.3.1 Waiting ADB device... OK Reading phone info... Model: SM-G531F Android version: 5.1.1 Product code: SM-G531FXXXINU Phone version: G531FDDU1AOH1 PDA version: G531FXXU1AOH1 CSC version: CSC country code: CSC sales code: HW version: MP 0.200 Phone SN: RZ8GC0C2V1Y Modem board: RF cal date: 20160801 IMEI: 000000000000000 Checking Super user right... true Patching CERT check... OK Reading modem... OK Patching modem... skipped Rebooting phone... OK Patching CERT check... done anther cert file write error see this log BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Read CERT' button to read certificates or 'Write CERT' to restore. Operation: Write CERT Selected model: SM-G531F Software version: 29.3.1 Checking CERT file... OK KEY ID: 0001 Waiting ADB device... OK Reading phone info... Model: SM-G531F Android version: 5.1.1 Product code: SM-G531FXXXINU Phone version: G531FDDU1AOH1 PDA version: G531FXXU1AOH1 CSC version: CSC country code: CSC sales code: HW version: MP 0.200 Phone SN: RZ8GC0C2V1Y Modem board: RF cal date: 20160801 IMEI: 000000000000000 Checking Super user right... true Reading NV data... OK Analyzing SEC file... error plz help urgents Last edited by SHARMA NEERAJ; 09-23-2017 at 10:17. |
09-23-2017, 10:52 | #64 (permalink) |
Registered User Join Date: Aug 2007 Location: United Kingdom
Member: 567838 Status: Offline Thanks Meter: 64 | can I please ask a question regarding this latest release if example I have a S7 edge G935F on 7.0 and I wish to do a Imei repair Do I need to root the phone or not ? thankyou |
09-23-2017, 10:58 | #66 (permalink) |
No Life Poster Join Date: Apr 2015 Location: FLORENCE ITALY
Member: 2375239 Status: Offline Sonork: 100.1662985 Thanks Meter: 962 | FIRST IN THE WORLD AGAIN BLAST Z3XBOX G920F ANDROID 7.0 WRITE CERT DONE IMEI REPAIRE DONE NO NEED TO DOWNGRADE MODEM OR ETC BEFORE DO FIRST FLASH WITH THESE FIRMWARES AFTER ROOT PHONE MANUALLY ROOT FILE LINK https://mega.nz/#!eoEHBLhD!t5dwfxi71...TyGKUwlLQCmP48 PASWORD -yeshildostgsm HERE IS LOG Last edited by naveedsialkoti; 09-23-2017 at 11:03. |
The Following 22 Users Say Thank You to naveedsialkoti For This Useful Post: |
09-23-2017, 11:23 | #68 (permalink) |
Junior Member Join Date: Sep 2017 Location: Uk
Member: 2760366 Status: Offline Thanks Meter: 0 | error (0) hi guy's, im abit new to these forums.i need some help plz. i purchased a z3x box few months ago was unlocking fine. now keeps coming up with unlocing....error(0) any help will be much appreciated. thanks |
09-23-2017, 11:51 | #69 (permalink) |
Freak Poster Join Date: Apr 2016 Location: azaz
Member: 2560889 Status: Offline Thanks Meter: 106 | Operation: Patch Certificate Selected model: SM-A710F Software version: 29.3.1 Waiting ADB device... OK Reading phone info... Model: SM-A710F Android version: 7.0 Product code: SM-A710FEDFSER Phone version: A710FXXU2CQDC PDA version: A710FXXU2CQDC CSC version: A710FOXY2CQDC CSC country code: Russia CSC sales code: SER HW version: MP 0.000 Phone SN: RF8HA37Z70L Chip name: EXYNOS7580 Modem board: SHANNON310 Security patch: 2017-04-01 RF cal date: 20161028 IMEI: 3525*********** Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.29.3.1 Android 7.0 patch cert done |
09-23-2017, 12:50 | #75 (permalink) |
Junior Member Join Date: Jun 2017 Location: I LOVE MY INDIA
Member: 2723060 Status: Offline Sonork: I Dont Used Thanks Meter: 17 | Samsung G935f android 7.0 Patch Cert Done In One Click By Z3X Operation: Patch Certificate Selected model: SM-G935F Software version: 29.3.1 Waiting ADB device... OK Reading phone info... Model: SM-G935F Android version: 7.0 Product code: SM-G935FZDUINS Phone version: G935FXXU1DQE7 PDA version: G935FXXS1DQHK CSC version: G935FODD1DQE1 CSC country code: India CSC sales code: INS HW version: MP 0.801 Phone SN: RZ8HXXXX Chip name: EXYNOS8890 Modem board: SHANNON335 Security patch: 2017-08-01 RF cal date: 20160709 IMEI: 3558XXXXXXXX Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Initialization data... OK Writing zTool... OK Initialization zTool... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.29.3.1 |
The Following User Says Thank You to Sab!r Khan For This Useful Post: |
