11-27-2017, 14:12 | #152 (permalink) |
Freak Poster Join Date: Mar 2013
Member: 1908127 Status: Offline Thanks Meter: 14 | can not flash why FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-T580 Software version: 30.0 File analysis... OK Total file size: 0x84D61031 (2125 Mb) Searching USB Flash interface... COM13 detected Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending boot.img... OK Sending recovery.img... error timeout Done with Samsung Tool PRO v.30.0 |
11-27-2017, 14:59 | #153 (permalink) |
Member: 1908127 Status: Offline Thanks Meter: 14 | look blang FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-T580 Software version: 30.1 File analysis... OK Total file size: 0x3F85ADA8 (1016 Mb) Searching USB Flash interface... COM13 detected Setup connection... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending param.bin... error timeout Done with Samsung Tool PRO v.30.1 |
11-27-2017, 16:40 | #154 (permalink) |
Freak Poster Join Date: Feb 2017 Location: Balochistan
Member: 2682425 Status: Offline Thanks Meter: 66 | Nice Update. But Make something easy to use. In future All are going to make service by Only Credits. Ok but make it a bit cheap too for us to use your service. thanks |
11-27-2017, 19:15 | #155 (permalink) | |
Insane Poster Join Date: Aug 2015 Location: Pakistan, Larkana Age: 32
Member: 2446687 Status: Offline Sonork: sarvechali Thanks Meter: 24 | Quote:
add fworlds first update for frp | |
11-27-2017, 20:17 | #156 (permalink) | |
Freak Poster Join Date: Jul 2015
Member: 2428732 Status: Offline Thanks Meter: 22 | Quote:
Model: SM-J727P Android version: 7.0 Product code: Not Active Phone version: J727PVPU2AQI1 PDA version: FA70_J727PVPU2AQI1 CSC version: CSC country code: CSC sales code: HW version: J727P.02 Phone SN: 00000000000 Modem board: MSM8953 Security patch: 2017-01-01 RF cal date: 2017.04.17 IMEI: 35355908xxxxxxx Writing AT RIL... OK Initialization AT RIL... OK Unlocking... OK Rebooting phone... OK Unlock done | |
11-27-2017, 20:24 | #158 (permalink) | |
1- FLASH THE PHONE WITH COMBINATION U2 GOOGLE IT 2- DO THE UNLOCK 3-REFLASH THE PHONE DONE 4- NO NEED FOR ROOT 5 LINK https:// androidfilehost.com/?fid=817906626617947530 [ 11/27/2017 1:04:00 PM ] Waiting ADB device... OK [ 11/27/2017 1:04:00 PM ] Reading phone info... [ 11/27/2017 1:04:00 PM ] Model: SM-J727P [ 11/27/2017 1:04:00 PM ] Android version: 7.0 [ 11/27/2017 1:04:00 PM ] Product code: Not Active [ 11/27/2017 1:04:00 PM ] Phone version: J727PVPU2AQI1 [ 11/27/2017 1:04:00 PM ] PDA version: FA70_J727PVPU2AQI1 [ 11/27/2017 1:04:00 PM ] CSC version: [ 11/27/2017 1:04:00 PM ] CSC country code: [ 11/27/2017 1:04:00 PM ] CSC sales code: [ 11/27/2017 1:04:00 PM ] HW version: J727P.02 [ 11/27/2017 1:04:00 PM ] Phone SN: 00000000000 [ 11/27/2017 1:04:00 PM ] Modem board: MSM8953 [ 11/27/2017 1:04:00 PM ] Security patch: 2017-01-01 [ 11/27/2017 1:04:00 PM ] RF cal date: 2017.04.17 [ 11/27/2017 1:04:00 PM ] IMEI: 3535XXXXXXXX [ 11/27/2017 1:04:00 PM ] Writing AT RIL... OK [ 11/27/2017 1:04:00 PM ] Initialization AT RIL... OK [ 11/27/2017 1:04:00 PM ] Unlocking... OK [ 11/27/2017 1:04:00 PM ] Rebooting phone... OK [ 11/27/2017 1:04:00 PM ] Unlock done | |
11-27-2017, 23:42 | #160 (permalink) |
Crazy Poster Join Date: Feb 2012 Location: Dominical republic
Member: 1722022 Status: Offline Sonork: edward Thanks Meter: 8 | UNLOCK INSTRUCCIONES: Domestic Unlock: 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options', tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock Domestic' button. To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-J727P Software version: 30.1 Waiting ADB device... Por favor, permite la depuración USB en el teléfono... Listo Leyendo información del teléfono ... Modelo: SM-J727P Android version: 7.0 Código del Producto: Not Active Versión del telefono: J727PVPU1AQB8 PDA version: FA70_J727PVPU1AQB5 CSC version: Código de país CSC: Código de Venta CSC: HW version: J727P.02 Phone SN: 00000000000 Módem: MSM8953 Security patch: 2017-01-01 RF cal date: 2017.04.29 IMEI: 353559082556540 Writing AT RIL... Listo Initialization AT RIL... Listo Desbloquear... Listo Reiniciando teléfono ... Listo Desbloqueo Listo Done with Samsung Tool PRO v.30.1 Only need flash a combination file and done |
11-28-2017, 07:39 | #161 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Dhahran ph
Member: 334094 Status: Offline Sonork: none Thanks Meter: 73 | SM-A520F Read unlock Code Working Done............ Operation: Read Codes via Server Selected model: SM-A520F Software version: 30.1 Checking Login and Password... OK Ballance: 45 crd. You have 45 credit(s) left. This opreratin takes 5 credits.Continue? Yes Searching Samsung modem... detected COM53 Reading phone info... OK Model: SM-A520F AP version: A520FXXU2AQG6 CSC version: A520FOJV2AQG1 CP version: A520FXXU2AQF5 Product code: SM-A520FZDDKSA Phone SN: R28J11A14KN Unique number: CBJ106A1BE8ECB3 Searching Samsung diag port... detected COM52 Reading phone info... OK CP version: A520FXXU2AQF5 CP build: Jun 9 2017 13:52:16 Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 50271579 NET lock: 84824629 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# |
11-28-2017, 13:32 | #164 (permalink) |
Freak Poster Join Date: May 2007 Location: Inside You
Member: 513210 Status: Offline Thanks Meter: 110 | Yesterday i have samsung A720f 7.0 version i use to unlock via server but z3x box say" Knox is Void... i cant unlock even if i have server credit So plz ADD Unlock via server even if KNOX VOID... Thanks In Advance Z3x Team... |
11-28-2017, 19:13 | #165 (permalink) |
Insane Poster Join Date: Oct 2016
Member: 2636022 Status: Offline Thanks Meter: 13 | Thank Z3X team...nice update... Waiting ADB device... OK Reading phone info... Model: SM-J727P Android version: 7.0 Product code: Not Active Phone version: J727PVPU1AQB9 PDA version: J727PVPU1AQB9 CSC version: J727PSPT1AQB9 CSC country code: USA CSC sales code: XAS HW version: J727P.02 Phone SN: 00000000000 Modem board: MSM8953 Security patch: 2017-02-01 RF cal date: 2017.06.27 IMEI: Writing AT RIL... OK Initialization AT RIL... root required Checking Super user right... true Initialization AT RIL... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.30.1 |
The Following User Says Thank You to lexisvz For This Useful Post: |
