12-01-2017, 12:22 | #182 (permalink) |
Junior Member Join Date: Jul 2008
Member: 822148 Status: Offline Thanks Meter: 1 | I can't unlock C701F how to unlock it ? UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will apear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Read Codes via Server Selected model: SM-C701F Software version: 30.1 Checking Login and Password... OK Ballance: 31 crd. You have 31 credit(s) left. This opreratin takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-C701F Android version: 6.0.1 Product code: SM-C701FNBDINS Phone version: C701FDDU1AQI4 PDA version: C701FDDU1AQI4 CSC version: C701FODD1AQI4 CSC country code: India CSC sales code: INS HW version: MP 0.101 Phone SN: RZ8JA0V57YF Chip name: MSM8953 Modem board: MSM8953 Security patch: 2017-08-01 RF cal date: 2017.10.11 IMEI: 357169081982904 Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM15 detected Reading data from phone... OK Calculating... error (3) Done with Samsung Tool PRO v.30.1 |
12-01-2017, 17:11 | #187 (permalink) |
Freak Poster Join Date: Oct 2016 Location: SUDAN
Member: 2637339 Status: Offline Thanks Meter: 44 | Operation: Flash Selected model: GT-E1205T Selected port: COM104 Z3X BOX Serial Port, 460800 Software version: 30.1 Connect phone, press power button Waiting phone... OK Sending PRELOADER... OK Flash ID: F8 (Fidelix_FM25M64A) Sending LOADER... OK Checking LOADER... OK Writing BIN... OK Writing LPD... OK Formatting TFS... OK Erasing TFS... OK Checking LOADER... OK Mounting TFS... OK Sending NAND checksum... OK Set time TFS... OK Creating TFS directories... OK Writing TFS VERSION... OK Writing TFS files... OK Unmounting TFS... OK Checking LOADER... OK Formatting CSC... OK Checking LOADER... OK Sending CSC checksum... OK Set time TFS... OK Creating CSC directories... OK Writing CSC files... OK Unmounting CSC... OK Flashing done (time - 00:09:44) Done with Samsung Tool PRO v.30.1 |
12-01-2017, 19:21 | #188 (permalink) |
Junior Member Join Date: Oct 2016 Location: nouvelle aquitaine france
Member: 2635281 Status: Offline Thanks Meter: 5 | in the shell click on parametres then the first choice, propose to watch the updates available or not otherwise it is available here http://z3x-team.com/support_files/ |
12-02-2017, 09:23 | #189 (permalink) |
Junior Member Join Date: Apr 2016
Member: 2558455 Status: Offline Thanks Meter: 6 | Checking Login and Password... OK Ballance: 16 crd. You have 16 credit(s) left. This opreratin takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SAMSUNG-SM-J327A Android version: 7.0 Product code: SM2J327AZSAATT Phone version: J327AUCS1AQJ1 PDA version: J327AUCS1AQJ1 CSC version: J327AATT1AQJ1 CSC country code: USA CSC sales code: ATT HW version: REV0.1 Phone SN: R28J7259S2B Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2017-10-01 RF cal date: 20170718 IMEI: 354775082009142 Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM11 detected Calculating... error (0.2) Done with Samsung Tool PRO v.30.1 |
12-02-2017, 09:50 | #190 (permalink) |
Member: 2558455 Status: Offline Thanks Meter: 6 | now unlocked with diag Checking Login and Password... OK Ballance: 16 crd. You have 16 credit(s) left. This opreratin takes 5 credits.Continue? Yes Searching Samsung modem... detected COM7 Reading phone info... OK Model: SM-J327A AP version: J327AUCS1AQJ1 CSC version: J327AATT1AQJ1 CP version: J327AUCS1AQJ1 Product code: ATT Phone SN: R28J7259S2B Unique number: CQ3003D94D04364 Searching Samsung diag port... detected COM9 Reading phone info... OK CP version: J327AUCS1AQJ1 CP build: Oct 11 2017 11:05:10 Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 04731968 NET lock: 92684296 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.30.1 |
12-02-2017, 14:55 | #191 (permalink) |
Freak Poster Join Date: Feb 2011 Location: Santa Cruz - Bolivia
Member: 1522403 Status: Offline Thanks Meter: 55 | Unlock Note 8 SM-N950F By Z3X PRO +0 5 Creditos 100% Exitoso Knox=0 Thank you z3x pro, the best Unlock Note 8 SM-N950F By Z3X PRO +0 5 Creditos 100% Exitoso Knox=0 done!! https://www.youtube.com/watch?v=5WwPyVj4Zgg |
12-02-2017, 15:25 | #192 (permalink) |
Member: 2637339 Status: Offline Thanks Meter: 44 | thanks z3x team Operation: Reset FRP Selected model: SM-J710F Software version: 30.1 Waiting ADB device... OK Reading phone info... Model: SM-J710F Android version: 6.0.1 Product code: SM-J710FZKDXSG Phone version: J710FXXU1APH4 PDA version: J710FXXU1APLM CSC version: J710FOJV1API1 CSC country code: UAE CSC sales code: XSG HW version: MP 0.400 Phone SN: RF8J30F12XZ Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2016-09-01 RF cal date: 20170304 IMEI: 355615085306849 Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.30.1 |
12-02-2017, 20:03 | #193 (permalink) | |
Freak Poster Join Date: Jun 2009 Location: GV, Brazil
Member: 1064466 Status: Offline Thanks Meter: 34 | Quote:
12-02-2017, 20:33 | #194 (permalink) |
Freak Poster Join Date: Aug 2015 Location: Jamaica
Member: 2450214 Status: Offline Thanks Meter: 106 | J330fn Unlock Problem N.B KNOX WARRANTY VOID I HAVE DONE ONE ALREADY BUT THIS ONE ISNT GOING THROUGH AND IT TOOK MY CREDIT. Waiting ADB device... OK Reading phone info... Model: SM-J330FN Android version: 7.0 Product code: SM-J330FZDNXEF Phone version: J330FNXXU1AQF7 PDA version: J330FNXXU1AQF9 CSC version: J330FNXEF1AQF4 CSC country code: France CSC sales code: XEF HW version: MP 0.500 Phone SN: R58JB00XXX Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2017-06-01 RF cal date: 20171101 IMEI: 35364409309XXXX Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM24 detected Calculating... error (0.0) Done with Samsung Tool PRO v.30.1 |
12-02-2017, 20:44 | #195 (permalink) | |
Member: 2450214 Status: Offline Thanks Meter: 106 | Quote:
J330fn Unlock Problem N.B KNOX WARRANTY VOID I HAVE DONE ONE ALREADY BUT THIS ONE ISNT GOING THROUGH AND IT TOOK MY CREDIT. Waiting ADB device... OK Reading phone info... Model: SM-J330FN Android version: 7.0 Product code: SM-J330FZDNXEF Phone version: J330FNXXU1AQF7 PDA version: J330FNXXU1AQF9 CSC version: J330FNXEF1AQF4 CSC country code: France CSC sales code: XEF HW version: MP 0.500 Phone SN: R58JB00XXX Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2017-06-01 RF cal date: 20171101 IMEI: 35364409309XXXX Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM24 detected Calculating... error (0.0) Done with Samsung Tool PRO v.30.1 | |
