Old 12-07-2017, 11:12   #211 (permalink)
Member: 2223242
Thanks Meter: 2
Thank GOOOOOOOOOOOOOOD
Old 12-07-2017, 11:34   #212 (permalink)
hekmat-safi's Avatar
Member: 961188
Thanks Meter: 38
[ 12/7/2017 3:13:00 PM ] Checking Login and Password... OK
[ 12/7/2017 3:13:00 PM ] Ballance: 50 crd.
[ 12/7/2017 3:13:00 PM ] You have 50 credit(s) left. This opreratin takes 5 credits.Continue? Yes
[ 12/7/2017 3:13:00 PM ] Waiting ADB device... OK
[ 12/7/2017 3:13:00 PM ] Reading phone info...
[ 12/7/2017 3:13:00 PM ] Model: SM-J330F
[ 12/7/2017 3:13:00 PM ] Android version: 7.0
[ 12/7/2017 3:13:00 PM ] Product code: SM-J330FZKDNEE
[ 12/7/2017 3:13:00 PM ] Phone version: J330FXXU1AQF7
[ 12/7/2017 3:13:00 PM ] PDA version: J330FXXU1AQF9
[ 12/7/2017 3:13:00 PM ] CSC version: J330FNEE1AQF2
[ 12/7/2017 3:13:00 PM ] CSC country code: Nordic
[ 12/7/2017 3:13:00 PM ] CSC sales code: NEE
[ 12/7/2017 3:13:00 PM ] HW version: MP 0.400
[ 12/7/2017 3:13:00 PM ] Phone SN: R58J73ACALW
[ 12/7/2017 3:13:00 PM ] Chip name: EXYNOS7570
[ 12/7/2017 3:13:00 PM ] Modem board: SHANNON305
[ 12/7/2017 3:14:00 PM ] Security patch: 2017-06-01
[ 12/7/2017 3:14:00 PM ] RF cal date: 20170718
[ 12/7/2017 3:14:00 PM ] IMEI: 358870080593720
[ 12/7/2017 3:14:00 PM ] Initialization zTool... OK
[ 12/7/2017 3:14:00 PM ] Running zTool, please wait...
[ 12/7/2017 3:14:00 PM ] Start... OK
[ 12/7/2017 3:14:00 PM ] Initialization... OK
[ 12/7/2017 3:14:00 PM ] Generate and check client proof... OK
[ 12/7/2017 3:14:00 PM ] Verify proof by client... OK
[ 12/7/2017 3:14:00 PM ] Reading data from phone... OK
[ 12/7/2017 3:14:00 PM ] Searching Ramdump interface... COM4 detected
[ 12/7/2017 3:15:00 PM ] Calculating... OK
[ 12/7/2017 3:16:00 PM ] Searching server... OK
[ 12/7/2017 3:16:00 PM ] Waiting for server answer
heng on this pleace it tak my 5 credit bout my phone not unlock
Old 12-07-2017, 20:49   #213 (permalink)
Member: 2784591
Thanks Meter: 2
Please add new phone and repair imei
Add this model :sm-g532f repair imei and write imei and patch cert
Old 12-12-2017, 04:39   #214 (permalink)
Member: 1559939
Thanks Meter: 2
for the 520 F Samsung variant knox 01 What it says to me urgent Thanks already find a solutionI wait for this solution for weeks and until now nothing will be very grateful to you no equipment giving solution equal to z3x then please variant knox 1 help please
Old 12-12-2017, 17:59   #215 (permalink)
Member: 1031322
please G900FD Knox 0X1
Old 12-13-2017, 03:22   #216 (permalink)
Member: 2780539
please add support for device unlock app carriers like tmobile and metropcs
Old 12-14-2017, 12:37   #217 (permalink)
Member: 1054358
Sonork: 100.1626312
Thanks Meter: 234
Good Update Z3X
Plasce add S550LT unlock
Old 12-15-2017, 19:52   #218 (permalink)
Member: 2734365
j120m no lo desbloquea la señal esto es lo que dice
Lectura de datos desde el teléfono ... error (0)
Try downgrade modem if possible
Done with Samsung Tool PRO v.29.9
Old 12-15-2017, 21:03   #219 (permalink)
Member: 379023
Thanks Meter: 13
is there a new update up from this version, because im having a trouble unlocking j320zn now...
Old 12-16-2017, 11:32   #220 (permalink)
Member: 1062231
Thanks Meter: 27
PLYZE MR BLANG AJOUTER
UART Cable G610F FRP
Old 12-16-2017, 11:39   #221 (permalink)
Member: 2114706
Thanks Meter: 22
samsung G532F
Hi guys i have SM-G532F .it have 2 sim slots even dual imei written on the back
But inside is only showing 1 imei . i try different method but and get back 2nd sim imei for working . please help Experts team
Old 12-16-2017, 11:52   #222 (permalink)
Member: 1277519
Sonork: 05447112999
:Şaşkın:j510f imei repair
Old 12-18-2017, 15:31   #223 (permalink)
Member: 2166700
Thanks Meter: 12
i feel proud to use z3x. and again great update
Old 12-18-2017, 22:44   #224 (permalink)
Member: 2062154
Sonork: 123321
Thanks Meter: 130
FLASH DON WAITH Z3X
File analysis... OK
Total file size: 0x49531BD8 (1173 Mb)
Searching USB Flash interface... COM52 detected
Setup connection... OK
Reading PIT from phone... OK
Sending oemsbl... OK
Sending appsbl... OK
Sending qcsbl.mbn... OK
Sending qcsblhd_cfgdata.mbn... OK
Sending boot.img... OK
Sending recovery.img... OK
Sending system.img.ext4... OK
Sending userdata.img.ext4... OK
Sending persist.img.ext4... OK
Sending fat.bin... OK
Sending cache.img.ext4... OK
Sending hidden.img.ext4... OK
Flashing done (time - 00:10:33)
Done with Samsung Tool PRO v.30.1
Old 12-19-2017, 13:29   #225 (permalink)
Member: 154448
Sonork: not yet
Thanks Meter: 22
j330fn unlock done
UNLOCK INSTRUCTIONS:
Unlocking with original MSL code:
Warning! Knox warranty must be active (0x00)!
If you have it voided (0x01(void)), then you can't unlock this phone with MSL.
1. Phone must be powered on.
2. Type *#0808# and select 'DM+ACM+ADB'.
3. Run dialer and type *#0*# (service mode will apear).
4. Connect the phone to USB cable, choose correct COM port in port settings.
5. Press 'Unlock' button.
6. Paste MSL code in new opened window and press 'OK'.
Reading codes using sever ('Diag' algo):
If you have it voided (0x01(void)), then you can't unlock this phone using sever.
1. Power on the phone.
2. Type *#0808# and select 'DM+MODEM+ADB'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Press 'Read Codes via server' button, select 'Diag', write your login and password in window if it will apear.
(Login and password will be saved as default after first input and can be changed in settings)
Reading codes using sever ('Upload' algo):
Knox warranty does not matter.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
4. Select device in ADB settings.
5. Press 'Read Codes via server' button, select 'Upload' write your login and password in window if it will apear.
(Login and password will be saved as default after first input and can be changed in settings.)
Operation: Read Codes via Server
Selected model: SM-J330FN
Software version: 30.1
Ballance: 50 crd.
Searching Samsung modem... detected COM263
Reading phone info... OK
Model: SM-J330FN
AP version: J330FNXXU1AQF9
CSC version: J330FNXEF1AQF4
CP version: J330FNXXU1AQF7
Product code: XEF
Phone SN: R58J93*****
Unique number: CQE003F45E0****
Searching Samsung diag port... detected COM264
CP build: Jun 15 2017 15:50:55
Calculating... OK
Waiting for server answer... OK
Freeze code: 1817****
NET lock: 6902****
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
For check lock status: *#7465625#
The Following User Says Thank You to zouhir For This Useful Post:
Page generated in 0.38647 seconds with 8 queries
