Ballance: 40 crd. You have 40 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... Please, allow USB debugging on phone... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-N950U Android version: 7.1.1 Product code: SM-N950UZKATMB Phone version: N950USQU2BQJA PDA version: N950USQU2BQJA CSC version: N950UOYN2BQJA CSC country code: USA CSC sales code: TMB HW version: REV1.0 Phone SN: R28JA0ZN5TZ Chip name: MSM8998 Modem board: MSM8998 Security patch: 2017-10-01 RF cal date: 2017.10.14 IMEI: 358505083XXXXX Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting to upload... OK Searching Ramdump interface... COM17 detected Reading data from phone... error (3.210) Done with Samsung Tool PRO v.30.4 :'( all phones i connect is either ztool error or reading data at around 30% of reading |
Try use other pc. try other cable original. |
USERID: zsc_IWlDFqsB Checking Login and Password... OK Ballance: 10 crd. You have 10 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-J727T Android version: 7.0 Product code: SM2J727TZDATMB Phone version: J727TUVU1AQD7 PDA version: J727TUVU1AQD7 CSC version: J727TTMB1AQD7 CSC country code: USA CSC sales code: TMB HW version: REV0.7 Phone SN: R28J93CTMMD Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-04-01 RF cal date: 20170926 IMEI: 355620084399274 Searching Samsung diag port... detected COM1089 Reading phone info... OK CP version: J727TUVU1AQD7 CP build: Apr 18 2017 18:32:27 Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.30.4 still locked.. i will reflash stock firmware |
UNLOCK INSTRUCTIONS: Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Unlock Selected model: SM-G360T Software version: 30.4 Checking Login and Password... OK Ballance: 50 crd. You have 50 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G360T Android version: 5.1.1 Product code: SM2G360TZWWTMB Phone version: G360TUVU1AOF9 PDA version: G360TUVU1AOF9 CSC version: G360TTMB1AOF9 CSC country code: USA CSC sales code: TMB HW version: REV0.1 Phone SN: R58H22MPPDP Chip name: MSM8916 Modem board: MSM8916 RF cal date: 2016.02.26 IMEI: 354335075603656 Checking Super user right... true Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting to upload... OK Searching Ramdump interface... COM42 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.30.4 |
all will work. some time need repeat 2 times. we improve server litle to avoid duplicate credits using. so just repeat. |
excellent update UNLOCK INSTRUCTIONS: To unlock: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings) To reset Pattern lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset Pattern Lock' button. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' to deactivate Google account activation lock. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-G935T Software version: 30.4 Checking Login and Password... OK Ballance: 10 crd. You have 10 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G935T Android version: 7.0 Product code: SM-G935TZDATMB Phone version: G935TUVS4BQC1 PDA version: G935TUVS4BQC1 CSC version: G935TTMB4BQC1 CSC country code: USA CSC sales code: TMB HW version: REV0.7 Phone SN: RF8H423B3FH Chip name: MSM8996 Modem board: MSM8996 Security patch: 2017-03-01 RF cal date: 2016.04.20 IMEI: 356164072721008 Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting to upload... OK Searching Ramdump interface... COM44 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.30.4 |
need support for lg phones t mobile app unlock. great update |
fake unlock j327t1 [ 08/01/2018 17:13:00 ] Waiting ADB device... Listo [ 08/01/2018 17:13:00 ] Leyendo información del teléfono ... [ 08/01/2018 17:13:00 ] Modelo: SM-J327T1 [ 08/01/2018 17:13:00 ] Android version: 7.0 [ 08/01/2018 17:13:00 ] Código del Producto: SM2J327TZKATMK [ 08/01/2018 17:13:00 ] Versión del telefono: J327T1UVU1AQK6 [ 08/01/2018 17:13:00 ] PDA version: J327T1UVU1AQK6 [ 08/01/2018 17:13:00 ] CSC version: J327T1TMK1AQK6 [ 08/01/2018 17:13:00 ] Código de país CSC: USA [ 08/01/2018 17:13:00 ] Código de Venta CSC: TMK [ 08/01/2018 17:13:00 ] HW version: REV0.1 [ 08/01/2018 17:13:00 ] Phone SN: RV8J91XKPXD [ 08/01/2018 17:13:00 ] Chip name: EXYNOS7570 [ 08/01/2018 17:13:00 ] Módem: SHANNON305 [ 08/01/2018 17:14:00 ] Security patch: 2017-11-01 [ 08/01/2018 17:14:00 ] RF cal date: 20170928 [ 08/01/2018 17:14:00 ] IMEI: 352001092656331 [ 08/01/2018 17:14:00 ] Searching Samsung diag port... detectado COM66 [ 08/01/2018 17:14:00 ] Leyendo información del teléfono ... Listo [ 08/01/2018 17:14:00 ] CP version: J327T1UVU1AQK6 [ 08/01/2018 17:14:00 ] CP build: Nov 20 2017 14:50:17 [ 08/01/2018 17:14:00 ] Lectura de datos desde el teléfono ... Listo [ 08/01/2018 17:15:00 ] Calculando... Listo [ 08/01/2018 17:16:00 ] Buscando servidor... Listo [ 08/01/2018 17:16:00 ] Waiting for server answer... Listo [ 08/01/2018 17:16:00 ] Waiting ADB device... Listo [ 08/01/2018 17:16:00 ] Initialization zTool... Listo [ 08/01/2018 17:16:00 ] Running zTool, please wait... [ 08/01/2018 17:16:00 ] Start... Listo [ 08/01/2018 17:16:00 ] Initialization... Listo [ 08/01/2018 17:16:00 ] Generate and check client proof... Listo [ 08/01/2018 17:16:00 ] Verify proof by client... Listo [ 08/01/2018 17:16:00 ] Lectura de datos desde el teléfono ... Listo [ 08/01/2018 17:16:00 ] Reiniciando teléfono ... Listo [ 08/01/2018 17:16:00 ] Desbloqueo Listo It's still blocked, it used up the credits and nothing. please help. Thank you |
my samsung j327t1 locked and also frp lock will server unlock clear the frp lock also? |
Imei repair removed for many phones, no option to repair imei..why sir??? |
Pls I want to unlock Samsung g360t b4 the unlock could finish the box got disconnected and has already take credit and phone isn't unlock I had to unlock again and phone take another credit this is my login zsc_xxz4blly |
Lettest version have This Bug please Fix This ( G532F ) Code: [ 1/11/2018 8:31:00 PM ] Operation: Read Codes |
