01-08-2018, 20:26 | #136 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,551 | Quote:
if any problem with credits balance send email to: sales @z3x-team.com with 1. logs. 2. login. 3. SN of phones. 4. details about problem. | |
01-09-2018, 01:15 | #137 (permalink) |
Freak Poster Join Date: Jul 2012
Member: 1787478 Status: Offline Thanks Meter: 22 | I have no network connexion in G930T1 after unlocking with z3x I"ve flashed phone after, with combination, full flash but still no network connexion What"s the problem please ? |
01-09-2018, 10:22 | #141 (permalink) |
Junior Member Join Date: Aug 2016 Location: china
Member: 2613578 Status: Offline Sonork: na Thanks Meter: 4 | Searching Samsung modem... detected COM89 Reading phone info... OK Model: SM-G955N AP version: G955NKSU1AQL3 CSC version: G955NOKR1AQL3 CP version: G955NKOU1AQL1 Product code: SKC Phone SN: R39J50544V Unique number: CE041714ED63B30F04 Searching Samsung diag port... detected COM90 Reading phone info... OK CP version: G955NKOU1AQL1 CP build: Dec 4 2017 16:59:36 Reading data from phone... error (4) Done with Samsung Tool PRO v.30.4 |
01-09-2018, 15:12 | #146 (permalink) |
Junior Member Join Date: Jul 2014
Member: 2225667 Status: Offline Thanks Meter: 4 | to mohmedfouad Mr. Blang post it more 40-50 times what to do if you get problem with unlock... just search backward and you see the solution... and after you get back your credicts make a hard reset and try again... for me works perfect. |
01-09-2018, 16:46 | #147 (permalink) |
Freak Poster Join Date: Nov 2006 Location: Santo domingo norte villa mell
Member: 398011 Status: Offline Thanks Meter: 25 | This tells me that if it was made but the unlocking did not work UNLOCK INSTRUCCIONES: Warning! Knox warranty must be active (0x00)! 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Type *#0808# and select 'DM + MODEM + ADB' (or 'DM + ACM + ADB'). 4. Connect the phone to PC with USB cable, install drivers if needed. 5. Select device in ADB settings. 6. Press 'Unlock TMB via Server' button for direct unlock, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings) Operation: Unlock Selected model: SM-J727T1 Software version: 30.4 Checking Login and Password... Listo Ballance: 10 crd. You have 10 credit(s) left. This operation takes 10 credits.Continue? Si Waiting ADB device... Listo Leyendo información del teléfono ... Modelo: SM-J727T1 Android version: 7.0 Código del Producto: SM2J727TZDATMK Versión del telefono: J727T1UVU1AQK8 PDA version: J727T1UVU1AQK8 CSC version: J727T1TMK1AQK8 Código de país CSC: USA Código de Venta CSC: TMK HW version: REV0.7 Phone SN: R58JB12A4VR Chip name: EXYNOS7870 Módem: SHANNON315 Security patch: 2017-12-01 RF cal date: 20171107 IMEI: 351808090317265 Searching Samsung diag port... detectado COM113 Leyendo información del teléfono ... Listo CP version: J727T1UVU1AQK8 CP build: Nov 24 2017 17:24:45 Lectura de datos desde el teléfono ... Listo Calculando... Listo Buscando servidor... Listo Waiting for server answer... Listo Waiting ADB device... Listo Initialization zTool... Listo Running zTool, please wait... Start... Listo Initialization... Listo Generate and check client proof... Listo Verify proof by client... Listo Lectura de datos desde el teléfono ... Listo Reiniciando teléfono ... Listo Desbloqueo Listo Done with Samsung Tool PRO v.30.4 |
01-09-2018, 17:22 | #148 (permalink) |
Member: 2225667 Status: Offline Thanks Meter: 4 | for octopus82 and betina First i guess is not the fault of Z3X team that maybe the IMEI is BAD it's that the case the box made its work... the problem is then blacklist. Second Betina, did you did a hard reset before to try unlock? and for refund just search backward and you see the solution public by Mr. Blang... |
01-09-2018, 19:03 | #150 (permalink) | |
Use english: 1. phone SN. 2. log related to phone. 3. login where credits has taken. 4. details about problem* email: [email protected] | |
