03-28-2016, 10:03 | #18 (permalink) |
No Life Poster Join Date: May 2013 Location: Far From Home..:(
Member: 1948608 Status: Offline Thanks Meter: 1,744 | Add DRK & Add Samsung ENABLE USB Debug option for MOST Samsung Phones.to Remove Pattern Lock,User Code,Screen Lock without getting Lost Data. |
The Following User Says Thank You to -Mosin- For This Useful Post: |
03-28-2016, 10:17 | #20 (permalink) | |
No Life Poster Join Date: Feb 2015 Location: IRAN-TABRIIZ
Member: 2339474 Status: Offline Sonork: 100.1662352 Thanks Meter: 332 | hi mr blang Quote:
do your team working for patch certs! or stopped! only yes/no thnaks | |
The Following User Says Thank You to metalgold23 For This Useful Post: |
03-28-2016, 10:43 | #24 (permalink) |
No Life Poster Join Date: Jun 2011 Location: Kabul City Afghanistan Age: 38
Member: 1600947 Status: Offline Sonork: 100.1627298 Thanks Meter: 772 | Great update you are the best team in the world please add FRP for new 2016 model and unlock for G360t and unlock without Root for all model thanks in advance |
The Following 3 Users Say Thank You to abdulhaq_majroh For This Useful Post: |
03-28-2016, 10:44 | #25 (permalink) |
Freak Poster Join Date: Jan 2011 Location: bangladesh
Member: 1483660 Status: Offline Sonork: 100.1601918 Thanks Meter: 155 | J7 Reset FRP add pls UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP/React/EE Selected model: SM-J700H Software version: 25.0 Searching Samsung USB Flash Interface... detected COM103 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... error Done with Samsung Tool PRO v.25.0 Last edited by trmobile2; 03-28-2016 at 10:49. |
