04-21-2016, 01:53 | #121 (permalink) | ||
No Life Poster Join Date: Jan 2005 Location: the earth Age: 41
Member: 103024 Status: Offline Thanks Meter: 616 | g925 security damaged (1) after reset efs cannot write cert , still security damaged (1) here is the log with new version ( fail ) Quote:
here is the succes log with old version Quote:
04-21-2016, 17:03 | #122 (permalink) |
Freak Poster Join Date: Feb 2016
Member: 2526783 Status: Offline Thanks Meter: 22 | Sm-g928t reactivation lock removal failed I was unable to remove the reactivation lock from the s6 edge (g928t). Operation: Reset FRP/React/EE Selected model: SM-G928T Software version: 25.1 Searching Samsung USB Flash Interface... detected COM12 Setup connection... OK Reading PIT from phone... error Done with Samsung Tool PRO v.25.1 |
04-21-2016, 21:34 | #125 (permalink) |
Registered User Join Date: Aug 2007 Location: bohol philippines Age: 42
Member: 572549 Status: Offline Thanks Meter: 175 | G531h/ds Searching Samsung USB Flash Interface... detected COM12 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... error |
The Following User Says Thank You to T0T0 For This Useful Post: |
04-22-2016, 19:06 | #129 (permalink) |
Junior Member Join Date: Nov 2012 Location: Ishwargonj, Mymenshingh
Member: 1844713 Status: Offline Sonork: [email protected] Thanks Meter: 4 | Need Samsung Virus remove option on Z3x. Please add It.. |
04-23-2016, 08:43 | #130 (permalink) |
Freak Poster Join Date: Jun 2007 Location: OUT OF CONTROL
Member: 536012 Status: Offline Sonork: 100.1660617 Thanks Meter: 120 | Problem Unlock SM-E700h 5.1.1 Phone is Rooted No ADB Option present in Unlock Tab.only present COM Port Setting. but I found this in Old SamsungTool_pro_21.5,but unlock failed,may be some issue with 5.1.1. Code: UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', enable 'USB debugging' in 'Settings'-'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SM-E700H Selected port: COM11 Z3X BOX Serial Port Software version: 25.1 Reading phone info... no answer from phone Done with Samsung Tool PRO v.25.1 |
06-23-2016, 00:14 | #131 (permalink) |
Junior Member Join Date: Nov 2009
Member: 1150867 Status: Offline Sonork: kurt285 Thanks Meter: 5 | Waiting ADB device... OK Reading phone info... Model: SM-G928T Android version: 6.0.1 Product code: SM2G928TZDETMB Phone version: G928TUVU2DPD1 PDA version: G928TUVU2DPD1 CSC version: G928TTMB2DPD1 CSC country code: USA CSC sales code: TMB HW version: REV1.0 Phone S/N: R58GB1HCCXT Modem board: SHANNON333 RF cal date: 20151114 IMEI: Checking Super user right... true Initialization AT RIL... Exception: Access violation at address 004074E0 in module 'SamsungToolPRO.exe'. Read of address 00000000 Done with Samsung Tool PRO v.24.3 i have the same problem too.. Can somebody help me please? I would greatly appreciate it! |
06-23-2016, 01:49 | #132 (permalink) | |
Junior Member Join Date: Apr 2014
Member: 2163241 Status: Offline Thanks Meter: 1 | Quote:
Might be your problem solved Sent from my SM-E700H using Tapatalk | |
