01-04-2017, 18:10 | #256 (permalink) |
Major Poster Join Date: Sep 2015 Location: usa
Member: 2455740 Status: Offline Thanks Meter: 0 | Searching server... Ok Compare local and server file... OK (up to date) Searching USB Flash interface... COM6 detected Setup connection... Ok Reading data from phone... Ok Sending data to phone... Ok Sending data to phone... Ok Waiting ADB device... Ok Reading phone info... Recovery build version: 6.0.1 Boot version: G920TUES5DPI2 Platform: exynos7420 Boot serial: 06157df628e00b03 Product board: zerolte Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Checking DRK status... NG! Writing DRK... error (error(5.6.-14)) Done with Samsung Tool PRO v.27.7 please help figure the issue i been try to fix drk for more than 3 days |
01-17-2017, 20:04 | #257 (permalink) |
Freak Poster Join Date: Jun 2008 Location: albania
Member: 787088 Status: Offline Thanks Meter: 22 | Checking local file... Ok Searching server... Ok Compare local and server file... OK (up to date) Searching USB Flash interface... COM12 detected Setup connection... Ok Reading data from phone... Ok Sending data to phone... Ok Sending data to phone... Ok Waiting ADB device... Ok Reading phone info... Recovery build version: 6.0.1 Boot version: FA60_G930FXXU1APB4 Platform: exynos5 Boot serial: 9885b549374a314751 Product board: universal8890 Initialization zTool... error (0) Done with Samsung Tool PRO v.27.7 ned help me pls i flash but not work please help me |
02-22-2017, 23:48 | #258 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: CAIRO Age: 37
Member: 237684 Status: Offline Thanks Meter: 66 | Quote:
and COMBINATION_FA51_N920CXXU3API1_CL6352757_QB1080327 9_REV00_user_mid_noship. whats now please | |
04-18-2017, 16:22 | #259 (permalink) |
Junior Member Join Date: Aug 2010 Location: south africa
Member: 1367882 Status: Offline Sonork: 0027727221786 Thanks Meter: 1 | need help samsung G925F drk repair Operation: Repair DRK Selected model: SM-G925F Software version: 28.1 Checking local file... not found Searching server... not found Done with Samsung Tool PRO v.28.1 |
06-24-2017, 16:01 | #262 (permalink) |
Freak Poster Join Date: Apr 2011 Location: Armenia Yerevan
Member: 1559514 Status: Offline Thanks Meter: 49 | Checking DRK status... NG! Writing DRK... error (error(5.6.-14) write correct efs adn after do drk repair. i'm solved this problem from this method! Checking local file... Ok Searching server... Ok Compare local and server file... OK (up to date) Searching USB Flash interface... COM5 detected Setup connection... Ok Reading data from phone... Ok Sending data to phone... Ok Sending data to phone... Ok Waiting ADB device... Ok Reading phone info... Recovery build version: 6.0.1 Boot version: G925IDVS3EPC1 Platform: exynos7420 Boot serial: 1015fa89a4803805 Product board: zerolte Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Checking DRK status... NG! Writing DRK... Ok Checking DRK status... Repairing DMVT key... Ok Rebooting phone... Ok Repair DRK done Done with Samsung Tool PRO v.28.2 |
09-11-2017, 09:07 | #265 (permalink) |
Junior Member Join Date: Aug 2008
Member: 832152 Status: Offline Sonork: 1897 Thanks Meter: 3 | Operation: Repair DRK Selected model: SM-J200G Software version: 29.2 Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash interface... COM77 detected Setup connection... OK Reading data from phone... OK Sending data to phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Recovery build version: 5.1.1 Boot version: J200GDDU2APJ1 Platform: exynos3475 Boot serial: 4200e4aee0964253 Product board: j2lte Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Checking DRK status... NG! Writing DRK... error (error(5.6.-13)) Done with Samsung Tool PRO v.29.2 solution pls? |
11-01-2017, 17:50 | #266 (permalink) |
Junior Member Join Date: Oct 2007
Member: 604981 Status: Offline Thanks Meter: 5 | Solution pls!! REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on the phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Repair DRK Selected model: SM-G928F Software version: 29.6 Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash interface... COM10 detected Setup connection... OK Reading data from phone... OK Sending data to phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Recovery build version: 6.0.1 Boot version: G928FXXU3CQH6 Platform: exynos7420 Boot serial: 836f39574b443851 Product board: zenlte Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Checking DRK status... NG! Writing DRK... error () Done with Samsung Tool PRO v.29.6 |
