04-23-2016, 12:53 | #32 (permalink) |
No Life Poster Join Date: Nov 2005
Member: 201840 Status: Offline Thanks Meter: 55 | g920 repair drk Checking Recovery file... OK Searching USB Flash Interface... detected COM8 Setup connection... OK Reading data from phone... OK Sending data to phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Android version: 6.0.1 Boot version: G920FXXU3DPBG Platform: exynos7420 Boot serial: 04157df4c18a1940 Product board: zerolte Initializating zTool... OK Running zTool, please wait... Start... OK Init... OK Generate and check client proof... OK Verify proof by client... OK Checking DRK status... NG! Writing DRK... OK Checking DRK status... Repairing DMVT key... OK Rebooting phone... OK Repair DRK done Done with Samsung Tool PRO v.25.2 |
04-23-2016, 13:51 | #35 (permalink) |
Insane Poster Join Date: Sep 2012
Member: 1813698 Status: Offline Thanks Meter: 8 | UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset Pattern Lock Selected model: SM-N920C Software version: 25.2 Checking Recovery file... OK Searching USB Flash Interface... detected COM5 Setup connection... OK Reading data from phone... OK Sending data to phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Android version: 6.0.1 Boot version: N920CXXU2BPCD Platform: exynos7420 Boot serial: 06157df630f82c3f Product board: zenlte Erasing locks... OK Rebooting phone... OK Reset locks done Done with Samsung Tool PRO v.25.2 Reset screen lock n920c android 6 but after job done reset on logo ... |
04-23-2016, 13:59 | #37 (permalink) |
Freak Poster Join Date: May 2008 Location: dominican republic Age: 37
Member: 764375 Status: Offline Sonork: 100.1676405 Thanks Meter: 23 | please help me Operation: Repair DRK Selected model: SM-G920P Selected port: COM1 Communications Port Software version: 25.2 Checking Recovery file... OK Searching USB Flash Interface... detected COM8 Setup connection... OK Reading data from phone... OK Sending data to phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Android version: 6.0.1 Boot version: G920PVPU3BOI1 Platform: exynos7420 Boot serial: 05157df56032e514 Product board: zerolte Initializating zTool... OK Running zTool, please wait... Start... OK Init... OK Generate and check client proof... OK Verify proof by client... OK Checking DRK status... NG! Writing DRK... error (error(5.6.1)) Done with Samsung Tool PRO v.25.2 |
04-23-2016, 13:59 | #38 (permalink) |
No Life Poster Join Date: Jun 2008 Location: dunja
Member: 786607 Status: Offline Thanks Meter: 66 | frp s6 no possible why UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP/React/EE Selected model: SM-G920F Software version: 25.2 Searching Samsung USB Flash Interface... detected COM10 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... error Done with Samsung Tool PRO v.25.2 |
The Following 2 Users Say Thank You to manule For This Useful Post: |
04-23-2016, 14:15 | #40 (permalink) |
Junior Member Join Date: Apr 2015 Location: ecuador
Member: 2384175 Status: Offline Thanks Meter: 0 | Flashing please J111 unlocking , Unlock , Read codes , Read / Write EFS , Read / Write CERT , reboot to download / Recovery , Repair DRK , Reset screen locks nesesito that model is not supported thanks |
04-23-2016, 14:50 | #43 (permalink) |
Freak Poster Join Date: Jun 2011
Member: 1596886 Status: Offline Thanks Meter: 7 | HELLO FRIENDS forum.gsmhosting.com WANT beware NOTIFY THIS UPDATE Z3X DOWN THE LOG OF MY TELEPHONE S6 * NO REMEDY THE DRK BUT MAKE THE BOOT BOOOM TOUCH LCD DISPLAY PROBLEM Reversed TOUCH If we press the call icon, is pushed OTHER SIDE OF DISPLAY Operation: Repair DRK Selected model: SM-G920I Software version: 25.2 Checking Recovery file... OK Searching USB Flash Interface... detected COM21 Setup connection... OK Reading data from phone... OK Sending data to phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Android version: 6.0.1 Boot version: G920IDVU3DOJ6 Platform: exynos7420 Boot serial: 04157df475b21539 Product board: zerolte Initializating zTool... OK Running zTool, please wait... Start... OK Init... OK Generate and check client proof... OK Verify proof by client... OK Checking DRK status... NG! Writing DRK... error (error(5.6.1)) Done with Samsung Tool PRO v.25.2 |
04-23-2016, 15:01 | #44 (permalink) |
No Life Poster Join Date: Sep 2006 Location: InTheSky
Member: 355613 Status: Offline Sonork: 100.1674359 Thanks Meter: 170 | Checking Recovery file... OK Searching USB Flash Interface... detected COM117 Setup connection... OK Reading data from phone... OK Sending data to phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Android version: 6.0.1 Boot version: N920CXXU2AOJ5 Platform: exynos7420 Boot serial: 0415304336334339 Product board: zenlte Initializating zTool... OK Running zTool, please wait... Start... OK Init... OK Generate and check client proof... OK Verify proof by client... OK Checking DRK status... NG! Writing DRK... OK Checking DRK status... Repairing DMVT key... OK Rebooting phone... OK Repair DRK done Done with Samsung Tool PRO v.25.2 |
04-23-2016, 15:09 | #45 (permalink) |
No Life Poster Join Date: Oct 2004
Member: 87727 Status: Offline Thanks Meter: 110 | DRK Repair Operation: Repair DRK Selected model: SM-G920F Software version: 25.2 File not exists, reinstall application Done with Samsung Tool PRO v.25.2 Already downloaded the repair pack and installed it but still same situation any solution please |
