07-06-2016, 00:30 | #47 (permalink) | |
Insane Poster Join Date: Jun 2014 Location: Hospitle Age: 36
Member: 2203193 Status: Offline Thanks Meter: 28 | Quote:
I have also g935f cant boot normle | |
The Following User Says Thank You to abu-zaid For This Useful Post: |
07-06-2016, 01:15 | #48 (permalink) |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | Full root on ALL S7 QC models G930A+Z/G935A+Z, G930P/G935P, G930T/G935T, G930V/G935V Blang, I've noticed that you didn't include the ATT S7 models for FRP due to the SHA256 error while flashing the eng-boot. Here's a complete package for ALL S7 QC models, and SHA256 error bypassed with a moded Odin. Also, made a Root.BAT mod which should disable the "Security Notice" and FOTA (test and report back). Click on the blue download button to avoid ads. Dev-Host - Samsung_Root_All_S7_QC_models_(BillA).ZIP - The Ultimate Free File Hosting / File Sharing Service Br, BillA |
The Following 5 Users Say Thank You to BillA For This Useful Post: |
07-06-2016, 03:22 | #49 (permalink) | |
Crazy Poster Join Date: Jan 2008 Location: Talisay, Negros Occidental
Member: 680176 Status: Offline Thanks Meter: 7 | Quote:
thanks | |
07-06-2016, 03:49 | #50 (permalink) |
No Life Poster Join Date: Jul 2012 Location: tunisia
Member: 1788877 Status: Offline Thanks Meter: 482 | UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Reset FRP/React/EE Selected model: SM-G935F Software version: 25.9 Checking local file... not found Searching server... not found Done with Samsung Tool PRO v.25.9.9 Last edited by aamigoo; 07-06-2016 at 03:55. |
The Following User Says Thank You to aamigoo For This Useful Post: |
07-06-2016, 08:12 | #52 (permalink) |
No Life Poster Join Date: Aug 2015 Location: Bd+
Member: 2441719 Status: Offline Sonork: uninstall Thanks Meter: 2,073 | samsung j111f unlock z3x Operation: Read Codes Selected model: SM-J110H Software version: 25.9 Searching Samsung modem... detected COM139 Reading phone info... OK Model: SM-J111F Version: J111FXXU0APAA/J111FOJV0APAA/J111FXXU0APB1/J111FXXU0APAA Product code: SM-J111FZWDTHR Phone S/N: R58H33Y1P1Y Imei: sorry no post Unique number: CFN00BB699A2D23 Reading codes... OK Please wait, calculating codes... OK (time - 00:02:09) Freeze code: 35197194 NET lock: 38604293 Sub lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.25.9 |
07-06-2016, 12:11 | #54 (permalink) |
Insane Poster Join Date: Apr 2010 Location: Brazil
Member: 1282334 Status: Offline Thanks Meter: 8 | Ja spent the firmwares gift older modems and nothing ever fails, decepiçao by add something that does not work Operation: Reset FRP/React/EE Selected model: SM-G935F Software version: 25.9 Checking local file... not found Searching server... not found Done with Samsung Tool PRO v.25.9 |
07-06-2016, 12:38 | #55 (permalink) |
Freak Poster Join Date: Dec 2009 Location: manila philipines
Member: 1173732 Status: Offline Sonork: 100.1605145 Thanks Meter: 68 | http://forum.gsmhosting.com/vbb/f453...x-bug-2108313/ sir blang pls try to fix this to unlock thanks |
07-06-2016, 13:30 | #56 (permalink) |
Freak Poster Join Date: Jul 2009 Location: smart shop
Member: 1084045 Status: Offline Thanks Meter: 41 | G935F Remove Frp Done too fast Checking local file... not found Searching server... OK Downloading file... OK Checking local file... OK Searching USB Flash Interface... detected COM17 Setup connection... OK Reading data from phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Model: SM-G935F Android version: 6.0.1 Product code: SM-G935FZKAITV Phone version: G935FXXU1APEQ PDA version: G935FXXU1APF2 CSC version: G935FITV1APE2 CSC country code: ITALY CSC sales code: ITV HW version: MP 0.800 Phone S/N: RF8H20LA5WK Modem board: SHANNON335 RF cal date: 20160208 IMEI: Checking Super user right... true Erasing FRP... OK Checking local file... not found Searching server... OK Downloading file... OK Checking local file... OK Restoring kernel... OK Rebooting phone... OK Reset FRP done Done with Samsung Tool PRO v.25.9 |
The Following User Says Thank You to pogradecar1 For This Useful Post: |
07-06-2016, 14:46 | #57 (permalink) |
No Life Poster Join Date: Jun 2006 Location: manchester, united kingdom Age: 39
Member: 288521 Status: Offline Thanks Meter: 685 | Operation: Reset FRP/React/EE Selected model: SM-G925F Software version: 25.9 Searching Samsung USB Flash Interface... detected COM25 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... OK Erasing Reactivation lock... OK Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.25.9 tried on last update and didnt work.. tried on new update and done.. |
07-06-2016, 15:41 | #58 (permalink) |
Junior Member Join Date: Mar 2007
Member: 477557 Status: Offline Thanks Meter: 2 | for this: Checking local file... not found Searching server... not found try to creat a folder Named: Recovery path: C:\Program Files (x86)\Z3X\Samsung\SamsungTool tnx |
The Following User Says Thank You to kadoor For This Useful Post: |
07-06-2016, 15:42 | #59 (permalink) |
Member: 477557 Status: Offline Thanks Meter: 2 | now i have this error message: Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash Interface... not found Done with Samsung Tool PRO v.25.9 |
