Old 12-23-2016, 19:57   #46 (permalink)
jesedavidfrv's Avatar
Member: 914317
Sonork: 100.1601159
Thanks Meter: 65
Waiting ADB device... Ok
Reading phone info...
Model: SM-J111M
Android version: 5.1.1
Product code: SM-J111MZWDCOO
Phone version: J111MUBU0APE2
PDA version: J111MUBU0APE2
CSC version: J111MUUB0APE2
CSC country code: Colombia
CSC sales code: COO
HW version: MP 0.200
Phone SN: R58H41WRNMY
Modem board: SC9830i
RF cal date: 2016.04.13
IMEI:
Checking Super user right... true
Reading data from phone... Ok
Repairing IMEI... Ok
Writing data to phone... Ok
Rebooting phone... Ok
Repair done
Done with Samsung Tool PRO v.27.6
imei same not chaged please fix bug
J320M Same problem
27.0 work ok
Old 12-23-2016, 20:11   #47 (permalink)
nikhil_gsm's Avatar
Member: 47627
Sonork: 100.1596335
Thanks Meter: 124
Originally Posted by TMAC1122 View Post
Easiest & Fastest way to get your MSL Code..
Download terminal emulator from the google play store.
Type "SU" allow super user access,
Then type "getprop ril.MSL". and press enter to get the MSL code for your device.
But if you have FRP lock how do you root handset. ?
Sent from my XT1706 using Tapatalk
Old 12-23-2016, 20:34   #48 (permalink)
Umesh_Arora's Avatar
Member: 1792140
Sonork: 100.1618782,gaba
Thanks Meter: 6,079
Originally Posted by luckymobile jalandhar View Post
support SM-J510F (unlock via msl code(if you have msl code) where to find msl that is the point
you have gun but you don't have bullets
that's the point
The Following 8 Users Say Thank You to Umesh_Arora For This Useful Post:
Old 12-23-2016, 21:09   #49 (permalink)
Member: 869283
BACKUP INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or
press 'Write CERT' to restore certificates.
To backup/restore QCN, phone diagnostic port must be enabled.
2. Type *#0808# and select 'DM+MODEM+ADB'.
3. Type *#9090# and select 'DM/DUN over HSIC'.
Or use 'Activate Diag' function from 'Repair' tab.
4. Connect phone to PC with USB cable, install drivers if needed.
5. Select diagnostic port in port settings.
6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore.
Operation: Write CERT
Selected model: SM-G600FY
Selected port: COM411 SAMSUNG Mobile USB Serial Port
Software version: 27.6
Checking CERT file... Ok
KEY ID: 0757
Model: SM-G600FY
Android version: 6.0.1
Product code: SM-G600FZKSZTO
Phone version: G600FYDDU1BPH2
PDA version: G600FYVJU1BPJ1
CSC version: G600FYZTO1BPJ1
CSC country code: Brazil
CSC sales code: ZTO
HW version: MP 0.400
Phone SN:
Modem board: MSM8916
RF cal date: 2016.11.01
IMEI:
Writing AT RIL... Ok
Initialization AT RIL... root required
Initialization AT RIL... Ok
Bypass MSL... error (2)
First reset MSL
I have this error to solve and I can not pass cert on this model, I would like help.
Old 12-23-2016, 21:19   #50 (permalink)
Member: 2105654
Thanks Meter: 7
FRP SM-G930V
....SOLUTIONS PLEASE.........!
SECURITY PATCH LEVEL
October 1, 2016
G930VVRU4API3
Operation: Reset FRP/React/EE
Selected model: SM-G930V
Checking local file... Ok
Searching server... Ok
Compare local and server file... OK (up to date)
Searching USB Flash interface... COM32 detected
Setup connection... Ok
Sending data to phone... Ok
Waiting ADB device... timeout
Phone not found
FRP G930V NO WORKING ....!
Old 12-23-2016, 21:34   #51 (permalink)
Member: 2136836
Thanks Meter: 14
Wow what an update!! been waiting for this for long time very very nice update guys. well done and thank you have a happy xmass and a great new year to you and team. big big updates this month Wow!!
The Following User Says Thank You to loop2008 For This Useful Post:
Old 12-23-2016, 21:56   #52 (permalink)
Member: 1808655
Thanks Meter: 27
Full workİng all solutİons %100 ok
Old 12-23-2016, 22:02   #53 (permalink)
bedel's Avatar
Member: 321176
Sonork: 100.1640958
Thanks Meter: 48
Where is the Link I not found in shell too
Old 12-23-2016, 22:03   #54 (permalink)
Member: 1808565
how remove samsung account n910c.
reactivetion is on....
Old 12-23-2016, 22:12   #55 (permalink)
Member: 87364
Thanks Meter: 51
Operation: Read Codes
Selected model: SM-G920F
Please, allow USB debugging on phone... Ok
Model: SM-G920F
Product code: SM-G920FZBATPH
Phone version: G920FXXS4DPIJ
PDA version: G920FXXS4DPJ2
CSC version: G920FOXX4DPH1
CSC country code: portugal
CSC sales code: TPH
HW version: MP 0.800
Phone SN: RF8G51KPYKZ
Chip name: EXYNOS7420
Modem board: SHANNON333
RF cal date: 20150522
IMEI:
Reading NV data... Ok
Checking NV data... Ok
Initialization zTool... Ok
Running zTool, please wait... Ok
Calculating... Ok
HWID: 88 56 9A 8F 75 04 00 00 00 00 00 00 00 00 00 00
Checking hash file... Ok
Please wait, calculating codes... OK (time - 00:00:08)
Freeze code: 24836371
NET lock: 64735305
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
For check lock status: *#7465625#
Old 12-23-2016, 22:24   #56 (permalink)
Member: 1596130
what about repair imei G920p when you will add it ???
Old 12-23-2016, 22:30   #57 (permalink)
Xaker2012's Avatar
Member: 1941705
Thanks Meter: 657
Selected model: SM-J510FN
Selected port: COM1 SAMSUNG Mobile USB Serial Port
Searching Samsung USB Flash interface... COM213 detected
Налаштування з'єднання... Добре
Reading PIT from phone... Добре
Searching FRP lock... Добре
Erasing FRP lock... Добре
Скидання успішне
For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset'
Old 12-23-2016, 22:33   #58 (permalink)
Member: 2496301
Thanks Meter: 34
This update is dhope
The Following User Says Thank You to Megavee For This Useful Post:
Old 12-23-2016, 22:49   #59 (permalink)
Member: 1984825
Thanks Meter: 88
please explain us what is msl exactly
Old 12-24-2016, 00:03   #60 (permalink)
Member: 1589112
Sonork: 1618000
Thanks Meter: 130
Model: SM-G920F
Product code:
Phone version:
CSC version: G920FITV4DPH1
CSC country code: ITALY
CSC sales code: ITV
HW version:
Phone SN:
Modem board:
RF cal date:
IMEI:
Running zTool, please wait... error (7.3)
Page generated in 0.40913 seconds with 8 queries
