Old 12-25-2016, 06:08   #121 (permalink)
Member: 92260
Thanks Meter: 802
MSL is not the 6 digit one!!
Originally Posted by jegan6300 View Post
Use any apps that allow you to view your Android device logs.
An app called aLogcat is a good example. To use this app, take the following steps:
Download aLogcat from Google Play Store and then install it.
Use your phone dialer to call ##DATA# or ##3282#
From the menu that appears, choose “View Mode”
You will see a screen with 3 selections, from here either press and hold the “Home” key and select aLogcat if you ran it before, go to your tray and run Logcat.
Open the aLogcat app, this app will start building your device logs, once it finishes press “Menu” and “Pause” the log.
Search your MSL by press “Menu” and Filter “MSL”
The gsm MSL is not the same as the 6 digit cdma msl/spc!!
It's much harder to get than just reading a logcat,why do you think Blang didn't include it?! It can be gotten from the 11 digit MSL address but not for free at this time.
Old 12-25-2016, 07:25   #122 (permalink)
Member: 2379348
Thanks Meter: 17
sar plz add reset patrran and pin lock
Avengers Box Android MTK Module v0.3.5 Xmas Update Released - [24/12/2016]
Merry Christmas To ALL
Added:
BLU STUDIO ENERGY (MT6582) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
BLU Studio X8 HD (MT6xxx) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
CCE SC452tv (MT6572) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
Doppio Sg401 (MT6572) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
Niu Tek 4D2 (MT6572) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
Niu Andy 5.5e (MT6582) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
Verykool S3502 (MT6571) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
Avvio L660 (MT6735) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
Carrier element ES A771 (MT6592) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
Bmobile AX685 (MT6580) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
ZTE Blade X9 TT175 (MT6753) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
Wiko K-Kool (MT6580) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
Samsung Clone
SM-G900(MT6571) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
GT-i9500(MT6571) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
SM-G350H(MT6572) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
SM-G355H(MT6572) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
SM-G360H(MT6572) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
SM-G530H(MT6572) - Boot Info/Re - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode. MTK6572
SM-G900(MT6572) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
SM-G920 (MT6572) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
SM-J100H(MT6572) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
SM-J100F(MT6572) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
SM-J200H(MT6572) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
SM-J200F(MT6572) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
SM-J300H(MT6572) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
SM-J500F(MT6572) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
SM-J500FD(MT6572) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
SM-J500G(MT6572) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
SM-J500H(MT6572) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
SM-J500HDS(MT6572) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
SM-J510FD(MT6572) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
SM-J700F(MT6572) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
SM-J700H(MT6572) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
GT-i8262(MT6572) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
GT-i8552(MT6572) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
GT-i9060i(MT6572) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
GT-i9060(MT6572) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
GT-i9500(MT6572) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
GT-i9600(MT6572) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
GT-S7562(MT6572) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
GT-S7582(MT6572) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
GT-i9082(MT6572) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
SM-G850(MT6572) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
GT-i8262(MT6575) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
GT-i8552(MT6575) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
GT-i9060(MT6575) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
GT-i9060i(MT6575) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
GT-i9082(MT6575) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
GT-S7562(MT6575) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
GT-S7582(MT6575) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
SM-J700H(MT6582) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
SM-G7102(MT6582) - Boot Info/Repair IMEI/Unlock/Reset Pattern, Privacy & Pin/Security Backup & Restore/Write Firmware/Flash Mode & Meta Mode.
Old 12-25-2016, 07:28   #123 (permalink)
Member: 2610720
Thanks Meter: 32
x-mas mr blang sir.....z3x box best for me.thank you.
Old 12-25-2016, 07:51   #124 (permalink)
Member: 2427980
Sonork: rajuaryal18
Thanks Meter: 3
How to Unlock J510F how to get MSL Code, how to use msl code why not unlocking usually? i have Z3x Box i am using 27.6, Help! Help! Help!
Old 12-25-2016, 08:34   #125 (permalink)
Crazy Poster
Member: 1608515
Thanks Meter: 8
please add j200g 6.0.1 frp solution
Old 12-25-2016, 10:43   #126 (permalink)
Member: 2655726
Thanks Meter: 7
Patching certificate For Galaxy S6 Edge G925F Done ! Thanks so much Blang !
Operation: Patch Certificate
Selected model: SM-G925F
Software version: 27.6
Waiting ADB device... Ok
Reading phone info...
Model: SM-G925F
Android version: 6.0.1
Product code:
Phone version: G925FXXU4DPGW
PDA version: G925FXXU4DPGW
CSC version: G925FTSI4DPH1
CSC country code: Ireland
CSC sales code: TSI
HW version:
Phone SN: RF1D45EJGGR
Chip name: EXYNOS7420
Modem board: SHANNON333
RF cal date:
IMEI:
Checking Super user right... true
Initialization zTool... Ok
Running zTool, please wait... Ok
Reading modem... Ok
Patching modem... Ok
Writing modem... Ok
Rebooting phone... Ok
Patching CERT check... done
Done with Samsung Tool PRO v.27.6
Old 12-25-2016, 11:03   #127 (permalink)
Member: 2427980
Sonork: rajuaryal18
Thanks Meter: 3
Post
J510F can unlock With V27.6?
Old 12-25-2016, 11:13   #128 (permalink)
Member: 985857
Sonork: 100.1677137
Thanks Meter: 131
another great update from these guys
Old 12-25-2016, 13:15   #129 (permalink)
Member: 1326581
Sonork: (((NAEEM)))
Thanks Meter: 46
Model: SM-G925F
Product code:
Phone version: G925FXXS4DPI1
PDA version: G925FXXS4DPJ4
CSC version: G925FOJV3DPB4
CSC country code: UAE
CSC sales code: XSG
HW version:
RF cal date:
IMEI:
Reading NV data... Ok
Checking NV data... error
Security damaged (1)
Old 12-25-2016, 13:47   #130 (permalink)
Member: 1127620
Thanks Meter: 10
J510F unlock function added on 27.6 version, but can't unlock. Please help
Old 12-25-2016, 13:56   #131 (permalink)
Member: 2189410
big update sir thanku
Old 12-25-2016, 14:05   #132 (permalink)
Crazy Poster
Member: 1591817
Thanks Meter: 5
T815 Patch Fail
Selected model: SM-T815
Model: SM-T815
Product code: SM-T815NZDEKSA
Phone version: T815XXU2BPG2
PDA version: T815XXU2BPG3
CSC version: T815OJV2BPG1
CSC country code: KSA
CSC sales code: KSA
HW version: MP 0.500
Phone SN: RF2GA05LCGP
Chip name: EXYNOS5433
RF cal date: 20151027
IMEI:
Running zTool, please wait... error (10 11.1)
Old 12-25-2016, 14:32   #133 (permalink)
Member: 713373
Sonork: 100.1619220
Thanks Meter: 229
Selected model: SM-A800F/DS
Model: SM-A800F
Product code:
Phone version: A800FXXU1BPFB
PDA version: A800FXXS1BPK1
CSC version: A800FOJV1BPF5
CSC country code: TURKEY
CSC sales code: TUR
HW version:
Phone SN: R38G60C5SGW
Chip name: EXYNOS5430
RF cal date:
IMEI:
Running zTool, please wait... error (11.1)
what problem blang???? patch cert problem
Old 12-25-2016, 15:04   #134 (permalink)
Member: 713373
Sonork: 100.1619220
Thanks Meter: 229
5.1.1-6.0.1 fimware error
Selected model: SM-A800YZ
Model: SM-A800YZ
Android version: 5.1.1
Product code:
Phone version: A800YZZTU1AOG2a
PDA version: A800YZZTU1AOG2
CSC version: A800YZZZT1AOG2
CSC country code: Taiwan
CSC sales code: BRI
HW version:
Phone SN:
RF cal date:
IMEI:
a800f and a800yz model patch firmware error mr .blang
Old 12-25-2016, 16:33   #135 (permalink)
Member: 2379260
Thanks Meter: 8
thank u very much . for this information .
Page generated in 0.51581 seconds with 8 queries
