08-31-2017, 09:53 | #1 (permalink) |
Freak Poster Join Date: Mar 2006
Member: 251872 Status: Offline Thanks Meter: 309 | j510fn unlock via server -ook Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will apear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Read Codes via Server Selected model: SM-J510FN Selected port: COM134 SAMSUNG Mobile USB Serial Port Software version: 29.1 Checking Login and Password... OK Ballance: 50 crd. Waiting ADB device... OK Reading phone info... Model: SM-J510FN Android version: 6.0.1 Product code: SM-J510FZDUXSG Phone version: J510FNXXU2APL3 PDA version: J510FNXXU2AQA7 CSC version: J510FOJW2AQB1 CSC country code: UAE CSC sales code: XSG HW version: MP 0.300 Phone SN: RF8J1276EXN Chip name: MSM8916 Modem board: MSM8916 Security patch: 2017-01-01 RF cal date: 2017.01.19 IMEI: Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM53 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 46905148 NET lock: 95169036 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.1 |
The Following User Says Thank You to shahram11 For This Useful Post: |
