06-23-2017, 13:00 | #168 (permalink) |
Freak Poster Join Date: Feb 2016 Location: GJ, India
Member: 2527669 Status: Offline Sonork: 100.1672079 Thanks Meter: 33 | Waiting ADB device... Ok Reading phone info... Model: SM-G950U Android version: 7.0 Product code: SM-G950UZKAXAS Phone version: G950USQU1AQEF PDA version: G950USQU1AQEF CSC version: G950UOYN1AQEF CSC country code: USA CSC sales code: XAS HW version: REV1.0 Phone SN: R28J410N14E Modem board: MSM8998 Security patch: 2017-05-01 RF cal date: 2017.04.11 IMEI: Writing AT RIL... Ok Initialization AT RIL... Ok Unlocking... Ok Rebooting phone... Ok Unlock done |
06-25-2017, 17:03 | #171 (permalink) |
Freak Poster Join Date: Apr 2017 Location: Ashuganj
Member: 2707726 Status: Offline Sonork: 100.1675740 Thanks Meter: 132 | Help me................... BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-N910T Selected port: COM14 SAMSUNG Mobile USB Serial Port Software version: 28.2 Checking CERT file... Ok KEY ID: 0772 Waiting ADB device... Ok Reading phone info... Model: SM-N910T Android version: 6.0.1 Product code: SM2N910TZWETMB Phone version: N910TUVS2EPG2 PDA version: N910TUVS2EPG2 CSC version: N910TTMB2EPG2 CSC country code: USA CSC sales code: TMB HW version: REV1.1 Phone SN: RF8G51CL7RH Modem board: MDM9225M Security patch: 2016-07-01 RF cal date: 2015.05.19 IMEI: Writing AT RIL... Ok Initialization AT RIL... root required Checking Super user right... true Initialization AT RIL... Ok Bypass MSL... error (2) First reset MSL Done with Samsung Tool PRO v.28.2 |
The Following User Says Thank You to gsmali40 For This Useful Post: |
06-26-2017, 06:00 | #173 (permalink) | |
Crazy Poster Join Date: Sep 2010
Member: 1384446 Status: Offline Thanks Meter: 37 | Quote:
S8 and S8+ all models, IMEI repair, direct unlock (without MSL code) We had this with the S7 before. S7 and S7 edge, write from another cert from another S7, temp patch is not good, because if reset, you loose the IMEI information. We need a very good update. I never said will be easy, but I think these update will be more useful. And we should focus less on older models. Would be nice to see, an direct unlock for the S8 and S8+ and imei repair. What you guys think, do you agree? | |
The Following User Says Thank You to ayoshidage For This Useful Post: |
06-29-2017, 16:02 | #177 (permalink) |
Junior Member Join Date: Dec 2016
Member: 2666082 Status: Offline Thanks Meter: 0 | Dont work frp for SM-G532M android 6.0 Dont work 1 flashing combination firmeare 2 activate ports adb and depuratation usb 3 press frp 4 ok 5 adjust ... factori reset 6 ok 7 install firmware sm-g532m 8 power on 9 frp dont remob.. And dont work frp j310m |
