07-02-2017, 11:43 | #166 (permalink) |
Freak Poster Join Date: Dec 2014
Member: 2310475 Status: Offline Thanks Meter: 64 | 1. because free solution will kill business. 2. becouse free solution fast copy past. 3. because high cost hardware involved in this solution. |
The Following User Says Thank You to gulfamkhan For This Useful Post: |
07-02-2017, 11:49 | #168 (permalink) |
No Life Poster Join Date: Oct 2009 Location: nepal,kathmandu,New Road
Member: 1139381 Status: Offline Sonork: 1593399 Thanks Meter: 225 | not work g935a UNLOCK INSTRUCTIONS: Unlocking with original MSL code: 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will apear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-G935A Selected port: COM119 SAMSUNG Mobile USB Serial Port Software version: 28.3 Checking Login and Password... OK Balance: 50 crd. Waiting ADB device... OK Reading phone info... Model: SAMSUNG-SM-G935A Android version: 6.0.1 Product code: Phone version: PDA version: G935AUCS4APK1 CSC version: G935AATT4APK1 CSC country code: USA CSC sales code: ATT HW version: Phone SN: RF8HC0K0A6E Chip name: MSM8996 Modem board: Security patch: 2016-11-01 RF cal date: IMEI: Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM7 detected Reading data from phone... error (2) Done with Samsung Tool PRO v.28.3 |
07-02-2017, 11:49 | #170 (permalink) | |
Member: 2310475 Status: Offline Thanks Meter: 64 | Quote:
its not good lol mr ............... if some one need help , provide help other wise you r lol lol lol lol , its not bad language | |
07-02-2017, 11:55 | #173 (permalink) |
No Life Poster Join Date: Nov 2007 Location: United State Of Islam Age: 34
Member: 624551 Status: Offline Sonork: 100.1584837 Thanks Meter: 737 | J510fn unlock done..... charm charm ----------------------------------------- UNLOCK INSTRUCTIONS: Unlocking with original MSL code: 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will apear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Read Codes via Server Selected model: SM-J510FN Selected port: COM206 SAMSUNG Mobile USB Serial Port Software version: 28.3 Checking Login and Password... OK Balance: 50 crd. Waiting ADB device... OK Reading phone info... Model: SM-J510FN Android version: 6.0.1 Product code: SM-J510FZWUCAC Phone version: J510FNXXU2AQD2 PDA version: J510FNXXU2AQD2 CSC version: J510FNOXY2AQD2 CSC country code: Central Asia CSC sales code: CAC HW version: MP 0.300 Phone SN: RV8J50R5P3A Chip name: MSM8916 Modem board: MSM8916 Security patch: 2017-04-01 RF cal date: 2017.05.16 IMEI: Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM25 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 49372859 NET lock: 73959090 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.28.3 |
07-02-2017, 11:55 | #174 (permalink) | ||
buy box , pay extra money , z3x provided solution | ||
07-02-2017, 12:10 | #175 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Pako new road,Nepal
Member: 257603 Status: Offline Sonork: 100.1605284 Thanks Meter: 147 | error while code read Operation: Read Codes via Server Selected model: SM-G930A Selected port: COM6 Z3X BOX Serial Port Software version: 28.4 Checking Login and Password... OK Balance: 50 crd. Waiting ADB device... OK Reading phone info... Model: SAMSUNG-SM-G930A Android version: 6.0.1 Product code: SM2G930AZKAATT Phone version: G930AUCS4APK1 PDA version: G930AUCS4APK1 CSC version: G930AATT4APK1 CSC country code: USA CSC sales code: ATT HW version: REV0.6 Phone SN: R58HA3CL12Z Chip name: MSM8996 Modem board: MSM8996 Security patch: 2016-11-01 RF cal date: 2016.10.16 IMEI: Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM35 detected Reading data from phone... error (3) Done with Samsung Tool PRO v.28.4 |
07-02-2017, 12:11 | #176 (permalink) |
Freak Poster Join Date: Apr 2015 Location: Ilam,Nepal
Member: 2378764 Status: Offline Sonork: I Dont Use !!! Thanks Meter: 60 | I have One Question If Team Have To Launch version 28.4 Then why There Was A unnecessary For Version 28.3 , i am confuse about this but Its Great Update After See Samsung Tool Pro 28.3 Vs Now !!! Z3x Team Is The Best With Best Regards, |
07-02-2017, 12:12 | #177 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,530 | Quote:
07-02-2017, 12:18 | #179 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,102 | Quote: | |
07-02-2017, 12:18 | #180 (permalink) |
Freak Poster Join Date: Dec 2006 Location: PAKISTAN Age: 38
Member: 421573 Status: Offline Sonork: 100.1650534 Thanks Meter: 54 | blang AND Z3X TEAM .. FIX MY PROBLAME PLEASE GIDE ME . HOW TO CREAT ACCOUNT ON Z3X AND FIX MY UNLOCKING PLEASE URGENTLY . THANS . BLANG . AND Z3X TEAM |
