07-10-2017, 04:52 | #391 (permalink) |
No Life Poster Join Date: May 2008 Location: NC, USA Age: 36
Member: 779665 Status: Offline Sonork: 100.1581784 Thanks Meter: 492 | Code: UNLOCK INSTRUCTIONS: Unlocking with original MSL code: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will apear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-G950U Selected port: COM2 Communications Port Software version: 28.6 Checking Login and Password... OK Balance: 50 crd. Waiting ADB device... OK Reading phone info... Model: SM-G950U Android version: 7.0 Product code: SM-G950UZSAATT Phone version: G950USQU1AQC9 PDA version: G950USQU1AQC9 CSC version: G950UOYN1AQC9 CSC country code: USA CSC sales code: ATT HW version: REV1.0 Phone SN: R38J401AM1L Chip name: MSM8998 Modem board: MSM8998 Security patch: 2017-03-01 RF cal date: 2017.04.03 IMEI: Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM71 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 08095192 NET lock: 41472495 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.28.6 |
07-12-2017, 13:23 | #393 (permalink) |
Freak Poster Join Date: May 2006 Location: Delhi
Member: 284196 Status: Offline Sonork: 100.1640403 Thanks Meter: 250 | Checking Login and Password... OK Balance: 50 crd. Waiting ADB device... OK Reading phone info... Model: SM-G955W Android version: 7.0 Product code: SM-G955WZVAGLW Phone version: G955WVLU1AQEJ PDA version: G955WVLU1AQEJ CSC version: G955WOYA1AQEJ CSC country code: Canada CSC sales code: GLW HW version: REV1.0 Phone SN: R28J441M94W Chip name: MSM8998 Modem board: MSM8998 Security patch: 2017-05-01 RF cal date: 2017.04.28 IMEI: Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM27 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 97495085 NET lock: 03848309 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.28.6 thanks team abhishek |
07-12-2017, 21:34 | #394 (permalink) |
Major Poster Join Date: Dec 2013
Member: 2092415 Status: Offline Thanks Meter: 12 | Hello, I just unlocked a couple of xfinity g955u models days ago, but after unlock, during the using, the screen "UPLOAD MODE..." appears suddenly, I did a reset and the issue disappeared apparently, but yesterday happened again... Do you know what is happening?... Maybe if I flash it with the original firmware can be fixed it... I haven't found the link for this firmware, someone knows where to download it?... Thanks in advance! |
07-19-2017, 09:09 | #398 (permalink) |
Freak Poster Join Date: Dec 2014 Location: Savar,Dhaka,Bangladesh.
Member: 2318480 Status: Offline Sonork: 100.1669259 Thanks Meter: 198 | Good Job Bro .................................................. . |
The Following User Says Thank You to shahinbangla For This Useful Post: |
09-28-2017, 06:39 | #401 (permalink) |
Freak Poster Join Date: Jun 2006 Location: Uzbekistan Bukhara
Member: 300929 Status: Offline Thanks Meter: 27 | Operation: Read Codes via Server Selected model: SM-C701F Software version: 29.4 Checking Login and Password... OK Ballance: 35 crd. Waiting ADB device... OK Reading phone info... Model: SM-C701F Android version: 6.0.1 Product code: SM-C701FZDDINS Phone version: C701FDDU1AQD1 PDA version: C701FDDU1AQE2 CSC version: C701FODD1AQD1 CSC country code: India CSC sales code: INS HW version: MP 0.100 Phone SN: RZ8J40GZ4FK Chip name: MSM8953 Modem board: MSM8953 Security patch: 2017-05-01 RF cal date: 2017.04.10 IMEI: Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM8 detected Reading data from phone... OK Calculating... error (3) Exception: Invalid pointer operation |
11-15-2017, 06:10 | #405 (permalink) |
Crazy Poster Join Date: Jul 2015 Location: Nepal
Member: 2422860 Status: Offline Thanks Meter: 3 | UNLOCK INSTRUCTIONS: Read codes only USB cable : 1. Phone must be powered on. 2. Type *#782872# to switch phone to Qualcomm USB mode, (after operations you can enter *#726872# to switch back to Samsung USB mode.) 3. Connect USB cable, install drivers. 4. Select diagnostic port in port settings. 5. Enter *#7465625# (phone must display locks status). 6. Press 'Read codes' to read security codes. Operation: Read Codes Selected model: SGH-T479B Selected port: COM4 Qualcomm HS-USB Diagnostics 9002 Software version: 29.7.2 Reading phone info... OK Model: SGH-T479B Country code: ij³ª´Ù/BMC Cal date: 2011-02-11 Factory SW: UGKB1 Unique number: 55030001198060 Memory phone: K5R2G1GACC(T479)S Phone SN: RP1B309815 Reading IMEI... OK IMEI: 352815040428018 Reading software version... OK Phone version: T479UGKB1 Searching sysinfo... not found Done with Samsung Tool PRO v.29.7.2 do I Need z3x server credit to unlock this Phone sir Mr Blang |
