Member: 1613469
Thanks Meter: 192 | Quote:
Originally Posted by blang Samsung Tool PRO 28.3 New function, Qualcomm based phones codes reading via server and more. After few years of job we present today own hot and exclusive solution for reading codes from new security qualcomm phones. At this moment not exist free solution for unlock this phones so we decide to do this (Direct READ codes via server) by credits. Why not free? 1. because free solution will kill business.
2. becouse free solution fast copy past.
3. because high cost hardware involved in this solution. How this work. Connect phone via usb(no need even root), enable ADB, press read codes.
Nothing will not changed inside phone, phone will be like before operation (knox will be untouched),
you will have just codes for unlock your phone.
This operation will work if you have enough credits on your account.
If phone has modified data inside, codes may not readed, in this case credits will remain on account. This solution work without any connection to 3nd part server. Solution fully independent from anyone.
So nothing to worry about (someone close account, problem on server, access changes etc.).
We guaranteed 99,9% servers uptime. Unlock Credits Pricing & Unlock Credits Resellers goto HERE: Added Direct Read codes via server :
- addition support SM-A9000 (Direct READ codes via server) - no need root
- addition support SM-A9100 (Direct READ codes via server) - no need root
- addition support SM-A910F (Direct READ codes via server) - no need root
- addition support SM-C5000 (Direct READ codes via server) - no need root
- addition support SM-C5010 (Direct READ codes via server) - no need root
- addition support SM-C5018 (Direct READ codes via server) - no need root
- addition support SM-C7000 (Direct READ codes via server) - no need root
- addition support SM-C7010 (Direct READ codes via server) - no need root
- addition support SM-C7018 (Direct READ codes via server) - no need root
- addition support SM-C9000 (Direct READ codes via server) - no need root
- addition support SM-C900F (Direct READ codes via server) - no need root
- addition support SM-G5510 (Direct READ codes via server) - no need root
- addition support SM-G5520 (Direct READ codes via server) - no need root
- addition support SM-G891A (Direct READ codes via server) - no need root
- addition support SM-G9300 (Direct READ codes via server) - no need root
- addition support SM-G9308 (Direct READ codes via server) - no need root
- addition support SM-G930A (Direct READ codes via server) - no need root
- addition support SM-G930AZ (Direct READ codes via server) - no need root
- addition support SM-G9350 (Direct READ codes via server) - no need root
- addition support SM-G935A (Direct READ codes via server) - no need root
- addition support SM-G9500 (Direct READ codes via server) - no need root
- addition support SM-G9508 (Direct READ codes via server) - no need root
- addition support SM-G950U (Direct READ codes via server) - no need root
- addition support SM-G950U1 (Direct READ codes via server) - no need root
- addition support SM-G950W (Direct READ codes via server) - no need root
- addition support SM-G9550 (Direct READ codes via server) - no need root
- addition support SM-G955U (Direct READ codes via server) - no need root
- addition support SM-G955U1 (Direct READ codes via server) - no need root
- addition support SM-G955W (Direct READ codes via server) - no need root
- addition support SM-J320N0 (Direct READ codes via server) - no need root
- addition support SM-J320Y (Direct READ codes via server) - no need root
- addition support SM-J320YZ (Direct READ codes via server) - no need root
- addition support SM-J320ZN (Direct READ codes via server) - no need root
- addition support SM-J5108 (Direct READ codes via server) - no need root
- addition support SM-J510F (Direct READ codes via server) - no need root
- addition support SM-J510FN (Direct READ codes via server) - no need root
- addition support SM-J510FQ (Direct READ codes via server) - no need root
- addition support SM-J510GN (Direct READ codes via server) - no need root
- addition support SM-J510H (Direct READ codes via server) - no need root
- addition support SM-J510K (Direct READ codes via server) - no need root
- addition support SM-J510L (Direct READ codes via server) - no need root
- addition support SM-J510MN (Direct READ codes via server) - no need root
- addition support SM-J510S (Direct READ codes via server) - no need root
- addition support SM-J510UN (Direct READ codes via server) - no need root
- addition support SM-J727V (Direct READ codes via server) - no need root
- addition support SM-J727VPP (Direct READ codes via server) - no need root
- addition support SM-T818 (Direct READ codes via server) - no need root
- addition support SM-T818A (Direct READ codes via server) - no need root
- addition support SM-T818T (Direct READ codes via server) - no need root
- addition support SM-T818V (Direct READ codes via server) - no need root
- addition support SM-T818W (Direct READ codes via server) - no need root
- addition support SM-T825 (Direct READ codes via server) - no need root
- addition support SM-T825Y (Direct READ codes via server) - no need root New phones added:
- support SM-J530F (Flashing, Backup/Restore CERT, Unlock, Repair, Patch cert, reboot download/recovery) - first in the world
- support SM-J530FM (Flashing, Backup/Restore CERT, Unlock, Repair, Patch cert, reboot download/recovery) - first in the world
- support SM-J530Y (Flashing, Backup/Restore CERT, Unlock, Repair, Patch cert, reboot download/recovery) - first in the world
- support SM-J730F (Flashing, Backup/Restore CERT, Unlock, Repair, Patch cert, reboot download/recovery) - first in the world
- support SM-J730FM (Flashing, Backup/Restore CERT, Unlock, Repair, Patch cert, reboot download/recovery) - first in the world
- support SM-J730GM (Flashing, Backup/Restore CERT, Unlock, Repair, Patch cert, reboot download/recovery) - first in the world
- support SM-C5018 (Flashing, Read/Write QCN, Read/Write EFS, Read/Write SEC, Unlock via MSL , reboot download/recovery)
- support SM-C7018 (Flashing, Read/Write QCN, Read/Write EFS, Read/Write SEC, Unlock via MSL , reboot download/recovery)
- support SM-G950F (Flash, Backup/Restore EFS, reboot download/recovery, unlock via MSL)
- support SM-G950N (Flash, Backup/Restore EFS, reboot download/recovery, unlock via MSL)
- support SM-G955F (Flash, Backup/Restore EFS, reboot download/recovery, unlock via MSL)
- support SM-G955N (Flash, Backup/Restore EFS, reboot download/recovery, unlock via MSL)
- support SM-G9500 (Flashing, Read/Write QCN, Read/Write EFS, Read/Write SEC, Unlock via MSL, reboot download/recovery)
- support SM-G9508 (Flashing, Read/Write QCN, Read/Write EFS, Read/Write SEC, Unlock via MSL, reboot download/recovery)
- support SM-G950U (Flashing, Read/Write QCN, Read/Write EFS, Read/Write SEC, Unlock via MSL, reboot download/recovery)
- support SM-G950U1 (Flashing, Read/Write QCN, Read/Write EFS, Read/Write SEC, Unlock via MSL, reboot download/recovery)
- support SM-G950W (Flashing, Read/Write QCN, Read/Write EFS, Read/Write SEC, Unlock via MSL, reboot download/recovery)
- support SM-G9550 (Flashing, Read/Write QCN, Read/Write EFS, Read/Write SEC, Unlock via MSL, reboot download/ recovery)
- support SM-G955U (Flashing, Read/Write QCN, Read/Write EFS, Read/Write SEC, Unlock via MSL, reboot download/recovery)
- support SM-G955U1 (Flashing, Read/Write QCN, Read/Write EFS, Read/Write SEC, Unlock via MSL, reboot download/recovery)
- support SM-G955W (Flashing, Read/Write QCN, Read/Write EFS, Read/Write SEC, Unlock via MSL, reboot download/recovery) Old phones moved from 2G tool:
- support GT-E2510 (flashing, unlock/read codes/repair(TAT and Flash), backup/restore EEP/FULL)
- support SGH-J700 (flashing, unlock/read codes/repair(TAT and Flash), backup/restore EEP/FULL)
- support SGH-J700I (flashing, unlock/read codes/repair(TAT and Flash), backup/restore EEP/FULL)
- support SGH-J700L (flashing, unlock/read codes/repair(TAT and Flash), backup/restore EEP/FULL)
- support SGH-J700V (flashing, unlock/read codes/repair(TAT and Flash), backup/restore EEP/FULL)
- support SGH-J706 (flashing, unlock/read codes/repair(TAT and Flash), backup/restore EEP/FULL)
- support SGH-J708 (flashing, unlock/read codes/repair(TAT and Flash), backup/restore EEP/FULL)
- support SGH-J708I (flashing, unlock/read codes/repair(TAT and Flash), backup/restore EEP/FULL)
- support SGH-M150 (flashing, unlock/read codes/repair(TAT and Flash), backup/restore EEP/FULL)
- support SGH-M158 (flashing, unlock/read codes/repair(TAT and Flash), backup/restore EEP/FULL)
- support SGH-M200 (flashing, unlock/read codes/repair(TAT and Flash), backup/restore EEP/FULL)
- support SGH-M208 (flashing, unlock/read codes/repair(TAT and Flash), backup/restore EEP/FULL)
- support SGH-M610 (flashing, unlock/read codes/repair(TAT and Flash), backup/restore EEP/FULL)
- support SGH-M618 (flashing, unlock/read codes/repair(TAT and Flash), backup/restore EEP/FULL)
- support GT-M2310 (flashing, unlock/read codes/repair(TAT and Flash), backup/restore EEP/FULL)
- support GT-M2710 (flashing, unlock/read codes/repair(TAT and Flash), backup/restore EEP/FULL)
- support GT-M3200 (flashing, unlock/read codes/repair(TAT and Flash), backup/restore EEP/FULL)
- support GT-M3510 (flashing, unlock/read codes/repair(TAT and Flash), backup/restore EEP/FULL)
- support GT-S3600 (flashing, unlock/read codes/repair(TAT and Flash), backup/restore EEP/FULL)
- support GT-S3600C (flashing, unlock/read codes/repair(TAT and Flash), backup/restore EEP/FULL)
- support GT-S3601 (flashing, unlock/read codes/repair(TAT and Flash), backup/restore EEP/FULL)
- support SGH-T109 (flashing, unlock/read codes/repair(TAT and Flash), backup/restore EEP/FULL)
- support SGH-T139 (flashing, unlock/read codes/repair(TAT and Flash), backup/restore EEP/FULL)
- support SGH-T219S (flashing, unlock/read codes/repair(TAT and Flash), backup/restore EEP/FULL)
- support SGH-T249 (flashing, unlock/read codes/repair(TAT and Flash), backup/restore EEP/FULL)
- support SGH-T369 (flashing, unlock/read codes/repair(TAT and Flash), backup/restore EEP/FULL)
- support SGH-T439 (flashing, unlock/read codes/repair(TAT and Flash), backup/restore EEP/FULL)
- support SGH-T456 (flashing, unlock/read codes/repair(TAT and Flash), backup/restore EEP/FULL)
- support SGH-T459 (flashing, unlock/read codes/repair(TAT and Flash), backup/restore EEP/FULL) - New settings look.
- Odin flasher protocol updated
- Double CTRL toggle Repair tab visibility (if no active work and checked "Allow restore IMEI") | J520mn ??? unlock |
