07-05-2017, 08:54 | #50 (permalink) |
Junior Member Join Date: Nov 2007
Member: 628401 Status: Offline Thanks Meter: 1 | Where to get MSL Code? UNLOCK INSTRUCTIONS: Unlocking with original MSL code: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will apear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Unlock Selected model: SM-G955F Software version: 28.6 Searching Samsung modem... detected COM14 Reading phone info... OK Model: SM-G955F AP version: G955FXXU1AQF7 CSC version: G955FPNG1AQF1 CP version: G955FXXU1AQF7 Product code: PNG Phone SN: R58J50PPNLL Unique number: CE031713AB77552C01 Reading IMEI... OK IMEI: 358 Reading SN... OK Phone SN: R58J50PPNL Enter MSL: canceled Operation aborted Done with Samsung Tool PRO v.28.6 |
07-05-2017, 10:02 | #53 (permalink) |
No Life Poster Join Date: Oct 2009 Location: nepal,kathmandu,New Road
Member: 1139381 Status: Offline Sonork: 1593399 Thanks Meter: 225 | Sc-02h unlock done by z3x Checking Login and Password... OK Balance: 45 crd. Waiting ADB device... OK Reading phone info... Model: SC-02H Android version: 6.0.1 Product code: SM-G935DZBADCM Phone version: SC02HOMU1APL2 PDA version: SC02HOMU1APL2 CSC version: SC02HDCM1APL2 CSC country code: JP CSC sales code: DCM HW version: REV0.4 Phone SN: RF8HB1XAXJV Chip name: MSM8996 Modem board: MSM8996 Security patch: 2016-12-01 RF cal date: 2016.11.16 IMEI: Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM7 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 06303903 NET lock: 75204291 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.28.6 |
07-05-2017, 10:38 | #54 (permalink) | |
Moderator Join Date: Oct 2009 Location: Poland Age: 42
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | Quote:
If restart after code entered mean your phone is in real G950T and someone write firmware from G950U1 and becouse this you got this problem, G950T is not supported to unlock becouse got additional security with t-mobile aplication.
__________________ Please do not Personal Message me for help or troubleshooting. They will be ignored. Use the forums! To get Instant help use "search" & follow "sticky thread"..!!! By respecting/following forum rules,You will be respected .! | |
07-05-2017, 10:45 | #55 (permalink) |
Insane Poster Join Date: May 2014 Location: Nigeria Age: 36
Member: 2194412 Status: Offline Sonork: ****uy Thanks Meter: 1 | hello sir i have problem unlocking not done but credit remove 7/4/2017 6:25:00 PM ] Checking Login and Password... OK [ 7/4/2017 6:26:00 PM ] Balance: 50 crd. [ 7/4/2017 6:26:00 PM ] Waiting ADB device... OK [ 7/4/2017 6:26:00 PM ] Reading phone info... [ 7/4/2017 6:26:00 PM ] Model: SM-J510F [ 7/4/2017 6:26:00 PM ] Android version: 6.0.1 [ 7/4/2017 6:26:00 PM ] Product code: SM-J510FZDDKSA [ 7/4/2017 6:26:00 PM ] Phone version: J510FXXU2AQC1 [ 7/4/2017 6:26:00 PM ] PDA version: J510FXXU2AQC1 [ 7/4/2017 6:26:00 PM ] CSC version: J510FOJV2AQC1 [ 7/4/2017 6:26:00 PM ] CSC country code: KSA [ 7/4/2017 6:26:00 PM ] CSC sales code: KSA [ 7/4/2017 6:26:00 PM ] HW version: MP 0.300 [ 7/4/2017 6:26:00 PM ] Phone SN: RV8J51S9ASJ [ 7/4/2017 6:26:00 PM ] Chip name: MSM8916 [ 7/4/2017 6:26:00 PM ] Modem board: MSM8916 [ 7/4/2017 6:26:00 PM ] Security patch: 2017-04-01 [ 7/4/2017 6:26:00 PM ] RF cal date: 2017.05.23 [ 7/4/2017 6:26:00 PM ] IMEI: [ 7/4/2017 6:26:00 PM ] Rebooting phone... OK [ 7/4/2017 6:26:00 PM ] Waiting ADB device... OK [ 7/4/2017 6:27:00 PM ] Initialization zTool... OK [ 7/4/2017 6:27:00 PM ] Running zTool, please wait... [ 7/4/2017 6:27:00 PM ] Start... OK [ 7/4/2017 6:27:00 PM ] Initialization... OK [ 7/4/2017 6:27:00 PM ] Generate and check client proof... OK [ 7/4/2017 6:27:00 PM ] Verify proof by client... OK [ 7/4/2017 6:27:00 PM ] Reading data from phone... OK [ 7/4/2017 6:28:00 PM ] Searching Ramdump interface... COM34 detected [ 7/4/2017 6:28:00 PM ] Reading data from phone... OK [ 7/4/2017 6:29:00 PM ] Calculating... OK [ 7/4/2017 6:29:00 PM ] Searching server... OK [ 7/4/2017 6:30:00 PM ] Waiting for server answer... error (0) [ 7/4/2017 6:30:00 PM ] wrong ip (should be 197.210.25.141 but you came with 197.210.24.43) [ 7/4/2017 6:30:00 PM ] [ 7/4/2017 6:34:00 PM ] Operation: Read Codes via Server [ 7/4/2017 6:34:00 PM ] Selected model: SM-J510F [ 7/4/2017 6:34:00 PM ] Selected port: COM10 USB Serial Port [ 7/4/2017 6:34:00 PM ] Software version: 28.5 [ 7/4/2017 6:34:00 PM ] |
07-05-2017, 10:47 | #56 (permalink) |
Member: 2194412 Status: Offline Sonork: ****uy Thanks Meter: 1 | [ 7/4/2017 6:10:00 PM ] Operation: Unlock [ 7/4/2017 6:10:00 PM ] Selected model: SM-J510F [ 7/4/2017 6:10:00 PM ] Selected port: COM10 USB Serial Port [ 7/4/2017 6:10:00 PM ] Software version: 28.4 [ 7/4/2017 6:10:00 PM ] [ 7/4/2017 6:22:00 PM ] Operation: Read Codes via Server [ 7/4/2017 6:23:00 PM ] Selected model: SM-J510F [ 7/4/2017 6:23:00 PM ] Selected port: COM10 USB Serial Port [ 7/4/2017 6:23:00 PM ] Software version: 28.5 [ 7/4/2017 6:23:00 PM ] [ 7/4/2017 6:23:00 PM ] Checking Login and Password... OK [ 7/4/2017 6:23:00 PM ] Balance: 50 crd. [ 7/4/2017 6:23:00 PM ] Waiting ADB device... OK [ 7/4/2017 6:23:00 PM ] Reading phone info... [ 7/4/2017 6:23:00 PM ] Model: SM-J510F [ 7/4/2017 6:23:00 PM ] Android version: 6.0.1 [ 7/4/2017 6:23:00 PM ] Product code: SM-J510FZDDKSA [ 7/4/2017 6:23:00 PM ] Phone version: J510FXXU2AQC1 [ 7/4/2017 6:23:00 PM ] PDA version: J510FXXU2AQC1 [ 7/4/2017 6:23:00 PM ] CSC version: J510FOJV2AQC1 [ 7/4/2017 6:23:00 PM ] CSC country code: KSA [ 7/4/2017 6:23:00 PM ] CSC sales code: KSA [ 7/4/2017 6:23:00 PM ] HW version: MP 0.300 [ 7/4/2017 6:23:00 PM ] Phone SN: RV8J51S9ASJ [ 7/4/2017 6:23:00 PM ] Chip name: MSM8916 [ 7/4/2017 6:23:00 PM ] Modem board: MSM8916 [ 7/4/2017 6:23:00 PM ] Security patch: 2017-04-01 [ 7/4/2017 6:23:00 PM ] RF cal date: 2017.05.23 [ 7/4/2017 6:23:00 PM ] IMEI: [ 7/4/2017 6:23:00 PM ] Rebooting phone... OK [ 7/4/2017 6:23:00 PM ] Waiting ADB device... [ 7/4/2017 6:23:00 PM ] Operation aborted [ 7/4/2017 6:23:00 PM ] [ 7/4/2017 6:25:00 PM ] Operation: Read Codes via Server [ 7/4/2017 6:25:00 PM ] Selected model: SM-J510F [ 7/4/2017 6:25:00 PM ] Selected port: COM10 USB Serial Port [ 7/4/2017 6:25:00 PM ] Software version: 28.5 [ 7/4/2017 6:25:00 PM ] [ 7/4/2017 6:25:00 PM ] Checking Login and Password... OK [ 7/4/2017 6:26:00 PM ] Balance: 50 crd. [ 7/4/2017 6:26:00 PM ] Waiting ADB device... OK [ 7/4/2017 6:26:00 PM ] Reading phone info... [ 7/4/2017 6:26:00 PM ] Model: SM-J510F [ 7/4/2017 6:26:00 PM ] Android version: 6.0.1 [ 7/4/2017 6:26:00 PM ] Product code: SM-J510FZDDKSA [ 7/4/2017 6:26:00 PM ] Phone version: J510FXXU2AQC1 [ 7/4/2017 6:26:00 PM ] PDA version: J510FXXU2AQC1 [ 7/4/2017 6:26:00 PM ] CSC version: J510FOJV2AQC1 [ 7/4/2017 6:26:00 PM ] CSC country code: KSA [ 7/4/2017 6:26:00 PM ] CSC sales code: KSA [ 7/4/2017 6:26:00 PM ] HW version: MP 0.300 [ 7/4/2017 6:26:00 PM ] Phone SN: RV8J51S9ASJ [ 7/4/2017 6:26:00 PM ] Chip name: MSM8916 [ 7/4/2017 6:26:00 PM ] Modem board: MSM8916 [ 7/4/2017 6:26:00 PM ] Security patch: 2017-04-01 [ 7/4/2017 6:26:00 PM ] RF cal date: 2017.05.23 [ 7/4/2017 6:26:00 PM ] IMEI: [ 7/4/2017 6:26:00 PM ] Rebooting phone... OK [ 7/4/2017 6:26:00 PM ] Waiting ADB device... OK [ 7/4/2017 6:27:00 PM ] Initialization zTool... OK [ 7/4/2017 6:27:00 PM ] Running zTool, please wait... [ 7/4/2017 6:27:00 PM ] Start... OK [ 7/4/2017 6:27:00 PM ] Initialization... OK [ 7/4/2017 6:27:00 PM ] Generate and check client proof... OK [ 7/4/2017 6:27:00 PM ] Verify proof by client... OK [ 7/4/2017 6:27:00 PM ] Reading data from phone... OK [ 7/4/2017 6:28:00 PM ] Searching Ramdump interface... COM34 detected [ 7/4/2017 6:28:00 PM ] Reading data from phone... OK [ 7/4/2017 6:29:00 PM ] Calculating... OK [ 7/4/2017 6:29:00 PM ] Searching server... OK [ 7/4/2017 6:30:00 PM ] Waiting for server answer... error (0) [ 7/4/2017 6:30:00 PM ] wrong ip (should be 197.210.25.141 but you came with 197.210.24.43) [ 7/4/2017 6:30:00 PM ] [ 7/4/2017 6:34:00 PM ] Operation: Read Codes via Server [ 7/4/2017 6:34:00 PM ] Selected model: SM-J510F [ 7/4/2017 6:34:00 PM ] Selected port: COM10 USB Serial Port [ 7/4/2017 6:34:00 PM ] Software version: 28.5 [ 7/4/2017 6:34:00 PM ] [ 7/4/2017 6:35:00 PM ] Checking Login and Password... OK [ 7/4/2017 6:36:00 PM ] Balance: 45 crd. [ 7/4/2017 6:36:00 PM ] Waiting ADB device... OK [ 7/4/2017 6:36:00 PM ] Reading phone info... [ 7/4/2017 6:37:00 PM ] Model: [ 7/4/2017 6:37:00 PM ] Android version: [ 7/4/2017 6:37:00 PM ] Product code: [ 7/4/2017 6:37:00 PM ] Phone version: [ 7/4/2017 6:37:00 PM ] PDA version: [ 7/4/2017 6:37:00 PM ] CSC version: [ 7/4/2017 6:37:00 PM ] CSC country code: [ 7/4/2017 6:37:00 PM ] CSC sales code: [ 7/4/2017 6:37:00 PM ] HW version: [ 7/4/2017 6:37:00 PM ] Phone SN: [ 7/4/2017 6:37:00 PM ] Chip name: [ 7/4/2017 6:37:00 PM ] Modem board: [ 7/4/2017 6:37:00 PM ] RF cal date: [ 7/4/2017 6:37:00 PM ] IMEI: [ 7/4/2017 6:37:00 PM ] Operation aborted [ 7/4/2017 6:37:00 PM ] [ 7/5/2017 10:34:00 AM ] Operation: Info [ 7/5/2017 10:34:00 AM ] Selected model: SM-J510F [ 7/5/2017 10:34:00 AM ] Selected port: COM10 USB Serial Port [ 7/5/2017 10:34:00 AM ] Software version: 28.5 [ 7/5/2017 10:34:00 AM ] [ 7/5/2017 10:34:00 AM ] Searching Samsung modem... detected COM37 [ 7/5/2017 10:34:00 AM ] Reading phone info... OK [ 7/5/2017 10:34:00 AM ] Model: SM-J510F [ 7/5/2017 10:34:00 AM ] AP version: J510FXXU2AQC1 [ 7/5/2017 10:34:00 AM ] CSC version: J510FOJV2AQC1 [ 7/5/2017 10:34:00 AM ] CP version: J510FXXU2AQC1 [ 7/5/2017 10:34:00 AM ] Product code: SM-J510FZDDKSA [ 7/5/2017 10:34:00 AM ] Phone SN: RV8J51S9ASJ [ 7/5/2017 10:34:00 AM ] Unique number: CQ3007D1AA8CF44 [ 7/5/2017 10:34:00 AM ] Reading IMEI... OK [ 7/5/2017 10:34:00 AM ] IMEI: 356316086525334 [ 7/5/2017 10:34:00 AM ] |
The Following User Says Thank You to maryams For This Useful Post: |
