07-08-2017, 23:23 | #136 (permalink) | |
No Life Poster Join Date: May 2006 Location: zambia
Member: 272581 Status: Offline Thanks Meter: 118 | Quote:
its doesnt work. tried with an s7 some months ago | |
The Following User Says Thank You to kachman For This Useful Post: |
07-08-2017, 23:50 | #137 (permalink) |
Freak Poster Join Date: Dec 2001 Location: israel Age: 69
Member: 7994 Status: Offline Thanks Meter: 20 | UNLOCK INSTRUCTIONS: Unlocking with original MSL code: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will apear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Unlock Selected model: SM-A520F Software version: 28.6 Searching Samsung modem... detected COM25 Reading phone info... OK Model: SM-A520F AP version: A520FXXU1APLO CSC version: A520FOJK1APLG CP version: A520FXXU1APLC Product code: SM-A520FZKAILO Phone SN: R58J109L0HK Unique number: CBJ10FED658A6A3 Reading IMEI... OK IMEI: 3546070802xxxxx Reading SN... OK Phone SN: R58J109L0H Enter MSL: 47021B2538392F31160B5D1E57464B5E Bypass MSL... OK Unlocking... error Done with Samsung Tool PRO v.28.6 need help way error the msl ok |
07-09-2017, 08:21 | #139 (permalink) | |
Freak Poster Join Date: Nov 2007
Member: 626321 Status: Offline Thanks Meter: 56 | Quote:
add samsung n910v | |
07-09-2017, 14:28 | #142 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,643 | Quote:
07-09-2017, 19:51 | #143 (permalink) |
Crazy Poster Join Date: Oct 2014
Member: 2280189 Status: Offline Thanks Meter: 10 | S7 AT&T G935A UNLOCK FAIL !!!!! Operation: Read Codes via Server Selected model: SM-G935A Selected port: COM153 SAMSUNG Mobile USB Serial Port Software version: 28.6 Checking Login and Password OK Balance 50 crd. Waiting ADB device OK Reading phone info Model SAMSUNG-SM-G935A Android version 7.0 Product code SM-G935AZKAATT Phone version G935AUCS4BQE1 PDA version G935AUCS4BQE1 CSC version G935AATT4BQE1 CSC country code USA CSC sales code ATT HW version REV0.7 Phone SN RF8H9343P9D Chip name MSM8996 Modem board MSM8996 Security patch: 2017-05-01 RF cal date 2016.09.28 IMEI: Initialization zTool error (0) |
07-09-2017, 20:25 | #144 (permalink) | |
Freak Poster Join Date: Jul 2013
Member: 1972804 Status: Offline Thanks Meter: 26 | Quote:
07-10-2017, 00:31 | #145 (permalink) |
Junior Member Join Date: Apr 2013
Member: 1918574 Status: Offline Thanks Meter: 11 | Operation: Read Codes via Server Selected model: SM-G930A Selected port: COM3 USB Serial Port Software version: 28.6 Checking Login and Password... OK Balance: 45 crd. Waiting ADB device... OK Reading phone info... Model: SAMSUNG-SM-G930A Android version: 6.0.1 Product code: Not Active Phone version: G930AUCS4APK1 PDA version: G930AUCS4APK1 CSC version: G930AUCS4APK1 CSC country code: USA CSC sales code: ATT HW version: REV0.6 Phone SN: 00000000000 Chip name: MSM8996 Modem board: MSM8996 Security patch: 2016-11-01 RF cal date: 2016.05.26 IMEI: Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM569 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 00000000 NET lock: 01234567 SUB lock: 01234567 SP lock: 01234567 CP lock: 01234567 For check lock status: *#7465625# Done with Samsung Tool PRO v.28.6 i got this error twice which the same device and i got charged twice--- please advise because when i put in the sim card says invaild sim but nothing pops up for putting in code-- I see it didnt read serial number#-- please advise what to do. |
07-10-2017, 21:00 | #148 (permalink) | |
Junior Member Join Date: Jan 2009
Member: 957060 Status: Offline Sonork: ginnipalak Thanks Meter: 5 | Frp solution Quote:
like one click frp remove | |
07-10-2017, 23:56 | #149 (permalink) |
Member: 7994 Status: Offline Thanks Meter: 20 | Hi see if it can be unlock plz idoWhatsApp Image 2017-07-11 at 01.49.46(1).jpeg WhatsApp Image 2017-07-11 at 01.49.46.jpeg WhatsApp Image 2017-07-11 at 01.49.47.jpeg WhatsApp Image 2017-07-11 at 01.49.48.jpeg |
07-11-2017, 04:59 | #150 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | Quote:
Not the Knox app, but the Knox flag when you put the phone in download mode. Press Home + Vol- + Power which shows the Knox Flag on top in really small letters. If it's Knox flag: 1 then you can't unlock. | |
The Following User Says Thank You to BillA For This Useful Post: |
