Old 07-13-2017, 18:23   #181 (permalink)
Member: 1636257
Thanks Meter: 22
Post Still no read code from server
Still no read code from server with z3x 28.7........................
Originally Posted by danjuma View Post
pls check and show me how to read code from z3x server with this model g950f galaxy s8
urgent...........
Old 07-15-2017, 01:18   #182 (permalink)
Member: 92260
Thanks Meter: 598
Originally Posted by FAME Ele View Post
Initialization zTool... OK
Running zTool, please wait...
Start... OK
Initialization... OK
Generate and check client proof... OK
Verify proof by client... OK
Reading data from phone... OK
Searching Ramdump interface... COM41 detected
Calculating... OK
Searching server... OK
Waiting for server answer... OK
Freeze code: 94240631
NET lock: 18291959
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
For check lock status: *#7465625#
Done with Samsung Tool PRO v.28.7
AFTER LONG TRY SUCCESSFULLY UNLOCKED ...
Please don't just say "successful", but tell us exactly what did you do so others can learn from it.
If you don't see the "Read Codes via Server" button then it's not yet available, just wait till it's included in a future update.
I'm sure they would have included it if there was a solution.
Old 07-15-2017, 01:37   #183 (permalink)
kingsoftaz's Avatar
Member: 1996171
Thanks Meter: 79
Originally Posted by blang View Post
this is coma phone. check what band phone support and then check this band in your location.
After factory settings network normal
Old 07-15-2017, 15:57   #184 (permalink)
Member: 2054913
Thanks Meter: 13
Thanks for your reply and its Help to me for solve this issue ..
First I am using dongle instead of z3x box , so connected the dongle in PC front port ,while reading the code from server z3x card not detecting and its get disconnect . then directly connected the dongle in back side port of PC , afterthat change of dongle code read successfully and unlocked ...
Thanks to Mr.Blang for help this issue ...
The Following User Says Thank You to FAME Ele For This Useful Post:
Old 07-15-2017, 21:16   #185 (permalink)
Member: 192296
Sonork: 100.1623059
Thanks Meter: 21
Samsung j210f unlock modem not found pls any solution
Sent from my Blade S6 using Tapatalk
Old 07-16-2017, 05:03   #186 (permalink)
Member: 92260
Thanks Meter: 598
Thanks for the reply, see that wasn't too hard for a quick report.
So what we all learned from this is that sometimes there are issues with the Z3X card or box disconnecting during a server/code session, therefore one must find the most stable port/hub setup to avoid this.
There could be a number of issues, so try these one step at a time.
1. Make sure that USB Debugging is turned on in Developer Options, and DM+MODEM+ADB is selected by *#0808#
2. Make sure in Device Manager the correct drivers have been loaded. (look for any yellow "!" devices and solve it before continuing.
3. In Z3X make sure you have selected the correct modem or DM port.
4. Put the phone into download mode and read the PIT under the Flash tab to see if there's any communication at all, then go from there.
If it still doesn't work, then you may have a hardware issue or some weird software glitch.
Old 07-19-2017, 09:21   #187 (permalink)
Member: 2506735
Sonork: IT ZONE
Thanks Meter: 15
Samsung j320 ZN unlock successfully thanks Z3X
Checking Login and Password... OK
Ballance: 50 crd.
Waiting ADB device... OK
Reading phone info...
Model: SM-J320ZN
Android version: 5.1.1
Product code: SM-J320ZZKN2DX
Phone version: J320ZNDOU1APG2
PDA version: J320ZNDOU1APH1
CSC version: J320ZN2DX1APH1
CSC country code: New Zealand
CSC sales code: 2DX
HW version: MP 0.200
Phone SN: R58HA3WNJSV
Chip name: MSM8916
Modem board: MSM8916
Security patch: 2016-08-01
RF cal date: 2016.10.19
IMEI:
Start... OK
Searching Ramdump interface... COM8 detected
Calculating... OK
Freeze code: 92068407
NET lock: 86360941
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
Done with Samsung Tool PRO v.28.8.1
Old 07-19-2017, 09:27   #188 (permalink)
Member: 2506735
Sonork: IT ZONE
Thanks Meter: 15
Another Samsung j320ZN unlock successfully thanks once again Z3X
Ballance: 45 crd.
Model: SM-J320ZN
CSC sales code: 2DX
Phone SN: R58HA13WSRV
Chip name: MSM8916
RF cal date: 2016.10.06
IMEI:
Start... OK
Calculating... OK
Freeze code: 25282404
NET lock: 09539584
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
Old 07-19-2017, 19:51   #189 (permalink)
Member: 2675119
Hello Blang. I unlocked with z3x - g930p but since the phone is blacklisted, it is not making phone calls. I am using it in Brazil. Any solution for that? Thanks
Page generated in 0.31444 seconds with 8 queries
