Old 07-04-2017, 23:34   #16 (permalink)
bedel's Avatar
Member: 321176
Sonork: 100.1640958
Thanks Meter: 43
Where can I to Download Not see in my shell please.
Regards bedel
The Following User Says Thank You to bedel For This Useful Post:
Old 07-04-2017, 23:37   #17 (permalink)
Member: 1360333
Thanks Meter: 3
Support files | z3x-team
Old 07-04-2017, 23:39   #18 (permalink)
Member: 1360333
Thanks Meter: 3
Originally Posted by blang View Post
you have to enter master code 1st and then nck.
Searching Samsung modem... detected COM143
Reading phone info... OK
Model: SM-G950U1
AP version: G950U1UEU1AQE3
CSC version: G950U1OYM1AQE3
CP version: G950U1UEU1AQE3
Product code: TMB
Phone SN: R28J41ASVZE
Unique number: 9887BC444A4A4D5A4C
Reading IMEI... OK
IMEI: 355987081460478
Done with Samsung Tool PRO v.28.6
keeps asking for code after reboot
Old 07-04-2017, 23:40   #19 (permalink)
apologized's Avatar
Member: 1712203
Thanks Meter: 81
hope to see a support for all phone by server
keep it
Old 07-04-2017, 23:42   #20 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 173,762
Model: SM-G950U1
Product code: TMB
Reading IMEI... OK
try use search button for that, i not sure what the problem. if code entered then code correct. may be need hard reset of phone. may be refresh.
Old 07-04-2017, 23:54   #21 (permalink)
Member: 1110740
Thanks Meter: 165
Originally Posted by zigitoo View Post
Hi! Maybe with this update one bug you fix is "Access Violation..." when I was tryin unlock a J500M but now the unlock process give me error (0). Do you know something.
Thanks.
you must downgrade your modem before unlock j500 in 6.0.1
Old 07-05-2017, 00:00   #22 (permalink)
Member: 1900730
Thanks Meter: 163
ty for the fix!,
here is a link for other ppl
https://www.4shared.com/s/fe85E4vjsei
The Following 5 Users Say Thank You to Maurioski For This Useful Post:
Old 07-05-2017, 00:19   #23 (permalink)
Member: 955311
Thanks Meter: 233
TRYING TO UNLOCJ G955W AND GETTING THIS ERROR HRE IS THELOG
UNLOCK INSTRUCTIONS:
Unlocking with original MSL code:
1. Phone must be powered on.
2. Type *#0808# and select 'DM+ACM+ADB'.
3. Run dialer and type *#0*# (service mode will apear).
4. Connect the phone to USB cable, choose correct COM port in port settings.
5. Press 'Unlock' button.
6. Paste MSL code in new opened window and press 'OK'.
Reading codes using sever:
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Read Codes via server' button, write your login and password in window if it will apear.
(Login and password will be saved as default after first input and can be changed in settings.)
Operation: Read Codes via Server
Selected model: SM-G955W
Software version: 28.6
Checking Login and Password... OK
Balance: 50 crd.
Waiting ADB device...
Please, allow USB debugging on phone... OK
Model: SM-G955W
Android version: 7.0
Product code: SM-G955WZKAVTR
Phone version: G955WVLU1AQDE
PDA version: G955WVLU1AQDE
CSC version: G955WOYA1AQDE
CSC country code: CANADA
CSC sales code: VTR
HW version: REV1.0
Phone SN: R28J33QAV7L
Chip name: MSM8998
Modem board: MSM8998
Security patch: 2017-04-01
RF cal date: 2017.03.31
IMEI:
Rebooting phone... OK
Initialization zTool... OK
Running zTool, please wait...
Start... OK
Initialization... OK
Generate and check client proof... OK
Verify proof by client... OK
Reading data from phone... OK
Searching Ramdump interface... COM11 detected
Reading data from phone... error (0)
Old 07-05-2017, 00:28   #24 (permalink)
mar_celo's Avatar
Member: 96165
Thanks Meter: 36
tab missing
were is repair tab in 28.6
thanks!!!
Old 07-05-2017, 00:29   #25 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Balance: 50 crd.
Model: SM-G955W
CSC sales code: VTR
HW version: REV1.0
Chip name: MSM8998
IMEI:
Start... OK
did you try with older version 28.5?
also try again few times.
Old 07-05-2017, 00:44   #26 (permalink)
Member: 2694991
Sonork: none
Thanks Meter: 23
- Fixed server message Wrong IP.
How about Credits message Wrong IP.
This error auto removed 5 creadit? no code given?
Old 07-05-2017, 00:48   #27 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
send pm with login , we will check and if this happens, credits will back to account.
The Following 2 Users Say Thank You to blang For This Useful Post:
Old 07-05-2017, 00:57   #28 (permalink)
Member: 666927
Is no way to fix J510MN imei?
Thanks
Old 07-05-2017, 01:07   #29 (permalink)
Crazy Poster
Member: 1800389
Sonork: 100.1661286
Thanks Meter: 97
link
Download SamsungToolPRO_28.6.exe | GSM FirmWare
The Following 4 Users Say Thank You to princecomsy For This Useful Post:
Old 07-05-2017, 02:22   #30 (permalink)
Member: 2458549
Thanks Meter: 4
please link to download from mega
The Following User Says Thank You to robesos For This Useful Post:
Page generated in 0.37495 seconds with 8 queries
