Old 07-05-2017, 07:49   #46 (permalink)
farukpdm's Avatar
Member: 1417131
Sonork: 100.1625249
Thanks Meter: 709
what about repair tab?
pls
Sent from my SM-A310F using Tapatalk
The Following 2 Users Say Thank You to farukpdm For This Useful Post:
Old 07-05-2017, 07:57   #47 (permalink)
Member: 161051
Thanks Meter: 6
g955f and g950f frp reset?
Old 07-05-2017, 08:01   #48 (permalink)
Member: 975554
Thanks Meter: 13
just want to ask whats the use of unlock button now?
Old 07-05-2017, 08:36   #49 (permalink)
kamrolhasan's Avatar
Member: 2506300
Thanks Meter: 248
Mr Blang Where is SM-N920V?
FIX IT
Old 07-05-2017, 08:54   #50 (permalink)
Member: 628401
Where to get MSL Code?
UNLOCK INSTRUCTIONS:
Unlocking with original MSL code:
1. Phone must be powered on.
2. Type *#0808# and select 'DM+ACM+ADB'.
3. Run dialer and type *#0*# (service mode will apear).
4. Connect the phone to USB cable, choose correct COM port in port settings.
5. Press 'Unlock' button.
6. Paste MSL code in new opened window and press 'OK'.
Reading codes using sever:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Read Codes via server' button, write your login and password in window if it will apear.
(Login and password will be saved as default after first input and can be changed in settings.)
Operation: Unlock
Selected model: SM-G955F
Software version: 28.6
Searching Samsung modem... detected COM14
Reading phone info... OK
Model: SM-G955F
AP version: G955FXXU1AQF7
CSC version: G955FPNG1AQF1
CP version: G955FXXU1AQF7
Product code: PNG
Phone SN: R58J50PPNLL
Unique number: CE031713AB77552C01
Reading IMEI... OK
IMEI: 358
Reading SN... OK
Enter MSL: canceled
Operation aborted
Done with Samsung Tool PRO v.28.6
Old 07-05-2017, 09:42   #51 (permalink)
Crazy Poster
Member: 1712315
Sonork: 100.1602299
Thanks Meter: 19
plz add g532f Read Write efs and j500f Read Write cert file
Old 07-05-2017, 09:50   #52 (permalink)
Member: 1350761
Thanks Meter: 15
Where is repair tab?
Old 07-05-2017, 10:02   #53 (permalink)
mobitechnepal's Avatar
Member: 1139381
Sonork: 1593399
Thanks Meter: 217
Arrow Sc-02h unlock done by z3x
Checking Login and Password... OK
Balance: 45 crd.
Waiting ADB device... OK
Model: SC-02H
Android version: 6.0.1
Product code: SM-G935DZBADCM
Phone version: SC02HOMU1APL2
PDA version: SC02HOMU1APL2
CSC version: SC02HDCM1APL2
CSC country code: JP
CSC sales code: DCM
HW version: REV0.4
Phone SN: RF8HB1XAXJV
Chip name: MSM8996
Modem board: MSM8996
Security patch: 2016-12-01
RF cal date: 2016.11.16
IMEI:
Initialization zTool... OK
Running zTool, please wait...
Start... OK
Initialization... OK
Generate and check client proof... OK
Verify proof by client... OK
Reading data from phone... OK
Searching Ramdump interface... COM7 detected
Calculating... OK
Searching server... OK
Waiting for server answer... OK
Freeze code: 06303903
NET lock: 75204291
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
For check lock status: *#7465625#
Old 07-05-2017, 10:38   #54 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,221
Originally Posted by godwin25 View Post
Searching Samsung modem... detected COM143
Model: SM-G950U1
AP version: G950U1UEU1AQE3
CSC version: G950U1OYM1AQE3
CP version: G950U1UEU1AQE3
Product code: TMB
Phone SN: R28J41ASVZE
Unique number: 9887BC444A4A4D5A4C
Reading IMEI... OK
IMEI: 355987081460478
keeps asking for code after reboot
If restart after code entered mean your phone is in real G950T and someone write firmware from G950U1 and becouse this you got this problem, G950T is not supported to unlock becouse got additional security with t-mobile aplication.
__________________
Please do not Personal Message me for help or troubleshooting. They will be ignored. Use the forums!
To get Instant help use "search" & follow "sticky thread"..!!!
By respecting/following forum rules,You will be respected .!
Old 07-05-2017, 10:45   #55 (permalink)
Member: 2194412
Sonork: ****uy
hello sir
i have problem unlocking not done but credit remove
7/4/2017 6:25:00 PM ] Checking Login and Password... OK
[ 7/4/2017 6:26:00 PM ] Balance: 50 crd.
[ 7/4/2017 6:26:00 PM ] Waiting ADB device... OK
[ 7/4/2017 6:26:00 PM ] Reading phone info...
[ 7/4/2017 6:26:00 PM ] Model: SM-J510F
[ 7/4/2017 6:26:00 PM ] Android version: 6.0.1
[ 7/4/2017 6:26:00 PM ] Product code: SM-J510FZDDKSA
[ 7/4/2017 6:26:00 PM ] Phone version: J510FXXU2AQC1
[ 7/4/2017 6:26:00 PM ] PDA version: J510FXXU2AQC1
[ 7/4/2017 6:26:00 PM ] CSC version: J510FOJV2AQC1
[ 7/4/2017 6:26:00 PM ] CSC country code: KSA
[ 7/4/2017 6:26:00 PM ] CSC sales code: KSA
[ 7/4/2017 6:26:00 PM ] HW version: MP 0.300
[ 7/4/2017 6:26:00 PM ] Phone SN: RV8J51S9ASJ
[ 7/4/2017 6:26:00 PM ] Chip name: MSM8916
[ 7/4/2017 6:26:00 PM ] Modem board: MSM8916
[ 7/4/2017 6:26:00 PM ] Security patch: 2017-04-01
[ 7/4/2017 6:26:00 PM ] RF cal date: 2017.05.23
[ 7/4/2017 6:26:00 PM ] IMEI:
[ 7/4/2017 6:26:00 PM ] Rebooting phone... OK
[ 7/4/2017 6:27:00 PM ] Initialization zTool... OK
[ 7/4/2017 6:27:00 PM ] Running zTool, please wait...
[ 7/4/2017 6:27:00 PM ] Start... OK
[ 7/4/2017 6:27:00 PM ] Initialization... OK
[ 7/4/2017 6:27:00 PM ] Generate and check client proof... OK
[ 7/4/2017 6:27:00 PM ] Verify proof by client... OK
[ 7/4/2017 6:27:00 PM ] Reading data from phone... OK
[ 7/4/2017 6:28:00 PM ] Searching Ramdump interface... COM34 detected
[ 7/4/2017 6:28:00 PM ] Reading data from phone... OK
[ 7/4/2017 6:29:00 PM ] Calculating... OK
[ 7/4/2017 6:29:00 PM ] Searching server... OK
[ 7/4/2017 6:30:00 PM ] Waiting for server answer... error (0)
[ 7/4/2017 6:30:00 PM ] wrong ip (should be 197.210.25.141 but you came with 197.210.24.43)
[ 7/4/2017 6:34:00 PM ] Operation: Read Codes via Server
[ 7/4/2017 6:34:00 PM ] Selected model: SM-J510F
[ 7/4/2017 6:34:00 PM ] Selected port: COM10 USB Serial Port
[ 7/4/2017 6:34:00 PM ] Software version: 28.5
Old 07-05-2017, 10:47   #56 (permalink)
Member: 2194412
Sonork: ****uy
[ 7/4/2017 6:10:00 PM ] Operation: Unlock
[ 7/4/2017 6:10:00 PM ] Selected model: SM-J510F
[ 7/4/2017 6:10:00 PM ] Selected port: COM10 USB Serial Port
[ 7/4/2017 6:10:00 PM ] Software version: 28.4
[ 7/4/2017 6:22:00 PM ] Operation: Read Codes via Server
[ 7/4/2017 6:23:00 PM ] Selected model: SM-J510F
[ 7/4/2017 6:23:00 PM ] Selected port: COM10 USB Serial Port
[ 7/4/2017 6:23:00 PM ] Software version: 28.5
[ 7/4/2017 6:23:00 PM ] Checking Login and Password... OK
[ 7/4/2017 6:23:00 PM ] Balance: 50 crd.
[ 7/4/2017 6:23:00 PM ] Waiting ADB device... OK
[ 7/4/2017 6:23:00 PM ] Reading phone info...
[ 7/4/2017 6:23:00 PM ] Model: SM-J510F
[ 7/4/2017 6:23:00 PM ] Android version: 6.0.1
[ 7/4/2017 6:23:00 PM ] Product code: SM-J510FZDDKSA
[ 7/4/2017 6:23:00 PM ] Phone version: J510FXXU2AQC1
[ 7/4/2017 6:23:00 PM ] PDA version: J510FXXU2AQC1
[ 7/4/2017 6:23:00 PM ] CSC version: J510FOJV2AQC1
[ 7/4/2017 6:23:00 PM ] CSC country code: KSA
[ 7/4/2017 6:23:00 PM ] CSC sales code: KSA
[ 7/4/2017 6:23:00 PM ] HW version: MP 0.300
[ 7/4/2017 6:23:00 PM ] Phone SN: RV8J51S9ASJ
[ 7/4/2017 6:23:00 PM ] Chip name: MSM8916
[ 7/4/2017 6:23:00 PM ] Modem board: MSM8916
[ 7/4/2017 6:23:00 PM ] Security patch: 2017-04-01
[ 7/4/2017 6:23:00 PM ] RF cal date: 2017.05.23
[ 7/4/2017 6:23:00 PM ] IMEI:
[ 7/4/2017 6:23:00 PM ] Rebooting phone... OK
[ 7/4/2017 6:23:00 PM ] Operation aborted
[ 7/4/2017 6:25:00 PM ] Operation: Read Codes via Server
[ 7/4/2017 6:25:00 PM ] Selected model: SM-J510F
[ 7/4/2017 6:25:00 PM ] Selected port: COM10 USB Serial Port
[ 7/4/2017 6:25:00 PM ] Software version: 28.5
[ 7/4/2017 6:25:00 PM ] Checking Login and Password... OK
[ 7/4/2017 6:35:00 PM ] Checking Login and Password... OK
[ 7/4/2017 6:36:00 PM ] Balance: 45 crd.
[ 7/4/2017 6:36:00 PM ] Waiting ADB device... OK
[ 7/4/2017 6:36:00 PM ] Reading phone info...
[ 7/4/2017 6:37:00 PM ] Model:
[ 7/4/2017 6:37:00 PM ] Android version:
[ 7/4/2017 6:37:00 PM ] Product code:
[ 7/4/2017 6:37:00 PM ] Phone version:
[ 7/4/2017 6:37:00 PM ] PDA version:
[ 7/4/2017 6:37:00 PM ] CSC version:
[ 7/4/2017 6:37:00 PM ] CSC country code:
[ 7/4/2017 6:37:00 PM ] CSC sales code:
[ 7/4/2017 6:37:00 PM ] HW version:
[ 7/4/2017 6:37:00 PM ] Phone SN:
[ 7/4/2017 6:37:00 PM ] Chip name:
[ 7/4/2017 6:37:00 PM ] Modem board:
[ 7/4/2017 6:37:00 PM ] RF cal date:
[ 7/4/2017 6:37:00 PM ] IMEI:
[ 7/4/2017 6:37:00 PM ] Operation aborted
[ 7/5/2017 10:34:00 AM ] Operation: Info
[ 7/5/2017 10:34:00 AM ] Selected model: SM-J510F
[ 7/5/2017 10:34:00 AM ] Selected port: COM10 USB Serial Port
[ 7/5/2017 10:34:00 AM ] Software version: 28.5
[ 7/5/2017 10:34:00 AM ] Searching Samsung modem... detected COM37
[ 7/5/2017 10:34:00 AM ] Reading phone info... OK
[ 7/5/2017 10:34:00 AM ] Model: SM-J510F
[ 7/5/2017 10:34:00 AM ] AP version: J510FXXU2AQC1
[ 7/5/2017 10:34:00 AM ] CSC version: J510FOJV2AQC1
[ 7/5/2017 10:34:00 AM ] CP version: J510FXXU2AQC1
[ 7/5/2017 10:34:00 AM ] Product code: SM-J510FZDDKSA
[ 7/5/2017 10:34:00 AM ] Phone SN: RV8J51S9ASJ
[ 7/5/2017 10:34:00 AM ] Unique number: CQ3007D1AA8CF44
[ 7/5/2017 10:34:00 AM ] Reading IMEI... OK
[ 7/5/2017 10:34:00 AM ] IMEI: 356316086525334
The Following User Says Thank You to maryams For This Useful Post:
Old 07-05-2017, 11:09   #57 (permalink)
Member: 2056780
Where is the restore tab?Who will answer?
Old 07-05-2017, 11:19   #58 (permalink)
glontz's Avatar
Member: 16269
Sonork: 1604924
Thanks Meter: 61
Exclamation
I try unlock with credit G935U get unlock code but after insert tell succesfully unlocked but after restart ask code again !? WHY ?
Old 07-05-2017, 11:25   #59 (permalink)
Member: 280487
Thanks Meter: 5
bay blang please s8 and s8+ repair pach added
Old 07-05-2017, 11:50   #60 (permalink)
delax2006's Avatar
Member: 305365
Thanks Meter: 90
Error 3
Page generated in 0.36241 seconds with 8 queries
