07-06-2017, 01:03 | #93 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,557 | Quote:
how you log related to this ? | |
07-06-2017, 01:04 | #94 (permalink) | |
07-06-2017, 09:13 | #96 (permalink) |
Freak Poster Join Date: Dec 2015 Location: New Zeland
Member: 2506735 Status: Offline Sonork: IT ZONE Thanks Meter: 20 | J320ZN unlcoking error even on 2nd mobile too! Hello Z3X Admin and team and GSM hosting mambers, have problem to unlock Samsung j320ZN i try on 2 mobile but same error on same line. so looking some helpful response thx.. Software version: 28.5 Checking Login and Password... OK Balance: 50 crd. Waiting ADB device... OK Reading phone info... Model: SM-J320ZN Android version: 5.1.1 Product code: SM-J320ZZKN2DX Phone version: J320ZNDOU1APG2 PDA version: J320ZNDOU1APH1 CSC version: J320ZN2DX1APH1 CSC country code: New Zealand CSC sales code: 2DX HW version: MP 0.200 Phone SN: R58J61WE5KE Chip name: MSM8916 Modem board: MSM8916 Security patch: 2016-08-01 RF cal date: 2017.06.16 IMEI: Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... error (4.1) Done with Samsung Tool PRO v.28.6 |
07-06-2017, 09:40 | #98 (permalink) | |
07-06-2017, 16:41 | #103 (permalink) |
Insane Poster Join Date: Oct 2007 Location: Peru - Southamerica
Member: 613047 Status: Offline Thanks Meter: 5 | UNLOCK INSTRUCTIONS: Unlocking with original MSL code: 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will apear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Read Codes via Server Selected model: SM-J510FN Software version: 28.6 Checking Login and Password... OK Balance: 50 crd. Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-J510FN Android version: 6.0.1 Product code: SM-J510FZDUITV Phone version: J510FNXWU2AQD3 PDA version: J510FNXXU2AQD2 CSC version: J510FNITV2AQD1 CSC country code: ITALY CSC sales code: ITV HW version: MP 0.300 Phone SN: RF8J238T4KB Chip name: MSM8916 Modem board: MSM8916 Security patch: 2017-04-01 RF cal date: 2017.03.01 IMEI: Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM24 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 57052593 NET lock: 24951686 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.28.6 |
07-06-2017, 20:59 | #104 (permalink) |
Freak Poster Join Date: Feb 2011 Location: cuba Age: 53
Member: 1524998 Status: Offline Thanks Meter: 76 | UNLOCK INSTRUCCIONES: Unlocking with original MSL code: 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will apear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-G935A Selected port: COM124 SAMSUNG Mobile USB Serial Port Software version: 28.6 Checking Login and Password... Listo Balance: 50 crd. Waiting ADB device... Listo Leyendo información del teléfono ... Modelo: SAMSUNG-SM-G935A Android version: 7.0 Código del Producto: SM2G935TZSAATT Versión del telefono: G935AUCU4BQA6 PDA version: G935AUCU4BQA6 CSC version: G935AATT4BQA6 Código de país CSC: USA Código de Venta CSC: ATT HW version: REV0.7 Phone SN: RF8HA29PNFT Chip name: MSM8996 Módem: MSM8996 Security patch: 2017-02-01 RF cal date: 2016.10.20 IMEI: Reiniciando teléfono ... Listo Waiting ADB device... Listo Initialization zTool... Listo Running zTool, please wait... Start... Listo Initialization... Listo Generate and check client proof... Listo Verify proof by client... Listo Lectura de datos desde el teléfono ... Listo Searching Ramdump interface... COM30 detected Lectura de datos desde el teléfono ... Listo Calculando... Listo Buscando servidor... Listo Waiting for server answer... Listo Congelar código: 07148302 NET lock: 62935959 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 Para comprobar bloquea el estado: *#7465625# Done with Samsung Tool PRO v.28.6 Accepts the code but does not release and when you turn it asks the code some solution please |
07-06-2017, 21:00 | #105 (permalink) |
Junior Member Join Date: Jun 2014 Location: USA
Member: 2210241 Status: Offline Thanks Meter: 2 | Checking Login and Password... OK Balance: 45 crd. Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SAMSUNG-SM-G930AZ Android version: 7.0 Product code: SM-G930AZKYAIO Phone version: G930AZTUS4BQE1 PDA version: G930AZTUS4BQE1 CSC version: G930AZAIO4BQE1 CSC country code: USA CSC sales code: AIO HW version: REV0.6 Phone SN: R38H3036WJK Chip name: MSM8996 Modem board: MSM8996 Security patch: 2017-05-01 RF cal date: 2016.03.02 IMEI: Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM7 detected Reading data from phone... error (0) Done with Samsung Tool PRO v.28.6 this what happen when trying to read cods via remote !!!!!!!!!! |
The Following User Says Thank You to moe1989 For This Useful Post: |
