Old 07-13-2017, 12:31   #61 (permalink)
Member: 2723060
Sonork: I Dont Used
Thanks Meter: 16
pls add patch cert for SM-G935F/G935FD on android 7.0
Old 07-13-2017, 12:34   #62 (permalink)
Member: 2506735
Sonork: IT ZONE
Thanks Meter: 12
Unhappy Same error on my side too, so have you find some solution for it plz kamal_singla
Originally Posted by kamal_singla View Post
I'm Still getting same problem in SM-J320ZN
Operation: Read Codes via Server
Selected model: SM-J320ZN
Selected port: COM201 SAMSUNG Mobile USB Serial Port
Software version: 28.7
Checking Login and Password... OK
Ballance: 50 crd.
Waiting ADB device... OK
Reading phone info...
Model: SM-J320ZN
Android version: 5.1.1
Product code: SM-J320ZZWNTLP
Phone version: J320ZNDOU1APK1
PDA version: J320ZNDOS1AQE2
CSC version: J320ZNTLP1AQB1
CSC country code: Australia
CSC sales code: TLP
HW version: MP 0.200
Phone SN: R58H93PMKLT
Chip name: MSM8916
Modem board: MSM8916
Security patch: 2017-05-01
RF cal date: 2016.09.21
IMEI:
Initialization zTool... OK
Running zTool, please wait...
Start... OK
Initialization... OK
Generate and check client proof... OK
Verify proof by client... OK
Reading data from phone... error (4.1)
Done with Samsung Tool PRO v.28.7
Same error on my side i try more then 5 mobiles j320ZN even on different opprating systems but still same, so have you got some luck or any solution ???
Old 07-13-2017, 12:56   #63 (permalink)
Salman725626's Avatar
Member: 2488001
Sonork: 100.1669288
Thanks Meter: 203
wow good update z3x team please add g570f imei
Old 07-13-2017, 15:23   #64 (permalink)
Member: 1143499
Thanks Meter: 18
Thanks z3x team add more repair of imei and patch cert sm- g532m sm-g570m
The Following User Says Thank You to alexguarin For This Useful Post:
Old 07-13-2017, 16:25   #65 (permalink)
Member: 1110740
Thanks Meter: 152
useless update... NARNIA PHONES ADDED
when gonna realease updates for INTERNATIONAL PHONES?
Old 07-13-2017, 16:44   #66 (permalink)
Member: 92260
Thanks Meter: 478
Originally Posted by blang View Post
We not released unlock for G950u, we released G950U code reading via credits.
Before use this method read attention regarding T-mobile and phone ask codes or not.
So for example if you flash a G930A/T G950A/T with "U" firmware and it starts asking for the unlock code, is that supported for server code reading?
Or only original "U" phones which were not flashed from "A/T" to "U"?
Old 07-13-2017, 16:46   #67 (permalink)
Member: 1300346
Thanks Meter: 39
need help
how to network unlock SM-A720F
and where buy msl code
Searching Samsung modem... detected COM12
Reading phone info... OK
Model: SM-A720F
AP version: A720FXXU1AQC5
CSC version: A720FOJV1AQC8
CP version: A720FXXU1AQC8
Product code: SM-A720FZDDKSA
Phone SN: R58J4xxxxx
Unique number: CBJ10EDF7xxxxxx
Reading IMEI... OK
IMEI: 3557580xxxxxxxx
Reading SN... OK
Phone SN: R58Jxxxxxx
Enter MSL: canceled
Operation aborted
Old 07-13-2017, 17:15   #68 (permalink)
Member: 1870105
Thanks Meter: 19
I ENCOUNTERED SAME PPROBLEM
UNLOCK INSTRUCTIONS:
Unlocking with original MSL code:
1. Phone must be powered on.
2. Run dialer and type *#0*# (service mode will apear).
3. Connect the phone to UART cable, choose correct COM port in port settings.
4. Press 'Unlock' button.
5. Paste MSL code in new opened window and press 'OK'.
Reading codes using sever:
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Read Codes via server' button, write your login and password in window if it will apear.
(Login and password will be saved as default after first input and can be changed in settings.)
Selected model: SM-G935A
Selected port: COM132 SAMSUNG Mobile USB Serial Port
Ballance: 50 crd.
Model: SAMSUNG-SM-G935A
Android version: 6.0.1
Product code: SM-G935AZSAATT
Phone version: G935AUCS4APK1
PDA version: G935AUCS4APK1
CSC version: G935AATT4APK1
CSC country code: USA
CSC sales code: ATT
HW version: REV0.7
Phone SN: R38H608R13V
Chip name: MSM8996
Modem board: MSM8996
Security patch: 2016-11-01
RF cal date: 2016.06.08
IMEI:
Initialization zTool... error (0)
ANY SOLUTION PLS
Old 07-13-2017, 17:38   #69 (permalink)
Member: 1477840
Sonork: 100.1612459
Thanks Meter: 37
SM-G530A patch cert option not present
Old 07-13-2017, 18:04   #70 (permalink)
freshwhite's Avatar
Member: 87204
Thanks Meter: 135
pls add g532f cert patch
Old 07-13-2017, 19:46   #71 (permalink)
.::RONY::.'s Avatar
Member: 1104393
Sonork: 100.1603062 .::RONY::..
Thanks Meter: 119
j3020zn samsung unlock success here the log
Selected port: COM49 SAMSUNG Mobile USB Serial Port
Ballance: 50 crd.
Model: SM-J320ZN
Product code: SM-J320ZZDNXSA
Phone version: J320ZNDOU1API1
PDA version: J320ZNDOS1AQC1
CSC version: J320ZNXSA1API2
CSC sales code: XSA
Phone SN: R58HB380Z1D
Chip name: MSM8916
Security patch: 2017-03-01
RF cal date: 2016.11.16
IMEI:
Start... OK
Reading data from phone... OK
Searching Ramdump interface... COM6 detected
Calculating... OK
Searching server... OK
Waiting for server answer... OK
Freeze code: 74705964
NET lock: 74846079
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
For check lock status: *#7465625#
tnx blang sir
Old 07-13-2017, 19:58   #72 (permalink)
Member: 1892086
Sonork: 1671742
Thanks Meter: 166
Ballance: 50 crd.
CSC sales code: ATT
HW version: REV0.7
Chip name: MSM8996
IMEI:
ANY SOLUTION PLS
Flash QA6 firmware sir, TESTED it
Old 07-13-2017, 20:16   #73 (permalink)
Member: 1712315
Sonork: 100.1602299
Thanks Meter: 14
PLZ ADD J500F AND G532F patch cert for this models
Old 07-13-2017, 20:18   #74 (permalink)
Member: 1712315
Sonork: 100.1602299
Thanks Meter: 14
PLZ ADD G570F patch cert for this models
The Following User Says Thank You to yasin.55 For This Useful Post:
Old 07-13-2017, 20:19   #75 (permalink)
Member: 1392507
Thanks Meter: 28
its possible to unlock SC-02H with Samsung Tool PRO ? using another model like SC-02J?
Page generated in 0.39907 seconds with 8 queries
