07-22-2017, 14:39 | #137 (permalink) | |
No Life Poster Join Date: Jul 2017
Member: 2737570 Status: Offline Thanks Meter: 117 | Quote:
How to use it?? Sent from my iPhone using Tapatalk | |
07-22-2017, 14:43 | #139 (permalink) |
Freak Poster Join Date: Feb 2017 Location: D.R
Member: 2684440 Status: Offline Thanks Meter: 218 | |
The Following User Says Thank You to GSM_FIX For This Useful Post: |
07-22-2017, 20:32 | #140 (permalink) |
Product Supporter Join Date: May 2013 Location: IN THIS WORLD ,LB,RO,
Member: 1933823 Status: Offline Thanks Meter: 1,273 | Bro you need to connect the phone to the box using it and follow the instructions press vol- and power 3-5 sec the box will reset frp no adb no combination uncomplicated IF YOU.LIKE WHAT I POST PRESS THANKS BUTTON |
The Following User Says Thank You to souma_k For This Useful Post: |
07-22-2017, 20:37 | #141 (permalink) | |
Member: 1933823 Status: Offline Thanks Meter: 1,273 | Bro did you see g610f in the supported phones list phones with ufs memory chipset are supported old emmc not supported you need to use old adb method (Sboot from compatible combination to enable adb and reset frp ) Quote:
07-23-2017, 08:55 | #145 (permalink) |
Insane Poster Join Date: Nov 2008 Location: Philippines
Member: 911426 Status: Offline Thanks Meter: 78 | Hold 'Vol down' and press 'POWER ON' for 2-3 seconds Checking phone at COM4 OK Phone detected, do not release 'Vol down' Reading data from phone... OK Release 'Vol down' now Comparing selected model... match (G935K) Setup connection... OK Reseting FRP... OK Rebooting phone... OK Reset FRP done Done with Samsung Tool PRO v.28.8.1 Great update.. |
The Following User Says Thank You to -=flashbang=- For This Useful Post: |
07-24-2017, 03:51 | #146 (permalink) |
Junior Member Join Date: Jun 2014 Location: wedhus gembels
Member: 2207196 Status: Offline Thanks Meter: 1 | Waiting ADB device... OK Reading phone info... Model: SM-J200G Android version: 5.1.1 Product code: Phone version: J200GDDU2API6 PDA version: J200GDDU2APJ1 CSC version: J200GOLE2API1 CSC country code: INDONESIA CSC sales code: XID HW version: Phone SN: 00000000000 Chip name: EXYNOS3475 Modem board: SHANNON308 Security patch: 2016-10-01 RF cal date: IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... error (1 13.2) Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Modem board: SHANNON308 HWID: 99 6F F7 16 EE 73 AD C1 FF 0B 30 7A F3 ED FE 8B Calculating... OK Initialization AT RIL... AT RIL stopped, restarting... error (0) Done with Samsung Tool PRO v.28.9 hello Mr Blank, please fix for j200g no solution yet |
The Following User Says Thank You to oiont For This Useful Post: |
07-24-2017, 04:48 | #147 (permalink) |
Freak Poster Join Date: Jun 2008 Location: Quebec city Canada
Member: 798845 Status: Offline Thanks Meter: 45 | Operation: Reset FRP UFS Selected model: SM-G930W8 Selected port: COM16 USB Serial Port Software version: 28.9 Hold 'Vol down' and press 'POWER ON' for 2-3 seconds Checking phone at COM16 OK Phone detected, do not release 'Vol down' Reading data from phone... OK Release 'Vol down' now Comparing selected model... match (G930W8) Setup connection... OK Reseting FRP... OK Rebooting phone... OK Reset FRP done Done with Samsung Tool PRO v.28.9 |
The Following User Says Thank You to tadj For This Useful Post: |
07-24-2017, 09:30 | #148 (permalink) |
Junior Member Join Date: Dec 2006
Member: 404532 Status: Offline Thanks Meter: 2 | UNLOCK INSTRUCTIONS: To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP UFS Selected model: SM-G935S Selected port: COM4 Z3X USB Serial Port Software version: 28.8 Hold 'Vol down' and press 'POWER ON' for 2-3 seconds Checking phone at COM4 OK Phone detected, do not release 'Vol down' Reading data from phone... OK Release 'Vol down' now Comparing selected model... match (G935S) Setup connection... OK Reseting FRP... OK Rebooting phone... OK Reset FRP done Done with Samsung Tool PRO v.28.8 |
The Following User Says Thank You to thienvuong For This Useful Post: |
07-24-2017, 11:38 | #150 (permalink) |
Junior Member Join Date: Jul 2015
Member: 2422569 Status: Offline Thanks Meter: 0 | TESTED BY ME SIR BIG THANKS...... Operation: Reset FRP UFS Selected model: SM-G9287C Selected port: COM3 Z3X BOX Serial Port Software version: 28.9 Hold 'Vol down' and press 'POWER ON' for 2-3 seconds Checking phone at COM3 OK Phone detected, do not release 'Vol down' Reading data from phone... OK Release 'Vol down' now Comparing selected model... match (G9287C) Setup connection... OK Reseting FRP... OK Rebooting phone... OK Reset FRP done Done with Samsung Tool PRO v.28.9 |
