07-20-2017, 08:54 | #107 (permalink) |
Insane Poster Join Date: Sep 2013 Location: fdfdf
Member: 2021205 Status: Offline Sonork: fdfd Thanks Meter: 10 | i have a g570f that its imei is and baseband is unknown and its not flashing by original file and when i flash the latest build it gives drk error and restarts over and over on samsung logo so i flash boot and sboot from combination so its boot and i can work with the phone but doesnt root to repair imei because when i flash twrp or auto cf root it gives error that the recovery image verification failed and the boot image verification failedso it doesnt root to repair imei,it works and boot when i flash combination fully,but it doesnt root on combination that i repair the imei,because when i try to root i get errors that i told above i tried flashing latest build without cache and hidden after flashing combination it didnt work please help thanks |
07-20-2017, 09:14 | #108 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | Quote:
If you could rewrite all that with some commas (,) and periods (.) then maybe someone would understand it and could help. Have a little courtesy and write legibly please. | |
07-20-2017, 09:31 | #109 (permalink) |
Member: 2021205 Status: Offline Sonork: fdfd Thanks Meter: 10 | i have a g570f that its imei is and baseband is unknown, and when i flash it by original filethe latest build it gives drk error and restarts over and over on samsung logo, so i flash boot and sboot from combination so its boot and i can work with the phone, but doesnt root to repair imei because when i flash twrp or auto cf root it gives error that the recovery image verification failed and the boot image verification failed,so it doesnt root to repair imei it works and boot when i flash combination fully,but it doesnt root on combination that i can repair the imei,because when i try to root i get errors that i told above i tried flashing latest build without cache and hidden after flashing combination it didnt work please help thanks |
07-20-2017, 10:49 | #112 (permalink) | |
Ok much better now, I can actually understand... So obviously you have a DRK error, which MUST be fixed before you can root it, etc. So you may ask how to fix DRK if you can't root it? Well, there's a DRK repair method via uart with no root required, but unfortunately z3x doesn't support that. So, you must find another tool to do the drk repair via uart. Hope that helps, let me know if you need any more info. Take this only as a joke, seems like the period "." doesn't work on your keyboard. lol You can also press the Ctrl key two times quickly to bring up the "Repair" tab. Last edited by BillA; 07-20-2017 at 10:56. | |
07-20-2017, 16:25 | #115 (permalink) |
Freak Poster Join Date: Mar 2014 Location: United States
Member: 2146046 Status: Offline Thanks Meter: 62 | Operation: Reset FRP UFS Selected model: SM-N920A Selected port: COM63 USB Serial Port Software version: 28.8.1 Hold 'Vol down' and press 'POWER ON' for 2-3 seconds Checking phone at COM63 OK Phone detected, do not release 'Vol down' Reading data from phone... OK Release 'Vol down' now Comparing selected model... match (N920A) Setup connection... OK Reseting FRP... OK Rebooting phone... OK Reset FRP done Done with Samsung Tool PRO v.28.8.1 |
