07-25-2017, 02:29 | #69 (permalink) | |
Major Poster Join Date: Jan 2016 Location: Davao Del Sur Philippines.
Member: 2510379 Status: Offline Thanks Meter: 13 | Quote:
but the orig command built inn reser frp via download mode.. what is true? | |
07-25-2017, 06:35 | #70 (permalink) |
Freak Poster Join Date: Jan 2005 Age: 49
Member: 108193 Status: Offline Thanks Meter: 70 | Hello, i got a question, i have a G935a and in the program is a button with read code via server and another taht says unlock, this mean that with the unlock button we dont need credits? and the unlock is free? im rigth or not?. and if i am rigth it seems that the unlock metod dont work becouse the progran never read the phone with the folowing metod. UNLOCK INSTRUCTIONS: Unlocking with original MSL code: 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will apear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Last edited by rudyandremely; 07-25-2017 at 06:42. |
07-25-2017, 08:28 | #72 (permalink) |
No Life Poster Join Date: Sep 2016 Location: IN THIS WORLD Age: 33
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | FRP for G531H Done UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' to deactivate Google account activation lock. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP/React/EE Selected model: SM-G531H Software version: 28.9 Searching Samsung USB Flash interface... COM11 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.28.9 |
