Old 07-27-2017, 02:41   #91 (permalink)
Member: 404532
Thanks Meter: 2
UNLOCK INSTRUCTIONS:
To unlock NEW security type:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Unlock' button and select 'New Unlock' for direct unlock.
To unlock OLD security type:
2. Connect the phone to PC with USB cable.
3. Check Samsung modem in device manager, install drivers if needed.
4. Press 'Unlock' button and select 'Unlock' for direct unlock.
To read security codes (all security types):
4. Press 'Read codes' button to read security codes.
To reset Google account activation lock:
1. ADB must be activated in any way (you can flash sBoot from combination firmware,
make sure, that you are not upgrade sBoot).
2. Connect the phone to PC with USB cable, install drivers if needed.
3. Select device in ADB settings.
4. Press 'Reset FRP' and follow the instructions in program.
5. When process done, press 'Back' on phone and perform factory reset from phone settings.
To reset Google account activation or Samsung reactivation lock:
1. Power on the phone in download mode (turn off phone, press vol.down + home + power).
3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
4. After phone reboot, go to settings and perform factory reset.
To reset Google account activation lock with UART cable:
1. Phone must be powered off
2. Connect the phone to UART cable.
3. Select correct COM port in port settings.
4. Press 'Reset FRP UFS' and follow the instructions in program.
Operation: Reset FRP UFS
Selected model: SM-N920S
Selected port: COM4 Z3X USB Serial Port
Software version: 29.0
Hold 'Vol down' and press 'POWER ON' for 2-3 seconds
Checking phone at COM4 OK
Phone detected, do not release 'Vol down'
Reading data from phone... OK
Release 'Vol down' now
Comparing selected model... match (N920S)
Setup connection... OK
Reseting FRP... OK
Rebooting phone... OK
Reset FRP done
Done with Samsung Tool PRO v.29.0
The Following User Says Thank You to thienvuong For This Useful Post:
Old 07-27-2017, 05:36   #92 (permalink)
obummuo's Avatar
Member: 1849839
Sonork: obummuo
Thanks Meter: 60
i just bought this box(z3x pro) last week and have been trying to activate it.but all i get is ''card not found''
i have tried every possible drivers, even uninstalling all and installing from shell but still the same. updated my windows and still noyhing. i have also tried on another laptop but same result.
i use windows 7 32bit
The Following User Says Thank You to obummuo For This Useful Post:
Old 07-27-2017, 08:36   #93 (permalink)
Member: 192296
Sonork: 100.1623059
Thanks Meter: 21
Pls add solution for security damaged phones
Sent from my Blade S6 using Tapatalk
Old 07-30-2017, 15:52   #94 (permalink)
Member: 828000
how to z3xpro active
Page generated in 0.18064 seconds with 8 queries
