08-11-2017, 12:40 | #139 (permalink) |
Freak Poster Join Date: Feb 2007
Member: 451193 Status: Offline Thanks Meter: 38 | THANKS FOR THE UPDATE BUT SIR THERE IS NO DOWLOAD IT SHOW PLAIN IN OLDER VERSION IT SHOWS ALL THE REQUIRED FRIMWARE WHAT IT IS BUG OR HIDDEN PLZ GUIDE ME IAM UPLOADING SCREEN SHOT THANKS Last edited by rajanumamani; 08-11-2017 at 12:47. |
08-11-2017, 14:50 | #142 (permalink) |
No Life Poster Join Date: Feb 2011 Location: (BaNgLaDeSh).(U.A.E,AD)
Member: 1511441 Status: Offline Sonork: 100.1604057 Thanks Meter: 1,162 | Operation: Reset FRP UFS Selected model: SM-A810F Selected port: COM40 UST Pro II Port Software version: 29.0 Hold 'Vol down' and press 'POWER ON' for 2-3 seconds Checking phone at COM40 OK Phone detected, do not release 'Vol down' Reading data from phone... OK Release 'Vol down' now Comparing selected model... match (A810F) Setup connection... OK Reseting FRP... OK Rebooting phone... OK Reset FRP done Done with Samsung Tool PRO v.29.0 |
08-11-2017, 21:19 | #143 (permalink) | |
Banned Join Date: May 2013 Location: Hacked by Hackflax on tiktok
Member: 1941705 Status: Offline Thanks Meter: 1,248 | J510FN Read Codes via Server Quote:
08-12-2017, 00:19 | #144 (permalink) |
Junior Member Join Date: Oct 2016 Location: nouvelle aquitaine france
Member: 2635281 Status: Offline Thanks Meter: 5 | Hello I wanted to use samsung tool pro v29 to desemlock an A700f, it tells me to select in ADB But nothing appears in this window, an idea? thank you |
08-12-2017, 11:37 | #145 (permalink) |
No Life Poster Join Date: Sep 2016 Location: IN THIS WORLD Age: 33
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect the phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Read QCN Selected model: SM-E500H Selected port: COM199 SAMSUNG Mobile USB Serial Port Software version: 29.0 Reading ID... OK Detected ID: 00000FFE (MSM8916) SW version: MPSS.DPM.2.0.c5-00083-M8936FAAAANUZM-1 Reading ESN... OK Backuping RFNV... OK Backuping FeatureMask... OK Backuping NV Item... OK Backuping NV Item SIM1... OK Backuping NV Item SIM2... OK Backuping Provisioning Item Files... OK Reading QCN done Done with Samsung Tool PRO v.29.0 |
