Old 07-26-2017, 14:33   #61 (permalink)
Member: 2662443
Sonork: lennypolanco
Try unlocking a galaxy s8 g950u from metropcs but the device does not ask me to put the unlock pin does anyone have any solutions please?
Old 07-26-2017, 14:43   #62 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,244
Sorry no solution for this, just official unlock way by aplication.
__________________
Please do not Personal Message me for help or troubleshooting. They will be ignored. Use the forums!
To get Instant help use "search" & follow "sticky thread"..!!!
By respecting/following forum rules,You will be respected .!
The Following User Says Thank You to wgmmmx1 For This Useful Post:
Old 07-26-2017, 14:43   #63 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,244
Originally Posted by Denva View Post
Can G955F unlock via Server ?
Can't this is exynos cpu and read codes work only on qualcomm cpu.
__________________
Old 07-26-2017, 14:44   #64 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,244
Originally Posted by tinhtit View Post
plz add S8 , SM-G950F Unlock via sever
Same like upper , Can't this is exynos cpu and read codes work only on qualcomm cpu.
__________________
Old 07-26-2017, 15:12   #65 (permalink)
Member: 2565910
Thanks Meter: 4
Please solution for exynos 7570 repair and patch
Enviado desde mi Blade V6 mediante Tapatalk
Old 07-26-2017, 15:44   #66 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 667
No you should use uart 523k cable
Originally Posted by ocarela View Post
can it be done with regular usb cable?
IF YOU.LIKE WHAT I POST PRESS THANKS BUTTON
Old 07-26-2017, 16:13   #67 (permalink)
Member: 266278
Thanks Meter: 8
Originally Posted by souma_k View Post
bro if you read the first post you will see in yellow press ctrl and any key or ctrl long press it will appear but it is much easier to ask without reading
Yes you are right. Its my bad. Believe me it is hard to read every single line when you are busy to answer the customers and run your job in its way.
Yhanks for correcting me.
Old 07-26-2017, 16:14   #68 (permalink)
skander's Avatar
Member: 144865
Thanks Meter: 15
what happen with imei tab ??
Old 07-26-2017, 17:09   #69 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 667
Hahahaaa bro you also , you are busy and you didn't read the yellow line press ctrl and any key or ctrl long press it will appear (repair button)
The Following User Says Thank You to souma_k For This Useful Post:
Old 07-26-2017, 17:35   #70 (permalink)
Member: 2493737
Thanks Meter: 2
for repair tab just click ctrl Twice. but imei option is absent. what the soluton plz
The Following User Says Thank You to stinger88 For This Useful Post:
Old 07-26-2017, 17:54   #71 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 667
Press ctrl long press and it appears
Old 07-26-2017, 18:34   #72 (permalink)
Member: 2493737
Thanks Meter: 2
imei repair option is absent.
Old 07-26-2017, 19:31   #73 (permalink)
Member: 2430185
try PRESS V + 2 x CTRL
The Following User Says Thank You to ferbeoulve For This Useful Post:
Old 07-26-2017, 20:04   #74 (permalink)
Member: 2010402
Sonork: 0000DE0C5C1809F7
"- support SM-N9300 (Direct READ codes via server) - no need root
- support SM-N930A (Direct READ codes via server) - no need root"
What code can read?
Old 07-26-2017, 21:09   #75 (permalink)
Member: 2684440
Thanks Meter: 98
J320V and J320VPP...paid solutions for unlock? Really? 😕
Enviado desde mi SM-G7102 mediante Tapatalk
Page generated in 0.39994 seconds with 8 queries
